29 #include <dtkCoreSupport/dtkAbstractData.h>
   30 #include <dtkCoreSupport/dtkGlobal>
   37 class axlInspectorPrivate
   52     Q_INIT_RESOURCE(axlGui);
   53     Q_INIT_RESOURCE(axelShader);
   58     d->inspector_object_manager->setController(d->controller);
   61     d->inspector_tool_manager->setController(d->controller);
   69     connect(d->inspector_tool_manager, SIGNAL(
update()),
this, SIGNAL(
update()));
   71     connect(d->inspector_tool_manager, SIGNAL(
dataChanged(dtkAbstractData *)),
this, SIGNAL(
dataChanged(dtkAbstractData *)));
   75     connect(d->inspector_tool_manager, SIGNAL(dataSetToRemove(QList<dtkAbstractData*>)), d->inspector_object_manager, SLOT(onDataRemoved(QList<dtkAbstractData*>)));
   76     connect(d->inspector_tool_manager, SIGNAL(dataSetToRemove(QList<dtkAbstractData*>)),
this, SIGNAL(
dataSetRemoved(QList<dtkAbstractData*>)));
   77     connect(d->inspector_tool_manager, SIGNAL(dataSetToRemove(QList<dtkAbstractData*>)), d->controller, SLOT(onDataRemoved(QList<dtkAbstractData*>)));
   78     connect(d->inspector_tool_manager, SIGNAL(fieldsCreatedOnData(QList<axlAbstractData*>, QString)), d->inspector_object_manager, SLOT(onFieldsCreatedOnData(QList<axlAbstractData *>, QString)));
   81     connect(d->inspector_object_manager, SIGNAL(
stateChanged(dtkAbstractData*,
int)),
this, SIGNAL(
int)));
   89     connect(d->inspector_object_manager, SIGNAL(
dataSetRemoved(QList<dtkAbstractData*>)),
this, SIGNAL(
   90     connect(d->inspector_object_manager, SIGNAL(
dataSetRemoved(QList<dtkAbstractData *>)), d->controller, SLOT(onDataRemoved(QList<dtkAbstractData*>)));
   94     connect(d->inspector_object_manager, SIGNAL(
update()),
this, SIGNAL(
update()));
   95     connect(d->inspector_object_manager, SIGNAL(
showCurrentPoint(
double,
double, dtkAbstractData *)),
this, SIGNAL(
showCurrentPoint(
double,
double, dtkAbstractData *)));
   96     connect(d->inspector_object_manager, SIGNAL(
hideCurrentPoint(
double,
this, SIGNAL(
hideCurrentPoint(
double,
   97     connect(d->inspector_object_manager, SIGNAL(
moveCurrentPoint(
double,
this, SIGNAL(
moveCurrentPoint(
double,
  102     connect(d->side_pane, SIGNAL(showInspector(
bool)),
this, SLOT(
onShowInspector(
bool)));
  107     connect(d->side_pane, SIGNAL(showSettings(
bool)),
this, SLOT(
onShowSettings(
bool)));
  111     d->stack->setFixedWidth(0);
  112     d->stack->addWidget(
"object", d->inspector_object_manager);
  113     d->stack->addWidget(
"tool", d->inspector_tool_manager);
  114     d->stack->addWidget(
"view", d->inspector_view);
  117     d->settings->setFixedWidth(0);
  119     QHBoxLayout *layout =
new QHBoxLayout(
this);
  120     layout->setContentsMargins(0, 0, 0, 0);
  121     layout->setSpacing(0);
  122     layout->addWidget(d->side_pane);
  123     layout->addWidget(d->stack);
  124     layout->addWidget(d->settings);
  126     this->setStyleSheet(dtkReadFile(
":axlGui/axlInspector.qss"));
  127     this->setSizePolicy(QSizePolicy::Fixed, QSizePolicy::Expanding);
  139     return d->stack->size() + d->side_pane->size();
  145         d->inspector_object_manager->insert(data);
  147     d->inspector_object_manager->resizeColumnToContents();
  152     d->inspector_object_manager->insert(data);
  153     d->inspector_object_manager->resizeColumnToContents();
  157     d->inspector_object_manager->removeData(data);
  162     return d->inspector_object_manager->dataSet();
  167     d->inspector_object_manager->setView(view);
  168     d->inspector_tool_manager->setView(view);
  169     d->inspector_view->setView(view);
  174     d->inspector_view->updateView();
  178     d->inspector_object_manager->onFieldOpened(dataSet, fieldName);
  185     d->inspector_object_manager->onStateChanged(data, mode);
  190     QPropertyAnimation *animation =
new QPropertyAnimation(d->stack,
"width");
  191     animation->setDuration(600);
  192     animation->setStartValue(0);
  193     animation->setEndValue(300);
  196         animation->setDirection(QAbstractAnimation::Forward);
  199         animation->setDirection(QAbstractAnimation::Backward);
  201     animation->start(QAbstractAnimation::DeleteWhenStopped);
  206     QPropertyAnimation *animation =
new QPropertyAnimation(d->settings,
"width");
  207     animation->setDuration(600);
  208     animation->setStartValue(0);
  209     animation->setEndValue(300);
  212         animation->setDirection(QAbstractAnimation::Forward);
  215         animation->setDirection(QAbstractAnimation::Backward);
  217     animation->start(QAbstractAnimation::DeleteWhenStopped);
  221     d->inspector_object_manager->clearScene();
virtual ~axlInspector(void)
void insertData(axlAbstractData *data)
void dataChangedByControlPoints(dtkAbstractData *data)
void switchFullScreen(void)
void onShowInspector(bool)
void interpolationChanded(dtkAbstractData *data, int interpolation)
void onStateChanged(dtkAbstractData *data, int mode)
axlInspector(QWidget *parent=0)
void moveCurrentPoint(double u, double v, dtkAbstractData *data)
void stateChanged(dtkAbstractData *data, int mode)
void hideCurrentPoint(double u, double v, dtkAbstractData *data)
void dataSetRemoved(QList< dtkAbstractData * > dataSetRemoved)
void dataChanged(dtkAbstractData *data)
void insertDataSet(QList< axlAbstractData * > dataSet)
void modifiedProperty(dtkAbstractData *, int)
QList< dtkAbstractData * > dataSet(void)
void sendFieldSignal(QList< axlAbstractData * > dataSet, QString fieldName)
QSize sizeHint(void) const
void setView(axlAbstractView *view)
void dataInserted(axlAbstractData *data)
void dataChangedByGeometry(dtkAbstractData *data)
void actorVisibilityChanged(dtkAbstractData *data, bool actorVisibility)
void showCurrentPoint(double u, double v, dtkAbstractData *data)
void removeData(dtkAbstractData *data)
void joystickCamera(void)
void onShowSettings(bool)
void trackballCamera(void)
Class axlAbstractData defines an API for all type of axel data.
