Developer documentation | Axl-2.5.1
axlInspectorToolInterface Class Reference
#include <axlInspectorToolFactory.h>
Inheritance diagram for axlInspectorToolInterface:
axlInspectorToolCreator axlInspectorToolCreatorCircleArc axlInspectorToolCreatorCone axlInspectorToolCreatorCylinder axlInspectorToolCreatorEllipsoid axlInspectorToolCreatorLine axlInspectorToolCreatorPlane axlInspectorToolCreatorPoint axlInspectorToolCreatorSphere axlInspectorToolCreatorTorus
Signals
void update (void)
void modifiedProperty (dtkAbstractData *data, int)
void dataChanged (dtkAbstractData *data)
void dataChangedByControlPoints (dtkAbstractData *)
void dataChangedByShader (dtkAbstractData *data, QString isophoteShaderXml)
void dataChangedByShaderFromString (dtkAbstractData *data, QString isophoteShaderXml)
void dataSetToRemove (QList< dtkAbstractData * > data)
void dataSetFieldsChanged (QList< axlAbstractData * > dataSet, QString fieldName)
void finished (void)
Public Member Functions
 axlInspectorToolInterface (QWidget *parent=0)
virtual ~axlInspectorToolInterface (void)
virtual void setController (axlInspectorObjectController *controller)
void setImplementation (const QString &implementation)
void setView (axlAbstractView *view)
void setToolFactorySingleton (axlInspectorToolFactory *toolFactorySingleton)
axlInspectorToolFactorytoolFactorySingleton (void)
Protected Attributes
axlAbstractViewm_view
axlInspectorObjectControllerm_controller
dtkAbstractProcess * m_process
QList< dtkAbstractData * > dataSet
Detailed Description
Definition at line 42 of file axlInspectorToolFactory.h.
Constructor & Destructor Documentation
axlInspectorToolInterface::axlInspectorToolInterface ( QWidget *  parent = 0)
Definition at line 41 of file axlInspectorToolFactory.cpp.
axlInspectorToolInterface::~axlInspectorToolInterface ( void  )
virtual
Definition at line 51 of file axlInspectorToolFactory.cpp.
Member Function Documentation
void axlInspectorToolInterface::dataChanged ( dtkAbstractData *  data)
signal
void axlInspectorToolInterface::dataChangedByControlPoints ( dtkAbstractData *  )
signal
void axlInspectorToolInterface::dataChangedByShader ( dtkAbstractData *  data,
signal
void axlInspectorToolInterface::dataChangedByShaderFromString ( dtkAbstractData *  data,
signal
void axlInspectorToolInterface::dataSetFieldsChanged ( QList< axlAbstractData * >  dataSet,
QString  fieldName
signal
void axlInspectorToolInterface::dataSetToRemove ( QList< dtkAbstractData * >  data)
signal
void axlInspectorToolInterface::finished ( void  )
signal
void axlInspectorToolInterface::modifiedProperty ( dtkAbstractData *  data,
int
signal
void axlInspectorToolInterface::setImplementation ( const QString &  implementation)
Definition at line 68 of file axlInspectorToolFactory.cpp.
void axlInspectorToolInterface::setToolFactorySingleton ( axlInspectorToolFactory toolFactorySingleton)
Definition at line 82 of file axlInspectorToolFactory.cpp.
void axlInspectorToolInterface::setView ( axlAbstractView view)
Definition at line 98 of file axlInspectorToolFactory.cpp.
axlInspectorToolFactory * axlInspectorToolInterface::toolFactorySingleton ( void  )
Definition at line 87 of file axlInspectorToolFactory.cpp.
void axlInspectorToolInterface::update ( void  )
signal
Member Data Documentation
QList<dtkAbstractData *> axlInspectorToolInterface::dataSet
protected
Definition at line 73 of file axlInspectorToolFactory.h.
axlInspectorObjectController* axlInspectorToolInterface::m_controller
protected
Definition at line 71 of file axlInspectorToolFactory.h.
dtkAbstractProcess* axlInspectorToolInterface::m_process
protected
Definition at line 72 of file axlInspectorToolFactory.h.
axlAbstractView* axlInspectorToolInterface::m_view
protected
Definition at line 70 of file axlInspectorToolFactory.h.
The documentation for this class was generated from the following files:
