#include <axlOFFReader.h>
Public Slots | |
| bool | canRead (const QString &file) |
| Check that the file can be read by this type of reader. More... | |
| bool | read (const QString &file) |
| Read the file which is supposed to be of right type OFF and create a data. More... | |
Public Member Functions | |
| axlOFFReader (void) | |
| ~axlOFFReader (void) | |
| QString | identifier (void) const |
| Return the identifier "axlOFFReader". More... | |
| QString | description (void) const |
| Return a description of the reader. More... | |
| QStringList | handled (void) const |
| Return the type of file that the reader is able to read : "OFF files (.OFF, .off)" . More... | |
Static Public Member Functions | |
| static bool | registered (void) |
| Register this reader type in the factory. More... | |
Definition at line 24 of file axlOFFReader.h.
| axlOFFReader::axlOFFReader | ( | void | ) |
Definition at line 28 of file axlOFFReader.cpp.
| axlOFFReader::~axlOFFReader | ( | void | ) |
Definition at line 33 of file axlOFFReader.cpp.
slot |
Definition at line 83 of file axlOFFReader.cpp.
| QString axlOFFReader::description | ( | void | ) | const |
Definition at line 53 of file axlOFFReader.cpp.
| QStringList axlOFFReader::handled | ( | void | ) | const |
Definition at line 63 of file axlOFFReader.cpp.
| QString axlOFFReader::identifier | ( | void | ) | const |
Definition at line 43 of file axlOFFReader.cpp.
slot |
Return true if the data is correctly created, else return false.
Definition at line 109 of file axlOFFReader.cpp.
static |
Definition at line 73 of file axlOFFReader.cpp.
