26 #include <dtkCoreSupport/dtkAbstractData.h>
   27 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
   43     return "axlTorusReader";
   47     return "axlTorusReader";
   51     return QStringList() <<
"axlTorus";
   55     return dtkAbstractDataFactory::instance()->registerDataReaderType(
"axlTorusReader", QStringList(),
createaxlTorusReader);
   59     QDomElement element = node.toElement();
   61     if (element.tagName() !=
"torus")
   77     return !this->
accept(node);
   81     QDomElement element = node.toElement();
   85     QString name = element.attribute(
"name");
   86     if (!name.isEmpty()) {
   87         currentTorus->setObjectName(name);
   90     QString color = element.attribute(
"color");
   91     if (!color.isEmpty()) {
   92         QStringList colorList = color.split(
   93         if (colorList.size() > 2)
   94             currentTorus->
setColor(QColor(colorList.at(0).toInt(), colorList.at(1).toInt(), colorList.at(2).toInt()));
   95         if (colorList.size() == 4)
   96             currentTorus->
setOpacity(colorList.at(3).toFloat());
   99     QString shader = element.attribute(
"shader");
  101     if (!shader.isEmpty()) {
  103         dirShader =
":axlShader/shader/" + shader;
  104         if (!QFile::exists(dirShader)) {
  105             QSettings settings(
"inria",
"dtk");
  107             settings.beginGroup(
"shader");
  108             dirShader = settings.value(
"path", defaultPath).toString();
  109             dirShader.append(
"/" + shader);
  114     QString size = element.attribute(
"size");
  116         currentTorus->
setSize(size.toFloat());
  119     QDomNodeList nodeListCenter = element.elementsByTagName(
"center");
  120     QDomElement elementCenter = nodeListCenter.item(0).toElement();
  121     QStringList coordCenter = elementCenter.text().simplified().split(QRegExp(
"\\s+"));
  122     if (coordCenter.size() == 3)
  123         currentTorus->
setCenter(
new axlPoint(coordCenter[0].toDouble(), coordCenter[1].toDouble(), coordCenter[2].toDouble()));
  125         qDebug() <<
"Torus data cannot be read correctly: radius coordinates";
  128     QDomNodeList nodeListDirection = element.elementsByTagName(
"direction");
  129     QDomElement elementDirection = nodeListDirection.item(0).toElement();
  130     QStringList coordDirection = elementDirection.text().simplified().split(QRegExp(
"\\s+"));
  131     if (coordDirection.size() == 3)
  132         currentTorus->
setDirection(
new axlPoint(coordDirection[0].toDouble(), coordDirection[1].toDouble(), coordDirection[2].toDouble()));
  134         qDebug() <<
"Torus data cannot be read correctly: direction coordinates";
  137     QDomNodeList nodeListRingRadius = element.elementsByTagName(
"ringRadius");
  138     QDomElement elementRingRadius = nodeListRingRadius.item(0).toElement();
  139     QStringList ringRadius = elementRingRadius.text().simplified().split(QRegExp(
"\\s+"));
  140     if (ringRadius.size() == 1)
  143         qDebug() <<
"Torus data cannot be read correctly : ring radius";
  146     QDomNodeList nodeListCrossSectionRadius = element.elementsByTagName(
"crossSectionRadius");
  147     QDomElement elementCrossSectionRadius = nodeListCrossSectionRadius.item(0).toElement();
  148     QStringList crossSectionRadius = elementCrossSectionRadius.text().simplified().split(QRegExp(
"\\s+"));
  149     if (crossSectionRadius.size() == 1)
  152         qDebug() <<
"Torus data cannot be read correctly : cross section radius";
  155     QDomNodeList nodeListField = element.elementsByTagName(
"field");
  156     if(!nodeListField.isEmpty()){
  157         for(
int i = 0; i < nodeListField.size(); i++){
  158             QDomElement fieldElement = nodeListField.at(i).toElement();
  159             QString fieldType = fieldElement.attribute(
"type");
  160             if(!fieldType.isEmpty()){
  165                     fieldToAdd->setObjectName(newName);
Class axlPoint defines 3D points.
QStringList handled(void) const
void setCenter(axlPoint *center)
void setCrossSectionRadius(double crossSectionRadius)
axlAbstractData * read(const QDomNode &node)
void setShader(const QString &shader)
QString changeFieldName(QString fieldName)
dtkAbstractDataReader * create(const QString &interface_name)
dtkAbstractDataReader * createaxlTorusReader(void)
virtual axlAbstractData * read(const QDomNode &node)=0
Class axlAbstractField defines an API for arrays of numeric data.
static bool registered(void)
void setRingRadius(double ringRadius)
bool accept(const QDomNode &node)
void setDirection(axlPoint *direction)
bool hasChildNode(QDomElement element, const QString &tag)
void setOpacity(const double &opacity)
QString identifier(void) const
virtual ~axlTorusReader(void)
static axlFieldReadersFactory * instance(void)
void addField(axlAbstractField *field)
Add a field to the field list of the object.
void setSize(const double &size)
void setColor(double r, double g, double b)
QString description(void) const
Class axlAbstractData defines an API for all type of axel data.
bool reject(const QDomNode &node)
