Developer documentation | Axl-2.5.1
axlShapeBSpline.cpp
Go to the documentation of this file.
1 #include "axlShapeBSpline.h"
2
3 #include <axlCore/axlShape.h>
4 #include <axlCore/axlMesh.h>
5
6 #include <axlCore/axlPoint.h>
7
8 #include <dtkLog/dtkLog.h>
9 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
10
11
12 class axlShapeBSplinePrivate
13 {
14 public :
15  QVector<axlShapeBSpline::ControlPoint *> points;
16  QVector<axlShapeBSpline::Edge *> edges;
17  QVector<axlShapeBSpline::Face *> faces;
18
19  int sample;
20
21  QMap<QPair<double, double>, double> scalar_values;
22  QHash<int, QList<int> > connect;
23 };
24
25 axlShapeBSpline::axlShapeBSpline() : axlAbstractData(), d(new axlShapeBSplinePrivate)
26 {
27  d->sample = 40;
28 }
29
31 {
32 }
33
34
35 // /**
36 // * @brief Emit a signal edgesSeleted
37 // * @param numEdge : the identifier of the Edge selected.
38 // */
39 // void axlShapeBSpline::emitEdgeSelected(int numEdge){
40
41 // if(numEdge < 0 || numEdge >= d->edges.size()){
42 // emit edgeSelected(-1, 0,0);
43 // }else{
44
45 // int previous = 0;
46 // for(int i = 0; i < numEdge;i++){
47 // previous = d->edges.at(i)->support->numSamples()-1 + previous;
48 // }
49 // int n = d->edges.at(numEdge)->support->numSamples();
50 // emit edgeSelected(numEdge, previous,n);
51 // }
52 // }
53
54
56
60  return dtkAbstractDataFactory::instance()->registerDataType("axlShapeBSpline", createaxlShapeBSpline);
61 }
62
63
65
68 QString axlShapeBSpline::identifier(void) const{
69  return "axlShapeBSpline";
70 }
71
73
76 QString axlShapeBSpline::description(void) const{
77  QString description;
78  description.append(identifier());
79  description.append( "has ");
80  description.append(QString::number(countControlPoints()));
81  description.append("control points;");
82  description.append(QString::number(countBoundaryEdges()));
83  description.append("boundary edges and ");
84  description.append(QString::number(d->faces.size()));
85  description.append("faces");
86
87  return description;
88 }
89
91
95  if(d->faces.isEmpty())
96  return -1;
97  else
98  return d->faces.first()->support->order_u();
99 }
100
102
106  if(d->faces.isEmpty())
107  return -1;
108  else
109  return d->faces.first()->support->order_v();
110 }
111
112
117 void axlShapeBSpline::createSurfaceFromBSplineDataSet(QList<axlAbstractSurfaceBSpline *> dataSet){
118
119  //We suppose all bspline surfaces of dataSet have same orders.
120  int order_u = dataSet.first()->order_u();
121  int order_v = dataSet.first()->order_v();
122  int nbEdges = 0;
123  int nbFaces = dataSet.size();
124
125  QVector< QVector<int> >pe;
126  QVector< QVector<int> >pf;
127  QVector< QPair<int,int> > npf;
128
129  QList<axlPoint > p;
130  for(int i = 0; i < dataSet.size(); i++){
131  QPair<int, int> pair = QPair<int,int>(dataSet.at(i)->countControlPoints_u(),dataSet.at(i)->countControlPoints_v() );
132  QVector<int> pf0;
133  for(int j = 1; j <= dataSet.at(i)->countControlPoints();j++){
134  const axlPoint& pointa = dataSet.at(i)->getCoef(j);
135  if(!isContained(p, pointa, pf0)){
136  p.append(pointa);
137  }
138  }
139  pf.append(pf0);
140  npf.append(pair);
141  }
142
143  int nbpoints = p.size();
144  double *points = new double[3*nbpoints];
145
146  for(int i = 0;i < p.size();i++){
147  points[3*i] = p.at(i).x();
148  points[3*i+1] = p.at(i).y();
149  points[3*i+2] = p.at(i).z();
150  }
151
152  this->setSurface( order_u, order_v, nbpoints, nbEdges, nbFaces, points, pe, pf, npf );
153 }
154
167 void axlShapeBSpline::setSurface(int order_u, int order_v,int nbpoints,int nbEdges, int nbFaces, double *points, QVector< QVector<int> > pe, QVector< QVector<int> >pf, QVector< QPair<int,int> > npf ){
168
169  setControlPoints(nbpoints,points);
170
171  for (int i = 0; i < nbEdges; i++) {
172  setEdge(i, pe.at(i),order_u);
173  }
174
175  for(int j = 0; j < nbFaces; j++) {
176  setFace(j, pf.at(j), order_u, order_v, npf.at(j).first, npf.at(j).second);
177  }
178 }
179
184 void axlShapeBSpline::setControlPoints(int nbpoints, double *points)
185 {
186  for(int i = 0; i < nbpoints;i++){
187  //d->points.append(new ControlPoint(i,points[3*i], points[3*i+1], points[3*i+2]));
188  d->points.append(new ControlPoint(i,points[3*i], points[3*i+1], 0));// same plane z = 0;
189  }
190 }
191
200 void axlShapeBSpline::setFace(int i, QVector<int> p, int order_u, int order_v, int nu, int nv)
201 {
202  axlAbstractSurfaceBSpline *surf = dynamic_cast<axlAbstractSurfaceBSpline *>(dtkAbstractDataFactory::instance()->create("goSurfaceBSpline"));
203  double *points = fillCoordinates(p);
204  double *knots_u = knots(nu,order_u);
205  double *knots_v = knots(nv,order_v);
206  surf->setSurface(nu,nv, order_u, order_v,3,knots_u, knots_v, points, false);
207  surf->setNumSamples_u(d->sample);
208  surf->setNumSamples_v(d->sample);
209  d->faces.append(new Face(i,nu,nv,p,surf));
210  updateFaceEdges(i);
211 }
212
218 void axlShapeBSpline::setEdge(int i,QVector<int> p, int order)
219 {
220  axlAbstractCurveBSpline *curv = dynamic_cast<axlAbstractCurveBSpline *>(dtkAbstractDataFactory::instance()->create("goCurveBSpline"));
221  double *points = fillCoordinates(p);
222  double *knot = knots(p.size(),order);
223  curv->setCurve(p.size(),order,3,knot, points, false);//rational=false, it is a bspline curve (non-rational one)
224  curv->setNumSamples(d->sample);
225  d->edges.append(new Edge(i,p,curv));
226  for(int pts =0; pts < p.size(); pts++ ){
227  d->points.at(p.at(pts))->addEdge(i);
228  }
229 }
230
236 void axlShapeBSpline::setFace(int i, QVector<int> p, axlAbstractSurfaceBSpline *surf)
237 {
238  surf->setNumSamples_u(d->sample);
239  surf->setNumSamples_v(d->sample);
240  d->faces.append(new Face(i,surf->countControlPoints_u(), surf->countControlPoints_v(),p,surf));
241  updateFaceEdges(i);
242  for(int pts =0; pts < p.size(); pts++ ){
243  d->points.at(p.at(pts))->addFace(i);
244  }
245 }
246
247
253 void axlShapeBSpline::setEdge(int i, QVector<int> p, axlAbstractCurveBSpline *curv)
254 {
255  curv->setNumSamples(d->sample);
256  d->edges.append(new Edge(i,p,curv));
257  for(int pts =0; pts < p.size(); pts++ ){
258  d->points.at(p.at(pts))->addEdge(i);
259  }
260 }
261
266 {
267  for(int j = 0; j < d->edges.at(i)->controlPointsIndices.size();j++){
268  int index = getPoint(d->edges.at(i)->controlPointsIndices.at(j))->edges.indexOf(i);
269  getPoint(d->edges.at(i)->controlPointsIndices.at(j))->edges.remove(index);
270  }
271
272  delete d->edges.at(i);
273  //d->edges.at(i) = NULL;
274  d->edges.remove(i);
275 }
276
277
282 //coefficients relatifs aux points de controle.
284 {
285  QVector<double> coord = d->points.at(index-1)->coordinates;
286  return axlPoint(coord.first(), coord.at(1),coord.last());
287 }
288
293 bool axlShapeBSpline::setCoef(int index, double *newCoordinate)
294 {
295  QVector<bool> interRes;
296
297  d->points.at(index-1)->setCoord(newCoordinate);
298
299  for(int i = 0; i < d->edges.size(); i++){
300  if(d->edges.at(i)->containsControlPoint(index-1)){
301  int ind = d->edges.at(i)->controlPointsIndices.indexOf(index-1);
302  interRes.append(d->edges.at(i)->support->setCoef(ind+1, newCoordinate));
303  }
304  }
305
306  for(int i = 0; i < d->faces.size(); i++){
307  if(d->faces.at(i)->containsControlPoint(index-1)){
308  int ind = d->faces.at(i)->controlPointsIndices.indexOf(index-1);
309  interRes.append(d->faces.at(i)->support->setCoef(ind+1, newCoordinate));
310  }
311  }
312  return !interRes.contains(false);
313 }
314
320 {
321  return d->points.size();
322 }
323
324 //double axlShapeBSpline::startParam_u(void)
325 //{
326 // DTK_DEFAULT_IMPLEMENTATION;
327
328 // return 0.;
329 //}
330 //double axlShapeBSpline::startParam_v(void)
331 //{
332 // DTK_DEFAULT_IMPLEMENTATION;
333
334 // return 0.;
335 //}
336
337 //double axlShapeBSpline::endParam_u(void)
338 //{
339 // DTK_DEFAULT_IMPLEMENTATION;
340 // return 1.;
341 //}
342 //double axlShapeBSpline::endParam_v(void)
343 //{
344 // DTK_DEFAULT_IMPLEMENTATION;
345 // return 1.;
346 //}
347 //int axlShapeBSpline::numSamples_u(void)
348 //{
349 // DTK_DEFAULT_IMPLEMENTATION;
350
351 // return 0;
352 //}
353 //int axlShapeBSpline::numSamples_v(void)
354 //{
355 // DTK_DEFAULT_IMPLEMENTATION;
356
357 // return 0;
358 //}
359
360 void axlShapeBSpline::eval(axlPoint *point, double u, double v) {
361  DTK_DEFAULT_IMPLEMENTATION;
362  DTK_UNUSED(point);
363  DTK_UNUSED(u);
364  DTK_UNUSED(v);
365 }
366
367 void axlShapeBSpline::normal(axlPoint *normal, double u, double v)
368 {
369  DTK_DEFAULT_IMPLEMENTATION;
370  DTK_UNUSED(normal);
371  DTK_UNUSED(u);
372  DTK_UNUSED(v);
373 }
374 double axlShapeBSpline::scalarValue(double u, double v)
375 {
376  return d->scalar_values.value(qMakePair<double, double>(u, v));
377 }
378
379 void axlShapeBSpline::setScalarValue(double u, double v, double value)
380 {
381  d->scalar_values.insert(qMakePair<double, double>(u, v), value);
382 }
383
385 {
386  DTK_DEFAULT_IMPLEMENTATION;
387
388  return 0;
389 }
390
392 {
393  DTK_DEFAULT_IMPLEMENTATION;
394  DTK_UNUSED(stripes);
395 }
396
398 {
399  DTK_DEFAULT_IMPLEMENTATION;
400  return 0;
401 }
402
404 {
405  DTK_DEFAULT_IMPLEMENTATION;
406  return 0;
407 }
408
410 {
411  return d->connect.value(i);
412 }
413
415
419  return !d->connect.isEmpty();
420 }
421
427  return d->faces.at(i)->support->startParam_u();
428 }
429
435  return d->faces.at(i)->support->startParam_v();
436 }
437
443  return d->faces.at(i)->support->endParam_u();
444 }
445
451  return d->faces.at(i)->support->endParam_v();
452 }
453
460 void axlShapeBSpline::eval(axlPoint *point, double u, double v,int i){
461  d->faces.at(i)->support->eval(point, u,v);
462  point->setCoordinates(point->x(), point->y(), point->z());
463 }
464
466
470  return (d->faces.size()>0);
471 }
472
474
478  return d->faces.size();
479 }
480
482
486  return d->edges.size();
487 }
488
494  return d->edges.at(i);
495 }
496
502  return d->faces.at(i);
503 }
504
510  return d->points.at(i);
511 }
512
518  return d->faces.at(i)->support->numSamples_u();
519 }
520
521
527  return d->faces.at(i)->support->numSamples_v();
528 }
529
530
534 void axlShapeBSpline::setNumSamples_u(int numSamples){
535  // axlAbstractSurfaceBSpline::setNumSamples_u(numSamples);
536
537  for(int i = 0;i < d->edges.size();i++){
538  d->edges.at(i)->support->setNumSamples(numSamples);
539  }
540
541  for(int i = 0;i < d->faces.size();i++){
542  d->faces.at(i)->support->setNumSamples_u(numSamples);
543  }
544 }
545
549 void axlShapeBSpline::setNumSamples_v(int numSamples) {
550  for(int i = 0; i < d->faces.size(); i++){
551  d->faces.at(i)->support->setNumSamples_v(numSamples);
552  }
553 }
554
561 void axlShapeBSpline::normal(axlPoint *currentNormal ,double paramCourant_u, double paramCourant_v,int indice){
562  d->faces.at(indice)->support->normal(currentNormal,paramCourant_u,paramCourant_v);
563 }
564
565
570
571  if(!d->faces.at(numFace)->edgesIndices.isEmpty())
572  d->faces.at(numFace)->edgesIndices.clear();
573
574  QVector<int>e;
575  QVector<int> p = d->faces.at(numFace)->controlPointsIndices;
576
577  for(int ip =0; ip < p.size(); ip++){
578  if(d->points.at(p.at(ip))->edges.size() == 1 ){
579  if(!e.contains(d->points.at(p.at(ip))->edges.first())){
580  e.push_back(d->points.at(p.at(ip))->edges.first());
581  }
582  }
583  }
584  d->faces.at(numFace)->edgesIndices = e;
585
586 }
587
588 // PRIVATE
589
594 double *axlShapeBSpline::fillCoordinates(QVector<int> p){
595  double *point = new double[3*p.size()];
596  int ind = 0;
597
598  for(int i= 0; i < p.size();i++){
599  point[3*ind] = d->points.at(p.at(i))->coordinates.first();
600  point[3*ind+1] = d->points.at(p.at(i))->coordinates.at(1);
601  point[3*ind+2] = d->points.at(p.at(i))->coordinates.last();
602
603  ind++;
604  }
605
606  return point;
607 }
608
609
615 double *axlShapeBSpline::knots(int pointsCount, int order)
616 {
617  double *knots = new double[pointsCount + order];
618  int knot_number = 1 ;
619
620
621
622  for(int i = 0 ; i < order ; i++ )
623  knots[i] = 0.0 ;
624
625  for(int i = order ; i < pointsCount ; i++)
626  knots[i] = knot_number++ ;
627
628  for(int i = pointsCount ; i < pointsCount + order ; i++)
629  knots[i] = knot_number ;
630
631
632
633  // for(int i = 0 ; i < pointsCount + order ; i++)
634  // knots[i] = i ;
635
636
637  return knots;
638 }
639
646 bool axlShapeBSpline::isContained(QList<axlPoint > list, axlPoint p, QVector<int>& pf){
647  bool res = false;
648
649  for(int i = 0;i <list.size(); i++){
650  axlPoint listP = list.at(i);
651  if(listP.x() == p.x() && listP.y()==p.y() && listP.z()==p.z()){
652  pf.append(i);
653  res = true;
654  }
655  }
656
657  if(!res){
658  int s = pf.size();
659  pf.append(s);
660  }
661
662
663  return res;
664 }
665
666
671  ControlPoint *control = new ControlPoint(d->points.size(),point->x(),point->y(),point->z());
672  d->points.append(control);
673 }
674
675
681 void axlShapeBSpline::insert_point(double x, double y, double z){
682  ControlPoint *control = new ControlPoint(d->points.size(),x,y,z);
683  d->points.append(control);
684 }
685
686
691  d->edges.append(edge);
692 }
693
694
699  d->faces.append(face);
700 }
701
702 dtkAbstractData *createaxlShapeBSpline(void){
703  return new axlShapeBSpline;
704 }
705
706 // /////////////////////////////////////////////////////////////////
707 // axlDataDynamic documentation
708 // /////////////////////////////////////////////////////////////////
709
void createSurfaceFromBSplineDataSet(QList< axlAbstractSurfaceBSpline * > dataSet)
Create an axlShapeBSpline from a set of axlAbstractSurfaceBSpline.
Class axlPoint defines 3D points.
Definition: axlPoint.h:34
double scalarValue(double u, double v)
axlPoint getCoef(int index) const
Get a coefficient of the surface.
int order_u() const
Return the order of the surface for the u parameter.
Edge * getEdge(int i)
Return edge.
double endParam_u(int i)
Return the last u parameter value of a face.
QList< int > getControlPointConnection(int i)
int countFaces(void)
Return how many faces.
int countControlPoints_v(void) const
void insert_point(double x, double y, double z)
Add a point to the control point set of the surface.
int order_v() const
Return the order of the surface for the v parameter.
void setEdge(int i, QVector< int > p, int order)
Add or modify an edge to the Surface.
int countControlPoints_u(void) const
virtual void setNumSamples_v(int numSamples)
bool setCoef(int index, double *newCoordinate)
Modified a coefficient of the surface.
double startParam_u(int i)
Return the first u parameter value of a face.
int numSamples_u(int numCell)
Mesh subdision on the u-direction.
void setNumSamples_u(int numSamples)
Modify mesh subdision on the v-direction. Same for all faces.
Face * getFace(int i)
Return face.
double endParam_v(int i)
Return the last v parameter value of a face.
static bool registered(void)
Emit a signal edgesSeleted.
virtual void setSurface(int pointsCount_u, int pointsCount_v, int order_u, int order_v, int dimension, double *knots_u, double *knots_v, double *points, bool rational)
axlAbstractSurfaceBSpline::setSurface
void setStripes(int stripes)
dtkAbstractData * createaxlShapeBSpline(void)
void eval(axlPoint *point, double u, double v)
virtual void setNumSamples(int numSamples)
void removeEdge(int i)
Remove an edge.
virtual int countControlPoints_u(void) const
virtual int countControlPoints_v(void) const
void insert_edge(Edge *edge)
Add an edge to the surface.
virtual void setCurve(int pointsCount, int order, int dimension, double *knots, double *points, bool rational)
int countBoundaryEdges() const
Return how many edges.
ControlPoint * getPoint(int i)
Return control point.
double startParam_v(int i)
void setSurface(int order_u, int order_v, int nbpoints, int nbEdges, int nbFaces, double *points, QVector< QVector< int > > pe, QVector< QVector< int > >pf, QVector< QPair< int, int > >npf)
Create a surface.
bool hasFaces(void)
Return whether the surface have several faces.
double y
Definition: axlPoint.h:37
QString description(void) const
Return a description of the surface.
int countControlPoints() const
double z
Definition: axlPoint.h:38
Class axlShapeBSpline defines a set of boundary curves (Edges) and bspline surface patches (Face)...
void setFace(int i, QVector< int > p, int order_u, int order_v, int nu, int nv)
Add or modify a face to the Surface.
void setControlPoints(int nbpoints, double *points)
Add control points to the Surface. All points should be on the plane z =0;.
int numSamples_v(int numCell)
Mesh subdision on the v-direction.
double x
bool connectionsAreDefined(void)
Return true if control points connections were defined by developers. False if there are default conn...
void setCoordinates(double x, double y, double z)
Change coordinates of this point.
Definition: axlPoint.cpp:370
void normal(axlPoint *normal, double u, double v)
void insert_face(Face *face)
Add a face to the surface.
virtual void setNumSamples_u(int numSamples)
void updateFaceEdges(int numFace)
Update indices list of the face edges.
Class axlAbstractData defines an API for all type of axel data.
void setScalarValue(double u, double v, double value)
QString identifier(void) const
Return the "axlShapeBSpline" identifier.Useful for data factory.
