Class axlShapeBSpline defines a set of boundary curves (Edges) and bspline surface patches (Face). More...
#include <axlShapeBSpline.h>
Classes | |
struct | ControlPoint |
struct | Edge |
struct | Face |
Signals | |
void | indexSelected (int i) |
void | modifiedGeometry (void) |
void | modifiedStructure (void) |
void | modifiedField (void) |
void | modifiedProperty (void) |
Public Member Functions | |
axlShapeBSpline () | |
~axlShapeBSpline () | |
QString | description (void) const |
Return a description of the surface. More... | |
QString | identifier (void) const |
Return the "axlShapeBSpline" identifier.Useful for data factory. More... | |
void | setSurface (int order_u, int order_v, int nbpoints, int nbEdges, int nbFaces, double *points, QVector< QVector< int > > pe, QVector< QVector< int > >pf, QVector< QPair< int, int > >npf) |
Create a surface. More... | |
void | setControlPoints (int nbpoints, double *points) |
Add control points to the Surface. All points should be on the plane z =0;. More... | |
void | setFace (int i, QVector< int > p, int order_u, int order_v, int nu, int nv) |
Add or modify a face to the Surface. More... | |
void | setFace (int i, QVector< int > p, axlAbstractSurfaceBSpline *surf) |
void | setEdge (int i, QVector< int > p, int order) |
Add or modify an edge to the Surface. More... | |
void | setEdge (int i, QVector< int > p, axlAbstractCurveBSpline *curv) |
void | removeEdge (int i) |
Remove an edge. More... | |
void | createSurfaceFromBSplineDataSet (QList< axlAbstractSurfaceBSpline * > dataSet) |
Create an axlShapeBSpline from a set of axlAbstractSurfaceBSpline. More... | |
Edge * | getEdge (int i) |
Return edge. More... | |
Face * | getFace (int i) |
Return face. More... | |
ControlPoint * | getPoint (int i) |
Return control point. More... | |
axlPoint | getCoef (int index) const |
Get a coefficient of the surface. More... | |
bool | setCoef (int index, double *newCoordinate) |
Modified a coefficient of the surface. More... | |
int | countControlPoints () const |
int | countBoundaryEdges () const |
Return how many edges. More... | |
int | order_u () const |
Return the order of the surface for the u parameter. More... | |
int | order_v () const |
Return the order of the surface for the v parameter. More... | |
int | numSamples_u (int numCell) |
Mesh subdision on the u-direction. More... | |
int | numSamples_v (int numCell) |
Mesh subdision on the v-direction. More... | |
void | setNumSamples_u (int numSamples) |
Modify mesh subdision on the v-direction. Same for all faces. More... | |
void | setNumSamples_v (int numSamples) |
int | stripes (void) |
void | setStripes (int stripes) |
void | normal (axlPoint *normal, double u, double v) |
void | eval (axlPoint *point, double u, double v) |
bool | connectionsAreDefined (void) |
Return true if control points connections were defined by developers. False if there are default connections visualization. More... | |
QList< int > | getControlPointConnection (int i) |
int | countControlPoints_u (void) const |
int | countControlPoints_v (void) const |
void | selectIndex (int i) |
double | scalarValue (double u, double v) |
void | setScalarValue (double u, double v, double value) |
double | startParam_u (int i) |
Return the first u parameter value of a face. More... | |
double | startParam_v (int i) |
double | endParam_u (int i) |
Return the last u parameter value of a face. More... | |
double | endParam_v (int i) |
Return the last v parameter value of a face. More... | |
void | eval (axlPoint *point, double u, double v, int i) |
Compute coordinates of a point of the Surface. More... | |
void | normal (axlPoint *currentNormal, double paramCourant_u, double paramCourant_v, int indice) |
Compute normal. More... | |
bool | hasFaces (void) |
Return whether the surface have several faces. More... | |
int | countFaces (void) |
Return how many faces. More... | |
void | insert_point (double x, double y, double z) |
Add a point to the control point set of the surface. More... | |
void | insert_point (axlPoint *point) |
void | insert_edge (Edge *edge) |
Add an edge to the surface. More... | |
void | insert_face (Face *face) |
Add a face to the surface. More... | |
void | updateFaceEdges (int numFace) |
Update indices list of the face edges. More... | |
void | emitEdgeSelected (int numEdge) |
axlAbstractData (axlAbstractData *parent=NULL) | |
axlAbstractData (const axlAbstractData &data) | |
virtual | ~axlAbstractData (void) |
const QColor & | color (void) const |
const double & | opacity (void) const |
const double & | size (void) const |
const QString & | shader (void) const |
const bool & | editable (void) |
const bool & | updateView (void) |
void | setColor (double r, double g, double b) |
void | addField (axlAbstractField *field) |
Add a field to the field list of the object. More... | |
bool | updateFieldList (QString nameField) |
Check if a field with the same name is already applied on the object. More... | |
QString | changeFieldName (QString fieldName) |
axlMesh * | mesh (void) |
Return the mesh of that object is computed. More... | |
void | setMesh (axlMesh *mesh) |
Set a corresponding mesh for that object. More... | |
virtual QVariantList | convertDataToQVariant (void) const |
Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData. More... | |
virtual int | convertQVariantToData (const QVariantList &data) |
Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0. More... | |
void | setUpdateView (bool updateView) |
QList< axlAbstractField * > | fields (void) |
Static Public Member Functions | |
static bool | registered (void) |
Emit a signal edgesSeleted. More... | |
Additional Inherited Members | |
void | touchGeometry (void) |
void | touchProperty (void) |
void | touchStructure (void) |
virtual void | touchField (void) |
void | setColor (const QColor &color) |
void | setOpacity (const double &opacity) |
void | setSize (const double &size) |
void | setShader (const QString &shader) |
void | setEditable (bool edit) |
QColor | color |
double | opacity |
double | size |
QString | shader |
To build each Edge and Face of an axlShapeBSpline, control points must be specified as their supports are respectively bspline curves and bspline surfaces. To be sure a control point is shared by different element and not duplicated, control point point must be defines one, even if it is shared by several Faces and/or Edges. This type of object is used in mesherplugin, which connect Axel and Num3sis simulator, as a geometry of a problem. Edges are useful to determine where to apply boundary conditions of a physical problem. Faces are useful for meshing by divided the geometry into several domains.
Definition at line 12 of file axlShapeBSpline.h.
axlShapeBSpline::axlShapeBSpline | ( | ) |
Definition at line 25 of file axlShapeBSpline.cpp.
axlShapeBSpline::~axlShapeBSpline | ( | ) |
Definition at line 30 of file axlShapeBSpline.cpp.
bool axlShapeBSpline::connectionsAreDefined | ( | void | ) |
Definition at line 418 of file axlShapeBSpline.cpp.
int axlShapeBSpline::countBoundaryEdges | ( | ) | const |
Definition at line 485 of file axlShapeBSpline.cpp.
int axlShapeBSpline::countControlPoints | ( | void | ) | const |
index | : coefficient index. |
Definition at line 319 of file axlShapeBSpline.cpp.
int axlShapeBSpline::countControlPoints_u | ( | void | ) | const |
Definition at line 397 of file axlShapeBSpline.cpp.
int axlShapeBSpline::countControlPoints_v | ( | void | ) | const |
Definition at line 403 of file axlShapeBSpline.cpp.
int axlShapeBSpline::countFaces | ( | void | ) |
Definition at line 477 of file axlShapeBSpline.cpp.
void axlShapeBSpline::createSurfaceFromBSplineDataSet | ( | QList< axlAbstractSurfaceBSpline * > | dataSet | ) |
dataSet | : set of axlAbstractSurfaceBSpline. |
Definition at line 117 of file axlShapeBSpline.cpp.
QString axlShapeBSpline::description | ( | void | ) | const |
Definition at line 76 of file axlShapeBSpline.cpp.
void axlShapeBSpline::emitEdgeSelected | ( | int | numEdge | ) |
double axlShapeBSpline::endParam_u | ( | int | i | ) |
i | : face identifier. |
Definition at line 442 of file axlShapeBSpline.cpp.
double axlShapeBSpline::endParam_v | ( | int | i | ) |
Definition at line 450 of file axlShapeBSpline.cpp.
void axlShapeBSpline::eval | ( | axlPoint * | point, |
double | u, | ||
double | v | ||
Definition at line 360 of file axlShapeBSpline.cpp.
double | u, | ||
double | v, | ||
int | i | ||
point | : point of the surface. |
u | : value of the u-parameter. |
v | : value of the v-parameter. |
Definition at line 460 of file axlShapeBSpline.cpp.
axlPoint axlShapeBSpline::getCoef | ( | int | index | ) | const |
Definition at line 283 of file axlShapeBSpline.cpp.
QList< int > axlShapeBSpline::getControlPointConnection | ( | int | i | ) |
Definition at line 409 of file axlShapeBSpline.cpp.
axlShapeBSpline::Edge * axlShapeBSpline::getEdge | ( | int | i | ) |
Return edge.
i | : edge identifier. |
Definition at line 493 of file axlShapeBSpline.cpp.
axlShapeBSpline::Face * axlShapeBSpline::getFace | ( | int | i | ) |
Return face.
Definition at line 501 of file axlShapeBSpline.cpp.
axlShapeBSpline::ControlPoint * axlShapeBSpline::getPoint | ( | int | i | ) |
i | : control point identifier. |
Definition at line 509 of file axlShapeBSpline.cpp.
bool axlShapeBSpline::hasFaces | ( | void | ) |
Definition at line 469 of file axlShapeBSpline.cpp.
QString axlShapeBSpline::identifier | ( | void | ) | const |
Definition at line 68 of file axlShapeBSpline.cpp.
signal |
void axlShapeBSpline::insert_edge | ( | Edge * | edge | ) |
edge | : edge of type axlShapeBSpline::Edge. |
Definition at line 690 of file axlShapeBSpline.cpp.
void axlShapeBSpline::insert_face | ( | Face * | face | ) |
face | : face of type axlShapeBSpline::Face. |
Definition at line 698 of file axlShapeBSpline.cpp.
void axlShapeBSpline::insert_point | ( | double | x, |
double | y, | ||
double | z | ||
x | : x-coordinate. |
y | : y-coordinate |
z | : z-coordinate |
Definition at line 681 of file axlShapeBSpline.cpp.
void axlShapeBSpline::insert_point | ( | axlPoint * | point | ) |
point | : a point. |
Definition at line 670 of file axlShapeBSpline.cpp.
void axlShapeBSpline::normal | ( | axlPoint * | normal, |
double | u, | ||
double | v | ||
Definition at line 367 of file axlShapeBSpline.cpp.
void axlShapeBSpline::normal | ( | axlPoint * | currentNormal, |
double | paramCourant_u, | ||
double | paramCourant_v, | ||
int | indice | ||
Compute normal.
currentNormal | : normal. |
paramCourant_u | : value of the u-parameter. |
paramCourant_v | : value of the v-parameter. |
indice | : face identifier. |
Definition at line 561 of file axlShapeBSpline.cpp.
int axlShapeBSpline::numSamples_u | ( | int | i | ) |
Definition at line 517 of file axlShapeBSpline.cpp.
int axlShapeBSpline::numSamples_v | ( | int | i | ) |
Definition at line 526 of file axlShapeBSpline.cpp.
int axlShapeBSpline::order_u | ( | void | ) | const |
Definition at line 94 of file axlShapeBSpline.cpp.
int axlShapeBSpline::order_v | ( | void | ) | const |
Definition at line 105 of file axlShapeBSpline.cpp.
static |
numEdge | : the identifier of the Edge selected.Registered the data in the data factory. |
Definition at line 59 of file axlShapeBSpline.cpp.
void axlShapeBSpline::removeEdge | ( | int | i | ) |
double axlShapeBSpline::scalarValue | ( | double | u, |
double | v | ||
Definition at line 374 of file axlShapeBSpline.cpp.
inline |
Definition at line 166 of file axlShapeBSpline.h.
bool axlShapeBSpline::setCoef | ( | int | index, |
double * | newCoordinate | ||
Definition at line 293 of file axlShapeBSpline.cpp.
void axlShapeBSpline::setControlPoints | ( | int | nbpoints, |
double * | points | ||
nbpoints | : number of control points. |
points | : points coordinates, size of points is equal to 3*nbpoints. |
Definition at line 184 of file axlShapeBSpline.cpp.
void axlShapeBSpline::setEdge | ( | int | i, |
QVector< int > | p, | ||
int | order | ||
p | : set of indices of control points owned by the face support. |
order | : curve support order. |
Definition at line 218 of file axlShapeBSpline.cpp.
axlAbstractCurveBSpline * | curv | ||
curv | : curve support. |
Definition at line 253 of file axlShapeBSpline.cpp.
void axlShapeBSpline::setFace | ( | int | i, |
int | order_u, | ||
int | order_v, | ||
int | nu, | ||
int | nv | ||
p | : set of indices of control points owned by the surface support. |
order_u | : surface support order for u parameter. |
order_v | : surface support order for v parameter. |
nu | : number of control point the u-direction. |
nv | : number of control point the v-direction. |
Definition at line 200 of file axlShapeBSpline.cpp.
axlAbstractSurfaceBSpline * | surf | ||
surf | : surface support. |
Definition at line 236 of file axlShapeBSpline.cpp.
void axlShapeBSpline::setNumSamples_u | ( | int | numSamples | ) |
numSamples | : number of points for the subdivision. |
Definition at line 534 of file axlShapeBSpline.cpp.
void axlShapeBSpline::setNumSamples_v | ( | int | numSamples | ) |
Definition at line 549 of file axlShapeBSpline.cpp.
void axlShapeBSpline::setScalarValue | ( | double | u, |
double | v, | ||
double | value | ||
Definition at line 379 of file axlShapeBSpline.cpp.
void axlShapeBSpline::setStripes | ( | int | stripes | ) |
Definition at line 391 of file axlShapeBSpline.cpp.
void axlShapeBSpline::setSurface | ( | int | order_u, |
int | order_v, | ||
int | nbpoints, | ||
int | nbEdges, | ||
int | nbFaces, | ||
double * | points, | ||
QVector< QVector< int > > | pe, | ||
QVector< QVector< int > > | pf, | ||
QVector< QPair< int, int > > | npf | ||
Create a surface.
order_u | : surface order for u parameter. |
order_v | : surface order for v parameter. |
nbEdges | : number of edges. |
nbFaces | : number of faces. |
pe | : contains all set of indices to precise what points is owned by each edge. |
pf | : contains all set of indices to precise what points is owned by each face. |
npf | : contains all pair of size to precise how many control points for the u-direction and the v-direction, for each face. |
Definition at line 167 of file axlShapeBSpline.cpp.
double axlShapeBSpline::startParam_u | ( | int | i | ) |
Definition at line 426 of file axlShapeBSpline.cpp.
double axlShapeBSpline::startParam_v | ( | int | i | ) |
Definition at line 434 of file axlShapeBSpline.cpp.
int axlShapeBSpline::stripes | ( | void | ) |
Definition at line 384 of file axlShapeBSpline.cpp.
void axlShapeBSpline::updateFaceEdges | ( | int | numFace | ) |
numFace | : face identifier. |
Definition at line 569 of file axlShapeBSpline.cpp.
