21 #include <dtkCoreSupport/dtkAbstractData.h>
   22 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
   45     return "axlOFFReader";
   55     return "axlOFFReader";
   65     return QStringList() <<
".off" <<
"off document";
   75     return dtkAbstractDataFactory::instance()->registerDataReaderType(
"axlOFFReader", QStringList(),
createaxlOFFReader);
   86     if (filename.open(QFile::ReadOnly))
   88         QTextStream in(&filename);
   92         QVector<int> currentFace;
   94         format = in.readLine(75);
   96         if(format.startsWith(
"OFF") || format.startsWith(
"off") ||  format.startsWith(
"Off")){
  111     QFile filename(file);
  112     if (filename.open(QFile::ReadOnly))
  114         QTextStream in(&filename);
  120         bool intConvert =
false;
  126         QVector<int> currentFace;
  127         int currentFaceSize = 0;
  128         int currentFaceIndex = 0;
  130         format = in.readLine(75);
  132         if(format.startsWith(
"Off"))
  142                 vertexCount = format.toInt(&intConvert);
  151             for(
int i = 0 ; i < vertexCount ; i++)
  164             for(
int i = 0 ; i < faceCount+edgeCount ; i++)
  168                 in >> currentFaceSize;
  170                 if(currentFaceSize == 1){
  171                     for(
int j = 0 ; j < 2 ; j++)
  174                         in >> currentFaceIndex;
  175                         currentFace << currentFaceIndex;
  183                     for(
int j = 0 ; j < currentFaceSize ; j++)
  186                         in >> currentFaceIndex;
  187                         currentFace << currentFaceIndex;
int face_count(void) const
QString description(void) const
Return a description of the reader.
bool read(const QString &file)
Read the file which is supposed to be of right type OFF and create a data.
bool vertex_show(void) const
void push_back_edge(int, int)
static bool registered(void)
Register this reader type in the factory.
bool edge_show(void) const
int edge_count(void) const
QString identifier(void) const
Return the identifier "axlOFFReader".
bool face_show(void) const
void push_back_face(const Face &face)
int vertex_count(void) const
dtkAbstractDataReader * createaxlOFFReader(void)
QStringList handled(void) const
Return the type of file that the reader is able to read : "OFF files (.OFF, .off)" ...
Class axlMesh defines a piecewise-linear 3D object.
void push_back_vertex(const double &x, const double &y, const double &z)
Add a new vertex to the mesh.
bool canRead(const QString &file)
Check that the file can be read by this type of reader.
