Developer documentation | Axl-2.5.1
axlInspectorObjectSet Class Reference
#include <axlInspectorObjectSet.h>
Inheritance diagram for axlInspectorObjectSet:
Public Slots
void setData (QList< dtkAbstractData * > dataSet)
void onSamplingDataChanged_u (int numSamples)
void onSamplingDataChanged_v (int numSamples)
void onSizeChanged (int size)
void onColorChanged (QColor color)
void onOpacityChanged (int opacity)
void openShader (void)
void onShaderStateChanged (bool isShader)
void onShaderChanged (QString)
void onLineEditShaderChanged (QString)
Signals
void colorChanged (QColor color, dtkAbstractData *data)
void dataChangedByGeometry (dtkAbstractData *data)
void update (void)
void modifiedProperty (dtkAbstractData *, int)
Public Member Functions
 axlInspectorObjectSet (QWidget *parent=0)
 ~axlInspectorObjectSet (void)
QSize sizeHint (void) const
Detailed Description
Definition at line 31 of file axlInspectorObjectSet.h.
Constructor & Destructor Documentation
axlInspectorObjectSet::axlInspectorObjectSet ( QWidget *  parent = 0)
Definition at line 63 of file axlInspectorObjectSet.cpp.
axlInspectorObjectSet::~axlInspectorObjectSet ( void  )
Definition at line 87 of file axlInspectorObjectSet.cpp.
Member Function Documentation
void axlInspectorObjectSet::colorChanged ( QColor  color,
dtkAbstractData *  data
signal
void axlInspectorObjectSet::dataChangedByGeometry ( dtkAbstractData *  data)
signal
void axlInspectorObjectSet::modifiedProperty ( dtkAbstractData *  ,
int
signal
void axlInspectorObjectSet::onColorChanged ( QColor  color)
slot
Definition at line 491 of file axlInspectorObjectSet.cpp.
void axlInspectorObjectSet::onLineEditShaderChanged ( QString  shader)
slot
Definition at line 371 of file axlInspectorObjectSet.cpp.
void axlInspectorObjectSet::onOpacityChanged ( int  opacity)
slot
Definition at line 510 of file axlInspectorObjectSet.cpp.
void axlInspectorObjectSet::onSamplingDataChanged_u ( int  numSamples)
slot
Definition at line 438 of file axlInspectorObjectSet.cpp.
void axlInspectorObjectSet::onSamplingDataChanged_v ( int  numSamples)
slot
Definition at line 456 of file axlInspectorObjectSet.cpp.
void axlInspectorObjectSet::onShaderChanged ( QString  shader)
slot
Definition at line 404 of file axlInspectorObjectSet.cpp.
void axlInspectorObjectSet::onShaderStateChanged ( bool  isShader)
slot
Definition at line 422 of file axlInspectorObjectSet.cpp.
void axlInspectorObjectSet::onSizeChanged ( int  size)
slot
Definition at line 469 of file axlInspectorObjectSet.cpp.
void axlInspectorObjectSet::openShader ( void  )
slot
Definition at line 394 of file axlInspectorObjectSet.cpp.
void axlInspectorObjectSet::setData ( QList< dtkAbstractData * >  dataSet)
slot
Definition at line 99 of file axlInspectorObjectSet.cpp.
QSize axlInspectorObjectSet::sizeHint ( void  ) const
Definition at line 94 of file axlInspectorObjectSet.cpp.
void axlInspectorObjectSet::update ( void  )
signal
The documentation for this class was generated from the following files:
