#include <axlInspectorObjectTorus.h>
Definition at line 32 of file axlInspectorObjectTorus.h.
| axlInspectorObjectTorus::axlInspectorObjectTorus |
QWidget * |
parent = 0 | ) |
| axlInspectorObjectTorus::~axlInspectorObjectTorus |
void |
virtual |
| void axlInspectorObjectTorus::colorChanged |
QColor |
color, |
dtkAbstractData * |
data |
signal |
| void axlInspectorObjectTorus::dataChangedByGeometry |
dtkAbstractData * |
data | ) |
signal |
| void axlInspectorObjectTorus::modifiedProperty |
dtkAbstractData * |
int |
signal |
| void axlInspectorObjectTorus::onColorChanged |
QColor |
color | ) |
slot |
| void axlInspectorObjectTorus::onCoordDataChangedCenter_x |
double |
x | ) |
slot |
| void axlInspectorObjectTorus::onCoordDataChangedCenter_y |
double |
y | ) |
slot |
| void axlInspectorObjectTorus::onCoordDataChangedCenter_z |
double |
z | ) |
slot |
| void axlInspectorObjectTorus::onCoordDataChangedDirection_x |
double |
x | ) |
slot |
| void axlInspectorObjectTorus::onCoordDataChangedDirection_y |
double |
y | ) |
slot |
| void axlInspectorObjectTorus::onCoordDataChangedDirection_z |
double |
z | ) |
slot |
| void axlInspectorObjectTorus::onCrossSectionRadiusChanged |
double |
crossSectionRadius | ) |
slot |
| void axlInspectorObjectTorus::onLineEditShaderChanged |
QString |
shader | ) |
slot |
| void axlInspectorObjectTorus::onOpacityChanged |
int |
opacity | ) |
slot |
| void axlInspectorObjectTorus::onRingRadiusChanged |
double |
ringRadius | ) |
slot |
| void axlInspectorObjectTorus::onShaderChanged |
QString |
shader | ) |
slot |
| void axlInspectorObjectTorus::onShaderStateChanged |
bool |
isShader | ) |
slot |
| void axlInspectorObjectTorus::openShader |
void |
slot |
| void axlInspectorObjectTorus::setData |
axlTorus * |
torus | ) |
slot |
| QSize axlInspectorObjectTorus::sizeHint |
void |
const |
| void axlInspectorObjectTorus::update |
void |
signal |
| void axlInspectorObjectTorus::updateValues |
void |
slot |
The documentation for this class was generated from the following files:
