26 #include <dtkCoreSupport/dtkAbstractData.h>
   27 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
   43     return "axlCircleArcWriter";
   47     return "axlCircleArcWriter";
   51     return QStringList() <<
"axlCircleArc";
   55     return dtkAbstractDataFactory::instance()->registerDataWriterType(
"axlCircleArcWriter", QStringList(),
createaxlCircleArcWriter);
   66     return !this->
accept(data);
   75     QDomElement arcElement = doc->createElement(
"arc");
   76     arcElement.setAttribute(
"name", arc->name());
   79     arcElement.setAttribute(
"size", QString::number(arc->
size()));
   82     QColor qcolor = arc->
color();
   84     QTextStream(&color) << QString::number(qcolor.red()) <<
   85                         << QString::number(qcolor.green()) <<
   86                         << QString::number(qcolor.blue()) <<
   87                         << QString::number(arc->
opacity());
   88     arcElement.setAttribute(
"color", color);
   91     QString shader = arc->
shader();
   92     QFileInfo shaderFileInfo(shader);
   93     arcElement.setAttribute(
"shader", shaderFileInfo.fileName());
   97     QDomElement point1Element = doc->createElement(
"point1");
   99     QTextStream(&point1Str) << QString::number(arc->
point1().
x()) <<
  100                             << QString::number(arc->
point1().
y()) <<
  101                             << QString::number(arc->
point1().
z());
  102     QDomText point1DomText = doc->createTextNode(point1Str);
  103     point1Element.appendChild(point1DomText);
  105     arcElement.appendChild(point1Element);
  108     QDomElement Point2Element = doc->createElement(
"point2");
  110     QTextStream(&Point2Str) << QString::number(arc->
point2().
x()) <<
  111                             << QString::number(arc->
point2().
y()) <<
  112                             << QString::number(arc->
point2().
z());
  113     QDomText Point2DomText = doc->createTextNode(Point2Str);
  114     Point2Element.appendChild(Point2DomText);
  116     arcElement.appendChild(Point2Element);
  119     QDomElement centerElement = doc->createElement(
"center");
  121     QTextStream(¢erStr) << QString::number(arc->
center().
x()) <<
  122                             << QString::number(arc->
center().
y()) <<
  123                             << QString::number(arc->
center().
z());
  124     QDomText centerDomText = doc->createTextNode(centerStr);
  125     centerElement.appendChild(centerDomText);
  127     arcElement.appendChild(centerElement);
  130     QDomElement normalElement = doc->createElement(
"normal");
  132     QTextStream(&normalStr) << QString::number(arc->
normal().
x()) <<
  133                             << QString::number(arc->
normal().
y()) <<
  134                             << QString::number(arc->
normal().
z());
  135     QDomText normalDomText = doc->createTextNode(normalStr);
  136     normalElement.appendChild(normalDomText);
  138     arcElement.appendChild(normalElement);
  141     QDomElement cCWElement = doc->createElement(
"ccw");
  143     QTextStream(&cCWStr) << arc->
isDirect();
  144     QDomText cCWDomText = doc->createTextNode(cCWStr);
  145     cCWElement.appendChild(cCWDomText);
  147     arcElement.appendChild(cCWElement);
  151     if(!arc->
fields().isEmpty()){
  154             QDomElement fieldElement = field_writer->
write(doc, field);
  155             arcElement.appendChild(fieldElement);
  162 QDomElement axlCircleArcWriter::elementByWriter(
axlAbstractDataWriter *axl_writer, QDomDocument *doc, dtkAbstractData *data) {
  167     if(!axl_writer->
accept(data))
  170     element = axl_writer->
write(doc, data);
bool isDirect(void) const
axlPoint point1(void) const
bool accept(dtkAbstractData *data)
virtual bool accept(dtkAbstractData *data)=0
QStringList handled(void) const
QDomElement write(QDomDocument *doc, dtkAbstractData *data)
QString description(void) const
static axlFieldWritersFactory * instance(void)
axlPoint center(void) const
QString identifier(void) const
virtual QString identifier(void) const
dtkAbstractDataWriter * createaxlCircleArcWriter(void)
dtkAbstractDataWriter * create(const QString &interface_name)
axlPoint point2(void) const
bool reject(dtkAbstractData *data)
Class axlAbstractField defines an API for arrays of numeric data.
virtual ~axlCircleArcWriter(void)
static bool registered(void)
axlPoint normal(void) const
QList< axlAbstractField * > fields(void)
virtual QDomElement write(QDomDocument *doc, dtkAbstractData *data)=0
