Developer documentation | Axl-2.5.1
axlInspectorObjectSceneWidgetField.cpp
Go to the documentation of this file.
1 /* axlInspectorObjectSceneWidgetField.cpp ---
2  *
3  * Author: Julien Wintz
4  * Copyright (C) 2008 - Julien Wintz, Inria.
5  * Created: Fri Jul 30 21:28:55 2010 (+0200)
6  * Version: $Id$
7  * Last-Updated: Fri Sep 9 15:43:52 2011 (+0200)
8  * By: Julien Wintz
9  * Update #: 265
10  */
11
12 /* Commentary:
13  *
14  */
15
16 /* Change log:
17  *
18  */
19
24
28
29 #include <QtGui>
30
31 class axlInspectorObjectSceneWidgetFieldPrivate
32 {
33 public:
34  axlAbstractField *field;
35  axlAbstractActorField *actorField;
36  axlAbstractView *view;
37
38  QLineEdit *stats_type_edit;
39  QLineEdit *stats_kind_edit;
40  QLineEdit *stats_supp_edit;
41
42  QVBoxLayout *layout;
43
47 };
48
49 axlInspectorObjectSceneWidgetField::axlInspectorObjectSceneWidgetField(QWidget *parent) : QFrame(parent), d(new axlInspectorObjectSceneWidgetFieldPrivate)
50 {
51  d->field = NULL;
52  d->actorField = NULL;
53  d->view = NULL;
54
55  d->widgetFieldScalar = NULL;
56  d->widgetFieldVector = NULL;
57  d->widgetFieldTensor = NULL;
58
59  d->stats_type_edit = new QLineEdit(this);
60  d->stats_type_edit->setReadOnly(true);
61
62  d->stats_kind_edit = new QLineEdit(this);
63  d->stats_kind_edit->setReadOnly(true);
64
65  d->stats_supp_edit = new QLineEdit(this);
66  d->stats_supp_edit->setReadOnly(true);
67
68  QWidget *stats_widget = new QWidget(this);
69  stats_widget->setObjectName("axlInspectorObjectSceneWidgetFieldStatsForm");
70
71  QHBoxLayout *stats_layout = new QHBoxLayout(stats_widget);
72  //stats_layout->setFieldGrowthPolicy(QFormLayout::AllNonFixedFieldsGrow);
73  stats_layout->addWidget(d->stats_type_edit);
74  stats_layout->addWidget (d->stats_kind_edit);
75  stats_layout->addWidget (d->stats_supp_edit);
76
77
78
79  d->layout = new QVBoxLayout(this);
80  d->layout->addWidget(new QLabel("Field", this));
81  d->layout->addWidget(stats_widget);
82
83 }
84
86 {
87
88  delete d;
89
90  d = NULL;
91 }
92
94 {
95  d->field = field;
96
97  switch (d->field->type()) {
99  d->stats_type_edit->setText("Integer");
100  break;
102  d->stats_type_edit->setText("Float");
103  break;
105  d->stats_type_edit->setText("Double");
106  break;
107  }
108
109  switch (d->field->kind()) {
111  d->stats_kind_edit->setText("Scalar");
112  break;
114  d->stats_kind_edit->setText("Vector");
115  break;
117  d->stats_kind_edit->setText("Tensor");
118  break;
119  }
120
121  switch (d->field->support()) {
123  d->stats_supp_edit->setText("Point");
124  break;
126  d->stats_supp_edit->setText("Cell");
127  break;
129  d->stats_supp_edit->setText("Custom");
130  break;
131  }
132
133  // We Want to have only one widget
134  if(d->widgetFieldScalar)
135  {
136  disconnect(d->widgetFieldScalar, SIGNAL(displayAsColor()), this, SLOT(onDisplayAsColor()));
137  disconnect(d->widgetFieldScalar, SIGNAL(displayAsIso()), this, SLOT(onDisplayAsIso()));
138  disconnect(d->widgetFieldScalar, SIGNAL(displayAsNone()), this, SLOT(onDisplayAsNoneScalar()));
139
140  disconnect(d->widgetFieldScalar, SIGNAL(colRangeMinChanged(double)), this, SLOT(onColRangeMinChanged(double)));
141  disconnect(d->widgetFieldScalar, SIGNAL(colRangeMaxChanged(double)), this, SLOT(onColRangeMaxChanged(double)));
142
143  disconnect(d->widgetFieldScalar, SIGNAL(isoCountChanged(int)), this, SLOT(onIsoCountChanged(int)));
144  disconnect(d->widgetFieldScalar, SIGNAL(isoRadiusChanged(double)), this, SLOT(onIsoRadiusChanged(double)));
145
146  disconnect(d->widgetFieldScalar, SIGNAL(isoRangeMinChanged(double)), this, SLOT(onIsoRangeMinChanged(double)));
147  disconnect(d->widgetFieldScalar, SIGNAL(isoRangeMaxChanged(double)), this, SLOT(onIsoRangeMaxChanged(double)));
148
149  d->layout->removeWidget(d->widgetFieldScalar);
150
151  delete d->widgetFieldScalar;
152  d->widgetFieldScalar = NULL;
153  }
154
155  if(d->widgetFieldVector)
156  {
157  disconnect(d->widgetFieldVector, SIGNAL(displayAsHedge()), this, SLOT(onDisplayAsHedge()));
158  disconnect(d->widgetFieldVector, SIGNAL(displayAsGlyph()), this, SLOT(onDisplayAsGlyph()));
159  disconnect(d->widgetFieldVector, SIGNAL(displayAsStream()), this, SLOT(onDisplayAsStream()));
160  disconnect(d->widgetFieldVector, SIGNAL(displayAsNone()), this, SLOT(onDisplayAsNoneVector()));
161
162
163  disconnect(d->widgetFieldVector, SIGNAL(glyphScaleValueChanged(double)), this, SLOT(onGlyphScaleValueChanged(double)));
164
165  disconnect(d->widgetFieldVector, SIGNAL(streamRadiusValueChanged(double)), this, SLOT(onStreamRadiusValueChanged(double)));
166  disconnect(d->widgetFieldVector, SIGNAL(streamPropagationValueChanged(double)), this, SLOT(onStreamPropagationValueChanged(double)));
167  disconnect(d->widgetFieldVector, SIGNAL(streamDirectionValueChanged(int)), this, SLOT(onStreamDirectionValueChanged(int)));
168
169  d->layout->removeWidget(d->widgetFieldVector);
170  delete d->widgetFieldVector;
171  d->widgetFieldVector = NULL;
172  }
173
174  if(d->widgetFieldTensor)
175  {
176  d->layout->removeWidget(d->widgetFieldTensor);
177
178  delete d->widgetFieldTensor;
179  d->widgetFieldTensor = NULL;
180  }
181
182  if (d->field->kind() == axlAbstractField::Scalar) {
183
184
185  d->widgetFieldScalar = new axlInspectorObjectSceneWidgetFieldScalar(this);
186  d->widgetFieldScalar->setField(d->field);
187  d->widgetFieldScalar->setView(d->view);
188  //d->widgetFieldScalar->setDefaultDisplay();
189
190  d->layout->addWidget(d->widgetFieldScalar);
191  d->layout->addStretch(1);
192
193  connect(d->widgetFieldScalar, SIGNAL(displayAsColor()), this, SLOT(onDisplayAsColor()));
194  connect(d->widgetFieldScalar, SIGNAL(displayAsIso()), this, SLOT(onDisplayAsIso()));
195  connect(d->widgetFieldScalar, SIGNAL(displayAsNone()), this, SLOT(onDisplayAsNoneScalar()));
196
197
198  connect(d->widgetFieldScalar, SIGNAL(colRangeMinChanged(double)), this, SLOT(onColRangeMinChanged(double)));
199  connect(d->widgetFieldScalar, SIGNAL(colRangeMaxChanged(double)), this, SLOT(onColRangeMaxChanged(double)));
200
201  connect(d->widgetFieldScalar, SIGNAL(isoCountChanged(int)), this, SLOT(onIsoCountChanged(int)));
202  connect(d->widgetFieldScalar, SIGNAL(isoRadiusChanged(double)), this, SLOT(onIsoRadiusChanged(double)));
203  connect(d->widgetFieldScalar, SIGNAL(isoRangeMinChanged(double)), this, SLOT(onIsoRangeMinChanged(double)));
204  connect(d->widgetFieldScalar, SIGNAL(isoRangeMaxChanged(double)), this, SLOT(onIsoRangeMaxChanged(double)));
205
206  }
207
208  if (d->field->kind() == axlAbstractField::Vector){
209
210  d->widgetFieldVector = new axlInspectorObjectSceneWidgetFieldVector(this);
211  d->widgetFieldVector->setField(d->field);
212  d->widgetFieldVector->setView(d->view);
213
214  d->layout->addWidget(d->widgetFieldVector);
215  d->layout->addStretch(1);
216
217  connect(d->widgetFieldVector, SIGNAL(displayAsHedge()), this, SLOT(onDisplayAsHedge()));
218  connect(d->widgetFieldVector, SIGNAL(displayAsGlyph()), this, SLOT(onDisplayAsGlyph()));
219  connect(d->widgetFieldVector, SIGNAL(displayAsStream()), this, SLOT(onDisplayAsStream()));
220  connect(d->widgetFieldVector, SIGNAL(displayAsNone()), this, SLOT(onDisplayAsNoneVector()));
221
222  connect(d->widgetFieldVector, SIGNAL(glyphScaleValueChanged(double)), this, SLOT(onGlyphScaleValueChanged(double)));
223
224  connect(d->widgetFieldVector, SIGNAL(streamRadiusValueChanged(double)), this, SLOT(onStreamRadiusValueChanged(double)));
225  connect(d->widgetFieldVector, SIGNAL(streamPropagationValueChanged(double)), this, SLOT(onStreamPropagationValueChanged(double)));
226  connect(d->widgetFieldVector, SIGNAL(streamDirectionValueChanged(int)), this, SLOT(onStreamDirectionValueChanged(int)));
227  }
228
229  if (d->field->kind() == axlAbstractField::Tensor) {
230
231  d->widgetFieldTensor = new axlInspectorObjectSceneWidgetFieldTensor(this);
232  d->widgetFieldTensor->setField(d->field);
233
234  d->layout->addWidget(d->widgetFieldTensor);
235  d->layout->addStretch(1);
236  }
237 }
238
240 {
241  d->actorField = actorField;
242 }
243
245 {
246  d->view = view;
247 }
248
250 {
251  if(!d->view)
252  return;
253
254
255  if(axlAbstractActorField *actor = dynamic_cast<axlAbstractActorField *>(d->view->actor(d->field)))
256  actor->displayAsNoneScalar();
257
258
259  d->view->update();
260 }
261
263 {
264  if(!d->view)
265  return;
266
267
268  if(axlAbstractActorField *actor = dynamic_cast<axlAbstractActorField *>(d->view->actor(d->field)))
269  actor->displayAsColor();
270
271
272  d->view->update();
273 }
274
276 {
277  if(!d->view)
278  return;
279
280  if(axlAbstractActorField *actor = dynamic_cast<axlAbstractActorField *>(d->view->actor(d->field)))
281  actor->displayAsIso();
282
283  d->view->update();
284 }
285
287 {
288  if(!d->view)
289  return;
290
291  if(axlAbstractActorField *actor = dynamic_cast<axlAbstractActorField *>(d->view->actor(d->field)))
292  actor->displayAsNoneVector();
293
294  d->view->update();
295 }
296
297
299 {
300  if(!d->view)
301  return;
302
303  if(axlAbstractActorField *actor = dynamic_cast<axlAbstractActorField *>(d->view->actor(d->field)))
304  actor->displayAsHedge();
305
306  d->view->update();
307 }
308
310 {
311  if(!d->view)
312  return;
313
314  if(axlAbstractActorField *actor = dynamic_cast<axlAbstractActorField *>(d->view->actor(d->field)))
315  actor->displayAsGlyph();
316
317  d->view->update();
318 }
319
321 {
322  if(!d->view)
323  return;
324
325  if(axlAbstractActorField *actor = dynamic_cast<axlAbstractActorField *>(d->view->actor(d->field)))
326  actor->displayAsStream();
327
328  d->view->update();
329 }
330
332 {
333  if(!d->view)
334  return;
335
336  if(axlAbstractActorField *actor = dynamic_cast<axlAbstractActorField *>(d->view->actor(d->field)))
337  actor->setIsoCount(count);
338
339  d->view->update();
340 }
341
343 {
344  if(!d->view)
345  return;
346
347  if(axlAbstractActorField *actor = dynamic_cast<axlAbstractActorField *>(d->view->actor(d->field)))
348  actor->onIsoRadiusChanged(radius);
349
350  d->view->update();
351 }
352
354 {
355  if(!d->view)
356  return;
357
358  if(axlAbstractActorField *actor = dynamic_cast<axlAbstractActorField *>(d->view->actor(d->field)))
359  actor->setColRangeMin(min);
360
361  d->view->update();
362 }
363
365 {
366  if(!d->view)
367  return;
368
369  if(axlAbstractActorField *actor = dynamic_cast<axlAbstractActorField *>(d->view->actor(d->field)))
370  actor->setColRangeMax(max);
371
372  d->view->update();
373 }
374
376 {
377  if(!d->view)
378  return;
379
380  if(axlAbstractActorField *actor = dynamic_cast<axlAbstractActorField *>(d->view->actor(d->field)))
381  actor->setIsoRangeMin(min);
382
383  d->view->update();
384 }
385
387 {
388  if(!d->view)
389  return;
390
391  if(axlAbstractActorField *actor = dynamic_cast<axlAbstractActorField *>(d->view->actor(d->field)))
392  actor->setIsoRangeMax(max);
393
394  d->view->update();
395 }
396
398 {
399  if(!d->view)
400  return;
401
402  if(axlAbstractActorField *actor = dynamic_cast<axlAbstractActorField *>(d->view->actor(d->field)))
403  actor->setGlyphScale(scale);
404
405  d->view->update();
406 }
407
409 {
410  if(!d->view)
411  return;
412
413  if(axlAbstractActorField *actor = dynamic_cast<axlAbstractActorField *>(d->view->actor(d->field)))
414  actor->setStreamRadius(radius);
415
416  d->view->update();
417 }
418
420 {
421  if(!d->view)
422  return;
423
424  if(axlAbstractActorField *actor = dynamic_cast<axlAbstractActorField *>(d->view->actor(d->field)))
425  actor->setStreamPropagation(propagation);
426
427  d->view->update();
428 }
429
431 {
432  if(!d->view)
433  return;
434
435  if(axlAbstractActorField *actor = dynamic_cast<axlAbstractActorField *>(d->view->actor(d->field)))
436  actor->setStreamDirection(direction);
437
438  d->view->update();
439 }
Class axlAbstractField defines an API for arrays of numeric data.
