24 #include "axlCoreExport.h"
   31 class axlCylinderPrivate;
   36     Q_PROPERTY(
axlPoint point1 READ firstPoint WRITE touchFirstPoint);
   37     Q_PROPERTY(
axlPoint point2 READ secondPoint WRITE touchSecondPoint);
   38     Q_PROPERTY(
double radius READ radius WRITE touchRadius);
   47     virtual QString description(
void)
const;
   48     virtual QString identifier(
void)
const;
   52     double    radius(
void)
const;
   53     double    length(
void)
const;
   58     void setRadius(
double radius);
   59     void setLength(
double length);
   60     void setFirstPoint(
double *p1);
   61     void setSecondPoint(
double *p2);
   65     void touchRadius(
double radius);
   77     void onFirstPointChanged(
axlPoint *p1);
   78     void onSecondPointChanged(
axlPoint *p2);
   79     void onRadiusChanged(
double radius);
   82     axlCylinderPrivate *d;
   98 #endif // AXLCYLINDER_H
Class axlPoint defines 3D points.
Q_DECLARE_METATYPE(axlAbstractData)
QDebug operator<<(QDebug dbg, axlCylinder point)
Class axlCylinder defines 3D cylinders.
virtual int convertQVariantToData(const QVariantList &data)
Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was suc...
virtual QVariantList convertDataToQVariant(void) const
Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData...
dtkAbstractData * createaxlCylinder(void)
Class axlAbstractData defines an API for all type of axel data.
