#include <axlAbstractCurveAlgebraic.h>
Public Types | |
| typedef QMap< double, axlPoint > | Sample |
Signals | |
| void | updated (void) |
| void | samplingChanged () |
Signals inherited from axlAbstractData | |
| void | modifiedGeometry (void) |
| void | modifiedStructure (void) |
| void | modifiedField (void) |
| void | modifiedProperty (void) |
Public Member Functions | |
| axlAbstractCurveAlgebraic (void) | |
| virtual | ~axlAbstractCurveAlgebraic (void) |
| virtual void | setData (void *data) |
| virtual void | setData (const QList< double > &box, const QString &) |
| virtual QString | description (void) const |
Public Member Functions inherited from axlAbstractCurve | |
| axlAbstractCurve (void) | |
| virtual | ~axlAbstractCurve (void) |
| virtual int | dimension (void) const |
| virtual bool | isPlanar (void) const |
| virtual void * | curve (void) |
Public Member Functions inherited from axlAbstractData | |
| axlAbstractData (axlAbstractData *parent=NULL) | |
| axlAbstractData (const axlAbstractData &data) | |
| virtual | ~axlAbstractData (void) |
| const QColor & | color (void) const |
| const double & | opacity (void) const |
| const double & | size (void) const |
| const QString & | shader (void) const |
| const bool & | editable (void) |
| const bool & | updateView (void) |
| void | setColor (double r, double g, double b) |
| void | addField (axlAbstractField *field) |
| Add a field to the field list of the object. More... | |
| bool | updateFieldList (QString nameField) |
| Check if a field with the same name is already applied on the object. More... | |
| QString | changeFieldName (QString fieldName) |
| axlMesh * | mesh (void) |
| Return the mesh of that object is computed. More... | |
| void | setMesh (axlMesh *mesh) |
| Set a corresponding mesh for that object. More... | |
| virtual QVariantList | convertDataToQVariant (void) const |
| Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData. More... | |
| virtual int | convertQVariantToData (const QVariantList &data) |
| Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0. More... | |
| void | setUpdateView (bool updateView) |
| QList< axlAbstractField * > | fields (void) |
Additional Inherited Members | |
Public Slots inherited from axlAbstractData | |
| void | touchGeometry (void) |
| void | touchProperty (void) |
| void | touchStructure (void) |
| virtual void | touchField (void) |
| void | setColor (const QColor &color) |
| void | setOpacity (const double &opacity) |
| void | setSize (const double &size) |
| void | setShader (const QString &shader) |
| void | setEditable (bool edit) |
Properties inherited from axlAbstractData | |
| QColor | color |
| double | opacity |
| double | size |
| QString | shader |
Definition at line 28 of file axlAbstractCurveAlgebraic.h.
| typedef QMap<double, axlPoint> axlAbstractCurveAlgebraic::Sample |
Definition at line 34 of file axlAbstractCurveAlgebraic.h.
| axlAbstractCurveAlgebraic::axlAbstractCurveAlgebraic | ( | void | ) |
Definition at line 30 of file axlAbstractCurveAlgebraic.cpp.
virtual |
Definition at line 35 of file axlAbstractCurveAlgebraic.cpp.
virtual |
Definition at line 53 of file axlAbstractCurveAlgebraic.cpp.
signal |
virtual |
virtual |
Definition at line 41 of file axlAbstractCurveAlgebraic.cpp.
signal |
