Class axlInspectorToolCreatorDataDynamicDialog is the dialog used to create dynamic data. More...
#include <axlInspectorToolCreatorDataDynamicDialog.h>
 | Public Slots | |
| void | run (void) |
| Create the dynamic Object when the create button is clicked.  More... | |
| void | setProcessName (void) |
| Checks if the process exits and then display appropriated dialog to enter and select inputs.  More... | |
| Signals | |
| void | dataInserted (axlAbstractData *data) |
| Public Member Functions | |
| axlInspectorToolCreatorDataDynamicDialog (QWidget *parent=0) | |
| ~axlInspectorToolCreatorDataDynamicDialog (void) | |
| Delete the dialog.  More... | |
| void | setController (axlInspectorObjectController *controller) |
| Assigns a controller.  More... | |
Definition at line 31 of file axlInspectorToolCreatorDataDynamicDialog.h.
| axlInspectorToolCreatorDataDynamicDialog::axlInspectorToolCreatorDataDynamicDialog | ( | QWidget * | parent = 0 | ) |
Definition at line 58 of file axlInspectorToolCreatorDataDynamicDialog.cpp.
| axlInspectorToolCreatorDataDynamicDialog::~axlInspectorToolCreatorDataDynamicDialog | ( | void | ) |
Delete the dialog.
Definition at line 142 of file axlInspectorToolCreatorDataDynamicDialog.cpp.
 | signal |
 | slot |
Definition at line 238 of file axlInspectorToolCreatorDataDynamicDialog.cpp.
| void axlInspectorToolCreatorDataDynamicDialog::setController | ( | axlInspectorObjectController * | controller | ) |
Definition at line 153 of file axlInspectorToolCreatorDataDynamicDialog.cpp.
 | slot |
Definition at line 165 of file axlInspectorToolCreatorDataDynamicDialog.cpp.
