4 #include <dtkCoreSupport/dtkGlobal.h>
    6 class axlCompositeCurvePrivate
    9     QList<axlAbstractCurve *> data;
   10     QPair<axlPoint *, axlPoint *> ends;
   42         return d->data.value(
id);
   49     return d->data.size();
   55         d->data.append(data_curves);
   62         for(
int i = 0; i<data_curve.size(); i++)
   73         d->data.insert(id_want_inserted,curve);
   96        d->data.append(curve);
  104         d->ends.first =
new axlPoint(startPoint);
  105         d->ends.second =
new axlPoint(endPoint);
  112         d->ends.first = startPoint;
  113         d->ends.second = endPoint;
  119     return d->ends.first;
  123     return d->ends.second;
  128      d->data.removeLast();
  134       d->data.removeAt(id_want_remove);
  139     QString s =
"axlCompositeCurve";
  142         for(
int i = 0; i <d->data.size(); i++)
  144             s.append(d->data.at(i)->description() +
"\n");
  149         s.append(d->ends.first->description() +
"\n");
  150         s.append(d->ends.second->description());
  157     return "axlCompositeCurve";
  162     d->tag = other.d->tag;
  166        d->data.append(other.d->data);
  170         d->ends = other.d->ends;
dtkAbstractData * createaxlCompositeCurve(void)
Class axlPoint defines 3D points.
void remove_curve_at_id(int id_want_remove)
axlPoint * get_start_point()
axlCompositeCurve & operator=(const axlCompositeCurve &other)
int count_curve(void) const
void append_point(const axlPoint &startPoint, const axlPoint &endPoint)
axlAbstractCurve * get_pt_curve_at_id(int id) const
void insert_curve(axlAbstractCurve *curve, int id_want_inserted)
void insert_list_curves(const QList< axlAbstractCurve > &data_curves)
axlPoint * get_end_point()
Generic interface for parametric curve.
void append_curve(const axlAbstractCurve &curve)
axlCompositeCurve(QObject *parent=0)
virtual QString description(void) const
virtual QString identifier(void) const
