Developer documentation | Axl-2.5.1
axlAbstractFieldParametricCurve.h
Go to the documentation of this file.
1 /* axlAbstractFieldParametricCurve.h ---
2  *
3  * Author: Anais Ducoffe
4  * Copyright (C) 2013 - Anais Ducoffe, Inria.
5  */
6
7 /* Commentary:
8  *
9  */
10
11 /* Change log:
12  *
13  */
14 #include "axlCoreExport.h"
15 #ifndef AXLABSTRACTFIELDPARAMETRICCURVE_H
16 #define AXLABSTRACTFIELDPARAMETRICCURVE_H
17
19
20 class axlAbstractFieldParametricCurvePrivate;
21 class axlAbstractData;
22
24 {
25  Q_OBJECT
26
27 public:
29  virtual ~axlAbstractFieldParametricCurve(void);
30
31  virtual void setCurve(axlAbstractData *Curve);
32
33  virtual int size(void);
34
35  virtual double scalar(double u, double v = 0, double w = 0);
36  virtual double *vector(double u, double v = 0, double w = 0);
37  virtual double *tensor(double u, double v = 0, double w = 0);
38
39  virtual double start_u(void);
40
41  virtual double end_u(void);
42
43  virtual double numbersample_u(void);
44
45  virtual void setFunction(axlAbstractData *data);
46  virtual axlAbstractData *getFunction(void);
47
48  virtual QString description(void) const;
49  virtual QString identifier(void) const;
50
51
52 signals :
53  void updated(void);
54
55
56 public slots:
57  virtual void update(void);
58
59
60 private:
61  axlAbstractFieldParametricCurvePrivate *d;
62 };
63
64 dtkAbstractData *createaxlAbstractFieldParametricCurve(void);
65
66
67 #endif // AXLABSTRACTFIELDPARAMETRICCURVE_H
Returns the description of the field.
Class axlAbstractFieldParametric defines an API for parametric field.
Returns number of parameters on which the field is evaluated.
Class axlAbstractFieldParametricCurve defines an API for parametric field.
virtual double * tensor(double u, double v=0, double w=0)
Returns the value of the spatial field at the coordinates point entered.
virtual axlAbstractData * getFunction(void)
virtual double * vector(double u, double v=0, double w=0)
Returns the value of the parametric field evaluated at the parameters in input.
virtual double scalar(double u, double v=0, double w=0)
Returns the value of the parametric field at the parameters values in input.
#define AXLCORE_EXPORT
Class axlAbstractData defines an API for all type of axel data.
dtkAbstractData * createaxlAbstractFieldParametricCurve(void)
