7 #include <dtkCoreSupport/dtkAbstractProcess.h>
    8 #include <dtkCoreSupport/dtkAbstractProcessFactory.h>
   17 #include <QDoubleSpinBox>
   35         this->setParent(parent);
   38         this->setValue(value);
   40         connect(
this, SIGNAL(valueChanged(
int)),
this, SLOT(
addParameterInt(
int)));
   47         disconnect(
int)),
this, SLOT(
addParameterInt(
int)));
   81         this->setParent(parent);
   83         this->setValue(value);
   84         this->setSingleStep(0.10);
   86         connect(
double)),
this, SLOT(
addParameter(
double)));
   93         disconnect(
double)),
this, SLOT(
addParameter(
double)));
  134                 this->addItem(item->text(0));
  138         QString name = this->currentText();
  140             QString nameList = item->text(0);
  143             if(nameList == name){
  151         connect(
this, SIGNAL(activated(QString)),
this, SLOT(
OnFindingInput(
const QString&)));
  157         disconnect(
this, SLOT(
OnFindingInput(
const QString&)));
  172             QString nameList = item->text(0);
  174             if(nameList == name){
  176                     process->setInput(controller->
data(item));
  178                     process->setInput(controller->
data(item),
channel);
  193         this->setText(
"Output:" + channel +
" "+label);
  215         this->setParent(parent);
  218         this->addItems(list);
  220         connect(
this, SIGNAL(currentIndexChanged(
int)),
this, SLOT(
addParameter(
int)));
  227         disconnect(
int)),
this, SLOT(
addParameter(
int)));
  234             process->setParameter(currentIndex);
  261         QList<axlAbstractData *>dataList;
  266             if( (item->text(2) ==
"Selected" || item->text(2) ==
"Editable"))
  268                 dataList << dynamic_cast<axlAbstractData *>(
controller->
data(item));
  298 class axlInspectorToolGenericPrivate
  324     d->process = qobject_cast<
axlAbstractProcess *>(dtkAbstractProcessFactory::instance()->create(implementation));
  326         d->process->setParent(
this);
  328         d->controller = control;
  331         d->button =
new QPushButton(
"Run",
this);
  332         d->layout->addWidget(d->button);
  336         dtkWarn() <<
"no process available";
  338     this->setAttribute(Qt::WA_DeleteOnClose);
  346     disconnect(d->button, SIGNAL(clicked()), d->process, SLOT(update()));
  360     if(d->process->update()){
  362             if(d->process->output()){
  363                 emit
dataInserted(dynamic_cast<axlAbstractData *>(d->process->output()));
  370 void axlInspectorToolGenericPrivate::setup(
void)
  372     this->layout =
new QFormLayout(q);
  375         this->layout->addRow(
new QLabel(
"Invalid process", q));
  377         this->layout->addRow(
new QLabel(this->process->identifier(), q));
  380     QString form = this->process->form();
  384         QList<dtkAbstractData*> dataSet;
  385         int numberOfDataSelected =0;
  389             if(item->text(2) ==
"Selected")
  391                 dataSet.push_back (this->controller->data(item));
  392                 numberOfDataSelected++;
  397         if(dataSet.size() == 0)
  398             qDebug() <<
" No input data selected for : "<< process->identifier();
  400         else if(dataSet.size() == 1)
  401             process->setInput(dataSet.first());
  404             for (
int i = 0 ; i < dataSet.size() ; i++)
  405                 process->setInput(dataSet[i], i);
  413         QStringList lines = form.split(
"\n");
  414         foreach(QString line, lines) {
  416             QStringList tokens = line.simplified().split(QRegExp(
"\\s"));
  417             int l=tokens.at(0).size();
  419             if(tokens.first().startsWith(
"INPUT")) {
  421                 Q_ASSERT(tokens.count() >3);
  423                 QString type = tokens.at(1);
  424                 QString label = tokens.at(2);
  428                     QString channel = tokens.at(0).right(l-6);
  431                         int value = tokens.last().toInt();
  435                     if(type ==
"double"){
  436                         double value = tokens.last().toDouble();
  444                     if(type ==
"dataList")
  449                         int value = tokens.last().toInt();
  453                     if(type ==
"double"){
  454                         double value = tokens.last().toDouble();
  462                     if(type ==
"dataList")
  469             if(tokens.first().startsWith(
"PARAMETER")) {
  475                     QString channel = tokens.at(0).right(l-10);
  476                     QString type = tokens.at(1);
  477                     QString label = tokens.at(2);
  481                         int value = tokens.last().toInt();
  485                     if(type ==
"double"){
  486                         double value = tokens.last().toDouble();
  494             if(tokens.first().startsWith(
"OUTPUT")){
  496                 Q_ASSERT(tokens.count() > 2);
  498                 QString channel =
  500                     channel = tokens.at(0).right(l-8);
  501                 QString label = tokens.at(2);
  508 #include "axlInspectorToolGeneric.moc"
dtkAbstractData * data(axlInspectorObjectManagerTreeItem *item)
QList< axlInspectorObjectManagerTreeItem * > items(void)
Class axlAbstractData defines an API for all type of axel data.
