18 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
   24 class axlToMeshPrivate{
   28     QVector<axlAbstractData *> input;
   30     QVector<axlAbstractData *> output;
   47     if(channel < d->input.size())
   48         return d->input.at(channel);
   50         qDebug()<<
"You are trying to acces an input that is not exit";
   56     if(channel < d->
output.size()){
   57         return d->output.at(channel);
   60         qDebug()<<
"You are trying to acces an output that is not exit";
   66         return d->output.at(0);
   79     if(
axlAbstractData *axlData = dynamic_cast<axlAbstractData *>(newData)){
   83             d->input.push_back(axlData);
  101     return d->output.size();
  109     for(
int i = 0 ; i < d->input.size() ; i++)
  118             converter->setData(data);
  120             d->output.push_back(currentMesh);
  124             qDebug()<<
"Cannot find converter for : "<< d->input[i]->identifier();
  129     dtkWarn()<<
"axlConvertToMesh::update :" <<d->output.size() <<
"data has been converted sucessfully";
  140     return "Convert all Input selected Data to axlMesh. Only data with converter will be converted";
axlToMesh(QObject *parent=0)
int face_count(void) const
QString description(void) const
void dataInserted(axlAbstractData *data)
int edge_count(void) const
axlAbstractData * getInput(int channel) const
axlToMesh is a process that allow you to convert data to mesh.
void setInput(dtkAbstractData *newData, int channel=0)
QString identifier(void) const
dtkAbstractData * output(void)
virtual axlMesh * toMesh(void)
Mesh conversion.
int vertex_count(void) const
Class axlAbstractData defines an API for all type of axel data.
dtkAbstractProcess * createaxlToMeshProcess(void)
Class axlMesh defines a piecewise-linear 3D object.
