| addField(axlAbstractField *field) | axlAbstractData | |
| axlAbstractData(axlAbstractData *parent=NULL) | axlAbstractData | |
| axlAbstractData(const axlAbstractData &data) | axlAbstractData | |
| axlShapeBSpline() | axlShapeBSpline | |
| changeFieldName(QString fieldName) | axlAbstractData | |
| color | axlAbstractData | |
| color(void) const | axlAbstractData | |
| connectionsAreDefined(void) | axlShapeBSpline | |
| convertDataToQVariant(void) const | axlAbstractData | virtual |
| convertQVariantToData(const QVariantList &data) | axlAbstractData | virtual |
| countBoundaryEdges() const | axlShapeBSpline | |
| countControlPoints() const | axlShapeBSpline | |
| countControlPoints_u(void) const | axlShapeBSpline | |
| countControlPoints_v(void) const | axlShapeBSpline | |
| countFaces(void) | axlShapeBSpline | |
| createSurfaceFromBSplineDataSet(QList< axlAbstractSurfaceBSpline * > dataSet) | axlShapeBSpline | |
| description(void) const | axlShapeBSpline | |
| editable(void) | axlAbstractData | |
| emitEdgeSelected(int numEdge) | axlShapeBSpline | |
| endParam_u(int i) | axlShapeBSpline | |
| endParam_v(int i) | axlShapeBSpline | |
| eval(axlPoint *point, double u, double v) | axlShapeBSpline | |
| eval(axlPoint *point, double u, double v, int i) | axlShapeBSpline | |
| fields(void) | axlAbstractData | |
| getCoef(int index) const | axlShapeBSpline | |
| getControlPointConnection(int i) | axlShapeBSpline | |
| getEdge(int i) | axlShapeBSpline | |
| getFace(int i) | axlShapeBSpline | |
| getPoint(int i) | axlShapeBSpline | |
| hasFaces(void) | axlShapeBSpline | |
| identifier(void) const | axlShapeBSpline | |
| indexSelected(int i) | axlShapeBSpline | signal |
| insert_edge(Edge *edge) | axlShapeBSpline | |
| insert_face(Face *face) | axlShapeBSpline | |
| insert_point(double x, double y, double z) | axlShapeBSpline | |
| insert_point(axlPoint *point) | axlShapeBSpline | |
| mesh(void) | axlAbstractData | |
| modifiedField(void) | axlAbstractData | signal |
| modifiedGeometry(void) | axlAbstractData | signal |
| modifiedProperty(void) | axlAbstractData | signal |
| modifiedStructure(void) | axlAbstractData | signal |
| normal(axlPoint *normal, double u, double v) | axlShapeBSpline | |
| normal(axlPoint *currentNormal, double paramCourant_u, double paramCourant_v, int indice) | axlShapeBSpline | |
| numSamples_u(int numCell) | axlShapeBSpline | |
| numSamples_v(int numCell) | axlShapeBSpline | |
| opacity | axlAbstractData | |
| opacity(void) const | axlAbstractData | |
| order_u() const | axlShapeBSpline | |
| order_v() const | axlShapeBSpline | |
| registered(void) | axlShapeBSpline | static |
| removeEdge(int i) | axlShapeBSpline | |
| scalarValue(double u, double v) | axlShapeBSpline | |
| selectIndex(int i) | axlShapeBSpline | inline |
| setCoef(int index, double *newCoordinate) | axlShapeBSpline | |
| setColor(double r, double g, double b) | axlAbstractData | |
| setColor(const QColor &color) | axlAbstractData | slot |
| setControlPoints(int nbpoints, double *points) | axlShapeBSpline | |
| setEdge(int i, QVector< int > p, int order) | axlShapeBSpline | |
| setEdge(int i, QVector< int > p, axlAbstractCurveBSpline *curv) | axlShapeBSpline | |
| setEditable(bool edit) | axlAbstractData | slot |
| setFace(int i, QVector< int > p, int order_u, int order_v, int nu, int nv) | axlShapeBSpline | |
| setFace(int i, QVector< int > p, axlAbstractSurfaceBSpline *surf) | axlShapeBSpline | |
| setMesh(axlMesh *mesh) | axlAbstractData | |
| setNumSamples_u(int numSamples) | axlShapeBSpline | |
| setNumSamples_v(int numSamples) | axlShapeBSpline | |
| setOpacity(const double &opacity) | axlAbstractData | slot |
| setScalarValue(double u, double v, double value) | axlShapeBSpline | |
| setShader(const QString &shader) | axlAbstractData | slot |
| setSize(const double &size) | axlAbstractData | slot |
| setStripes(int stripes) | axlShapeBSpline | |
| setSurface(int order_u, int order_v, int nbpoints, int nbEdges, int nbFaces, double *points, QVector< QVector< int > > pe, QVector< QVector< int > >pf, QVector< QPair< int, int > >npf) | axlShapeBSpline | |
| setUpdateView(bool updateView) | axlAbstractData | |
| shader | axlAbstractData | |
| shader(void) const | axlAbstractData | |
| size | axlAbstractData | |
| size(void) const | axlAbstractData | |
| startParam_u(int i) | axlShapeBSpline | |
| startParam_v(int i) | axlShapeBSpline | |
| stripes(void) | axlShapeBSpline | |
| touchField(void) | axlAbstractData | virtualslot |
| touchGeometry(void) | axlAbstractData | slot |
| touchProperty(void) | axlAbstractData | slot |
| touchStructure(void) | axlAbstractData | slot |
| updateFaceEdges(int numFace) | axlShapeBSpline | |
| updateFieldList(QString nameField) | axlAbstractData | |
| updateView(void) | axlAbstractData | |
| ~axlAbstractData(void) | axlAbstractData | virtual |
| ~axlShapeBSpline() | axlShapeBSpline | |
