Developer documentation | Axl-2.5.1
axlAbstractFieldParametricCurve.cpp
Go to the documentation of this file.
1 /* axlAbstractFieldParametricCurve.cpp ---
2  *
3  * Author: Anais Ducoffe
4  * Copyright (C) 2013 - Anais Ducoffe, Inria.
5  */
6
7 /* Commentary:
8  *
9  */
10
11 /* Change log:
12  *
13  */
14 #include <sstream>
15
17 #include "axlAbstractProcess.h"
18
19 #include <dtkCoreSupport/dtkGlobal.h>
20
21 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
22 #include <dtkCoreSupport/dtkAbstractProcessFactory.h>
23
24 class axlAbstractFieldParametricCurvePrivate
25 {
26 public:
27 };
28
29 // /////////////////////////////////////////////////////////////////
30 // axlAbstractFieldParametricCurve implementation
31 // /////////////////////////////////////////////////////////////////
32
34
38 {
39 }
40
41
42
44
48 {
49  delete d;
50
51  d = NULL;
52 }
53
54
56
60
61  DTK_DEFAULT_IMPLEMENTATION;
62 }
63
65
69  DTK_DEFAULT_IMPLEMENTATION;
70  return 0;
71 }
72
74
77 double axlAbstractFieldParametricCurve::scalar(double u, double v, double w)
78 {
79  if(!(this->kind() == Scalar)) {
80  qDebug() << "Getting scalar value on non scalar field.";
81  return 0;
82  }
83  return 0;
84 }
85
87
90 double *axlAbstractFieldParametricCurve::vector(double u, double v, double w)
91 {
92  if(!(this->kind() == Vector)) {
93  qDebug() << "Getting vector value on non vector field.";
94  return NULL;
95  }
96  return NULL;
97 }
98
100
103 double *axlAbstractFieldParametricCurve::tensor(double u, double v, double w)
104 {
105  if(!(this->kind() == Tensor)) {
106  qDebug() << "Getting tensor value on non tensor field.";
107  return NULL;
108  }
109
110  return NULL;
111 }
112
113
115
119
120  DTK_DEFAULT_IMPLEMENTATION;
121  return 0;
122 }
123
124
126
130
131  DTK_DEFAULT_IMPLEMENTATION;
132  return 0;
133 }
134
135
136
138
142
143  DTK_DEFAULT_IMPLEMENTATION;
144  return 0;
145 }
146
147
149
153
154  DTK_DEFAULT_IMPLEMENTATION;
155 }
156
157
159
163  return NULL;
164 }
165
167
172 {
173  DTK_DEFAULT_IMPLEMENTATION;
174  return QString();
175
176 }
177
178
180
185 {
186  DTK_DEFAULT_IMPLEMENTATION;
187  return QString();
188
189 }
190
193
197 {
198  emit updated();
199 }
200
201 // /////////////////////////////////////////////////////////////////
202 // axlField documentation
203 // /////////////////////////////////////////////////////////////////
204
211 // /////////////////////////////////////////////////////////////////
212 // Type instanciation
213 // /////////////////////////////////////////////////////////////////
214
216 {
218 }
219
220
Class axlAbstractFieldParametric defines an API for parametric field.
virtual double scalar(double u, double v=0, double w=0)
Returns the value of the parametric field at the parameters values in input.
virtual void setFunction(axlAbstractData *data)
Returns the description of the field.
virtual double * tensor(double u, double v=0, double w=0)
Returns the value of the spatial field at the coordinates point entered.
virtual void setCurve(axlAbstractData *Curve)
Sets the support Curve of the field.
virtual axlAbstractData * getFunction(void)
Class axlAbstractFieldParametricCurve defines an API for parametric field.
virtual int size(void)
Returns number of parameters on which the field is evaluated.
virtual Kind kind(void)
dtkAbstractData * createaxlAbstractFieldParametricCurve(void)
virtual QString identifier(void) const
virtual ~axlAbstractFieldParametricCurve(void)
Destroys a parametric field.
virtual double end_u(void)
Returns the last v-value parameter.
virtual double start_u(void)
Returns the first u-value parameter.
Class axlAbstractData defines an API for all type of axel data.
virtual double numbersample_u(void)
Returns the number of u-parameters.
virtual QString description(void) const
virtual double * vector(double u, double v=0, double w=0)
Returns the value of the parametric field evaluated at the parameters in input.
