Developer documentation | Axl-2.5.1
axlFieldParametricVolumeReader.cpp
Go to the documentation of this file.
1 /* axlFieldParametricVolumeReader.cpp ---
2  *
3  * Author: Anais Ducoffe
4  * Copyright (C) 2013 - Anais Ducoffe, Inria.
5  */
6
7 /* Commentary:
8  *
9  */
10
11 /* Change log:
12  *
13  */
14
16 #include "axlReader.h"
17
20
21 #include <dtkCoreSupport/dtkAbstractData.h>
22 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
23 #include <dtkCoreSupport/dtkAbstractProcessFactory.h>
24
25 // /////////////////////////////////////////////////////////////////
26 // axlFieldParametricVolumeReader
27 // /////////////////////////////////////////////////////////////////
28
30 {
31  this->setObjectName(this->description());
32 }
33
35 {
36
37 }
38
40 {
41  return "axlFieldParametricVolumeReader";
42 }
43
45 {
46  return "axlFieldParametricVolumeReader";
47 }
48
50 {
51  return QStringList() << "axlFieldParametricVolume";
52 }
53
55 {
56  return dtkAbstractDataFactory::instance()->registerDataReaderType("axlFieldParametricVolumeReader", QStringList(), createaxlFieldParametricVolumeReader);
57 }
58
59 bool axlFieldParametricVolumeReader::accept(const QDomNode& node)
60 {
61  QDomElement element = node.toElement();
62
63  if(element.tagName() != "field")
64  return false;
65
66  return true;
67 }
68
69 bool axlFieldParametricVolumeReader::reject(const QDomNode& node)
70 {
71  return !this->accept(node);
72 }
73
74
75 //read only one special field :axlFieldParametricVolume.
77 {
78
79  dtkWarn() << Q_FUNC_INFO << "enter";
80  QDomElement element = node.toElement();
81  axlFieldParametricVolume *field = NULL;
82
83  // field type : the type corresponds to the identifier, use factory to initialize field.
84  QString type = element.attribute("type");
85  if(!type.isEmpty())
86  {
87  field = dynamic_cast<axlFieldParametricVolume *>(dtkAbstractDataFactory::instance()->create(type));
88  }
89
91  QString name = element.attribute("name");
92  if(!name.isEmpty())
93  {
94  field->setObjectName(name);
95  }
96
98  QString typeField = element.attribute("valueType");
99  if(!typeField.isEmpty()){
100  if(typeField == "int"){
102  }else if(typeField == "float"){
104  }else{
106  }
107  }
108
109
111  QString support = element.attribute("support");
112  if(support == "point"){
114  }else if(support == "cell"){
116  }else{
118  }
119
121  QString kind = element.attribute("kind");
122  if(kind == "scalar"){
124  }else if(kind == "vector"){
126  }else{
128  }
129
130
132  QDomNodeList listFunction = element.elementsByTagName("volume");
133  QDomElement functionDescription = listFunction.at(0).toElement();
134
135  dtkAbstractData *data = NULL;
136  // test for all reader registered in the factory
137  foreach(QString reader, dtkAbstractDataFactory::instance()->readers()) {
138  axlAbstractDataReader *axl_reader = dynamic_cast<axlAbstractDataReader *>(dtkAbstractDataFactory::instance()->reader(reader));
139  data = this->dataByReader(axl_reader, functionDescription);
140  delete axl_reader;
141
142  if(data){
143  axlAbstractData *function = dynamic_cast<axlAbstractData *>(data);
144  field->setFunction(function);
145  }
146  }
147
148
149  field->update();
150  return field;
151
152
153 }
154
155 dtkAbstractData *axlFieldParametricVolumeReader::dataByReader(axlAbstractDataReader *axl_reader, const QDomNode& node)
156 {
157  if(!axl_reader)
158  return NULL;
159
160  if(!axl_reader->accept(node))
161  return NULL;
162
163  axl_reader->dtkAbstractDataReader::read(this->file());
164
165  if(dtkAbstractData *data = axl_reader->read(node))
166  return data;
167
168
169  return NULL;
170 }
171
172
173
174 dtkAbstractDataReader *createaxlFieldParametricVolumeReader(void)
175 {
177 }
178
179
dtkAbstractDataReader * createaxlFieldParametricVolumeReader(void)
void setFunction(axlAbstractData *data)
Sets the Bspline function which determines the values of the parametric field.
virtual axlAbstractData * read(const QDomNode &node)=0
virtual void setType(Type type)
Sets the type of the field which can be either int, float or double.
virtual void setSupport(Support support)
virtual bool accept(const QDomNode &node)=0
Class axlFieldParametricVolume defines an API for field which owns a BSpline Volume.
dtkAbstractData * dataByReader(axlAbstractDataReader *axl_reader, const QDomNode &node)
virtual void setKind(Kind kind)
Sets the kind of the field which can be either scalar, vector or tensor.
Class axlAbstractData defines an API for all type of axel data.
