9 #include <dtkCoreSupport/dtkAbstractData.h>
   10 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
   29     return "axlCompositeCurveReader";
   33     return "axlCompositeCurveReader";
   37     return QStringList() <<
"axlCompositeCurve";
   45     QDomElement element = node.toElement();
   47     if (element.tagName() !=
"composite_curve")
   54     return !this->
accept(node);
   59     QDomElement element = node.toElement();
   64     QString name = element.attribute(
"name");
   65     if (!name.isEmpty()) {
   66         comCur->setObjectName(name);
   70     QString color = element.attribute(
"color");
   71     if (!color.isEmpty()) {
   72         QStringList colorList = color.split(
   73         if (colorList.size() > 2)
   74             comCur->
setColor(QColor(colorList.at(0).toInt(), colorList.at(1).toInt(), colorList.at(2).toInt()));
   75         if (colorList.size() == 4)
   80     QString shader = element.attribute(
"shader");
   82     if (!shader.isEmpty()) {
   84         dirShader =
":axlShader/shader/" + shader;
   85         if (!QFile::exists(dirShader)) {
   86             QSettings settings(
"inria",
"dtk");
   88             settings.beginGroup(
"shader");
   89             dirShader = settings.value(
"path", defaultPath).toString();
   90             dirShader.append(
"/" + shader);
   96     QString size = element.attribute(
"size");
   98         comCur->
setSize(size.toFloat());
  101     QList<axlAbstractCurve *> curveList;
  102     QDomNodeList curvelistElement = element.elementsByTagName(
"curve");
  103     for(
int i = 0; i<curvelistElement.size(); i++)
  105         QDomElement curveElement = curvelistElement.at(i).toElement();
  106         QString curveReaderTag = curveElement.attribute(
"type")+
"Reader";
  109         curveList.append(curve);
void setShader(const QString &shader)
dtkAbstractDataReader * createaxlCompositeCurveReader(void)
void insert_list_curves(const QList< axlAbstractCurve > &data_curves)
axlAbstractData * read(const QDomNode &node)
virtual axlAbstractData * read(const QDomNode &node)=0
static bool registered(void)
bool reject(const QDomNode &node)
QString identifier(void) const
void setOpacity(const double &opacity)
QString description(void) const
void setSize(const double &size)
void setColor(double r, double g, double b)
QStringList handled(void) const
bool accept(const QDomNode &node)
Class axlAbstractData defines an API for all type of axel data.
virtual ~axlCompositeCurveReader(void)
