#include <axlAbstractCurveBSpline.h>
 | Public Types | |
| typedef QMap< double, axlPoint > | Sample |
| Signals | |
| void | updated (void) |
| void | samplingChanged () |
| void | indexSelected (int) |
|  Signals inherited from axlAbstractData | |
| void | modifiedGeometry (void) |
| void | modifiedStructure (void) |
| void | modifiedField (void) |
| void | modifiedProperty (void) |
| Public Member Functions | |
| axlAbstractCurveBSpline (void) | |
| virtual | ~axlAbstractCurveBSpline (void) |
| virtual int | countControlPoints (void) const |
| virtual int | knotVectorSize (void) const |
| virtual int | order (void) const |
| virtual int | numCoefs () const |
| virtual bool | rational (void) const |
| virtual double | startParam (void) |
| virtual double | endParam (void) |
| virtual void | setCurve (int pointsCount, int order, int dimension, double *knots, double *points, bool rational) |
| virtual axlPoint | closestPoint (const axlPoint &pt) |
| virtual double | closestParameter (const axlPoint &pt) |
| virtual Sample | sampling (int n) |
| virtual void | insertKnot (double k) |
| virtual void | removeKnot (double k) |
| virtual axlPoint | getCoef (int n) const |
| virtual bool | setCoef (int n, double *controlPoint) |
| virtual double | getKnot (int n) const |
| virtual QString | printCoeffs (bool print) const |
| virtual QString | printKnotsVector (bool print) const |
| virtual double | getWeight (int n) const |
| virtual void | updateRcoeff () |
| virtual QString | description (void) const |
| virtual bool | connectionsAreDefined (void) |
| Return true if control points connections were defined by developers. False if there are default connections visualization.  More... | |
| virtual QList< int > | getControlPointConnection (int i) |
| The list returned contains all indices of coefficients that are still to be connected to the ith coefficient.  More... | |
| virtual void | defineControlPointConnection (int i, int j) |
| Define connection between the ith and the jth coefficient.  More... | |
| virtual void | resetControlPointConnections (void) |
| Removes all control point connections.  More... | |
| QVariantList | convertDataToQVariant (void) const |
| Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData.  More... | |
| int | convertQVariantToData (const QVariantList &data) |
| Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0.  More... | |
| virtual void | selectIndex (int i) |
|  Public Member Functions inherited from axlAbstractCurveParametric | |
| axlAbstractCurveParametric (void) | |
| virtual | ~axlAbstractCurveParametric (void) |
| virtual axlPoint | eval (double u) |
| virtual void | eval (axlPoint *point, double u) |
| virtual axlMesh | eval (double u, int derivs, bool from_right=true) |
| double | parameterOf (const axlPoint &p) |
| virtual double | length (double tolerance) |
| virtual int | numSamples (void) |
| virtual void | setNumSamples (int numSamples) |
| const int & | samples (void) const |
|  Public Member Functions inherited from axlAbstractCurve | |
| axlAbstractCurve (void) | |
| virtual | ~axlAbstractCurve (void) |
| virtual int | dimension (void) const |
| virtual bool | isPlanar (void) const |
| virtual void * | curve (void) |
|  Public Member Functions inherited from axlAbstractData | |
| axlAbstractData (axlAbstractData *parent=NULL) | |
| axlAbstractData (const axlAbstractData &data) | |
| virtual | ~axlAbstractData (void) |
| const QColor & | color (void) const |
| const double & | opacity (void) const |
| const double & | size (void) const |
| const QString & | shader (void) const |
| const bool & | editable (void) |
| const bool & | updateView (void) |
| void | setColor (double r, double g, double b) |
| void | addField (axlAbstractField *field) |
| Add a field to the field list of the object.  More... | |
| bool | updateFieldList (QString nameField) |
| Check if a field with the same name is already applied on the object.  More... | |
| QString | changeFieldName (QString fieldName) |
| axlMesh * | mesh (void) |
| Return the mesh of that object is computed.  More... | |
| void | setMesh (axlMesh *mesh) |
| Set a corresponding mesh for that object.  More... | |
| void | setUpdateView (bool updateView) |
| QList< axlAbstractField * > | fields (void) |
| Additional Inherited Members | |
|  Public Slots inherited from axlAbstractCurveParametric | |
| virtual void | onDirectChanged (bool direct) |
| void | setSamples (const int &color) |
|  Public Slots inherited from axlAbstractData | |
| void | touchGeometry (void) |
| void | touchProperty (void) |
| void | touchStructure (void) |
| virtual void | touchField (void) |
| void | setColor (const QColor &color) |
| void | setOpacity (const double &opacity) |
| void | setSize (const double &size) |
| void | setShader (const QString &shader) |
| void | setEditable (bool edit) |
|  Properties inherited from axlAbstractCurveParametric | |
| int | samples |
|  Properties inherited from axlAbstractData | |
| QColor | color |
| double | opacity |
| double | size |
| QString | shader |
Definition at line 30 of file axlAbstractCurveBSpline.h.
| typedef QMap<double, axlPoint> axlAbstractCurveBSpline::Sample |
Definition at line 36 of file axlAbstractCurveBSpline.h.
| axlAbstractCurveBSpline::axlAbstractCurveBSpline | ( | void | ) |
Definition at line 37 of file axlAbstractCurveBSpline.cpp.
 | virtual |
Definition at line 42 of file axlAbstractCurveBSpline.cpp.
 | virtual |
Definition at line 110 of file axlAbstractCurveBSpline.cpp.
Definition at line 103 of file axlAbstractCurveBSpline.cpp.
 | virtual |
Definition at line 195 of file axlAbstractCurveBSpline.cpp.
 | virtual |
Reimplemented from axlAbstractData.
Definition at line 243 of file axlAbstractCurveBSpline.cpp.
 | virtual |
Definition at line 265 of file axlAbstractCurveBSpline.cpp.
 | virtual |
Definition at line 49 of file axlAbstractCurveBSpline.cpp.
 | virtual |
Definition at line 221 of file axlAbstractCurveBSpline.cpp.
 | virtual |
Definition at line 184 of file axlAbstractCurveBSpline.cpp.
 | virtual |
Reimplemented from axlAbstractCurveParametric.
Definition at line 91 of file axlAbstractCurveBSpline.cpp.
 | virtual |
Definition at line 125 of file axlAbstractCurveBSpline.cpp.
 | virtual |
Definition at line 212 of file axlAbstractCurveBSpline.cpp.
 | virtual |
Definition at line 153 of file axlAbstractCurveBSpline.cpp.
 | virtual |
Definition at line 140 of file axlAbstractCurveBSpline.cpp.
 | signal |
 | virtual |
Definition at line 160 of file axlAbstractCurveBSpline.cpp.
 | virtual |
Definition at line 56 of file axlAbstractCurveBSpline.cpp.
 | virtual |
Definition at line 70 of file axlAbstractCurveBSpline.cpp.
 | virtual |
Definition at line 63 of file axlAbstractCurveBSpline.cpp.
 | virtual |
Definition at line 170 of file axlAbstractCurveBSpline.cpp.
 | virtual |
Definition at line 177 of file axlAbstractCurveBSpline.cpp.
 | virtual |
Definition at line 78 of file axlAbstractCurveBSpline.cpp.
 | virtual |
Definition at line 165 of file axlAbstractCurveBSpline.cpp.
 | virtual |
Definition at line 203 of file axlAbstractCurveBSpline.cpp.
 | virtual |
Definition at line 118 of file axlAbstractCurveBSpline.cpp.
 | signal |
 | inlinevirtual |
Definition at line 87 of file axlAbstractCurveBSpline.h.
 | virtual |
Definition at line 132 of file axlAbstractCurveBSpline.cpp.
 | virtual |
Definition at line 98 of file axlAbstractCurveBSpline.cpp.
 | virtual |
Definition at line 84 of file axlAbstractCurveBSpline.cpp.
 | signal |
 | virtual |
Definition at line 148 of file axlAbstractCurveBSpline.cpp.
