#include <axlCylinderCreator.h>
Public Member Functions | |
| axlCylinderCreator (QObject *parent=0) | |
| virtual | ~axlCylinderCreator (void) |
| virtual axlAbstractData * | getInput (int channel) const |
| void | copyProcess (axlAbstractProcess *process) |
| bool | hasParameters (void) |
| virtual int | update (void) |
| virtual QString | description (void) const |
| virtual QString | identifier (void) const |
| virtual void | setInput (dtkAbstractData *newData, int channel) |
| virtual void | setParameter (double data) |
| virtual dtkAbstractData * | output (void) |
Public Member Functions inherited from axlAbstractCreatorProcess | |
| axlAbstractCreatorProcess (QObject *parent=0) | |
| virtual | ~axlAbstractCreatorProcess (void) |
| virtual dtkAbstractData * | output (int channel) |
| virtual int | channelCount (void) |
Public Member Functions inherited from axlAbstractProcess | |
| axlAbstractProcess (void) | |
| virtual | ~axlAbstractProcess (void) |
| virtual void | setDescription (QString description) |
| virtual void | setIdentifier (QString identifier) |
| virtual QString | form (void) const |
| Description of the form for the dialog with the process. More... | |
Static Public Member Functions | |
| static bool | registered (void) |
Definition at line 29 of file axlCylinderCreator.h.
| axlCylinderCreator::axlCylinderCreator | ( | QObject * | parent = 0 | ) |
Definition at line 39 of file axlCylinderCreator.cpp.
virtual |
Definition at line 47 of file axlCylinderCreator.cpp.
virtual |
Reimplemented from axlAbstractProcess.
Definition at line 62 of file axlCylinderCreator.cpp.
virtual |
Reimplemented from axlAbstractCreatorProcess.
Definition at line 117 of file axlCylinderCreator.cpp.
virtual |
Definition at line 54 of file axlCylinderCreator.cpp.
virtual |
returns true if the process needs parameters. By default, equals false.
Definition at line 68 of file axlCylinderCreator.cpp.
virtual |
Definition at line 122 of file axlCylinderCreator.cpp.
virtual |
Definition at line 73 of file axlCylinderCreator.cpp.
static |
Definition at line 126 of file axlCylinderCreator.cpp.
virtual |
Definition at line 78 of file axlCylinderCreator.cpp.
virtual |
Definition at line 90 of file axlCylinderCreator.cpp.
virtual |
Definition at line 95 of file axlCylinderCreator.cpp.
