Class axlFieldParametricVolumeTangentVector defines an API for field which owns a BSpline Surface as a function and a parametric surface on which the field is applied. More...
#include <axlFieldParametricVolumeTangentVector.h>
Public Slots | |
virtual void | update (void) |
void | touchGeometry (void) |
void | touchProperty (void) |
void | touchStructure (void) |
virtual void | touchField (void) |
void | setColor (const QColor &color) |
void | setOpacity (const double &opacity) |
void | setSize (const double &size) |
void | setShader (const QString &shader) |
void | setEditable (bool edit) |
Public Member Functions | |
axlFieldParametricVolumeTangentVector () | |
virtual | ~axlFieldParametricVolumeTangentVector (void) |
Destroys a Bspline field. More... | |
void | setVolume (axlAbstractData *data) |
Sets the BSpline on which the BSpline field is applied. More... | |
void | setParameter (double parameter, int channel) |
Sets the direction parameter for the tangentVector. More... | |
double | parameter (int channel) |
Returns the direction parameter for the tangentVector, the channel-th one. More... | |
double | start_u (void) |
Returns the first parameter value of the field. More... | |
double | start_v (void) |
double | start_w (void) |
double | end_u (void) |
Returns the last parameter value of the field. More... | |
double | end_v (void) |
double | end_w (void) |
double | numbersample_u (void) |
Returns the number of parameters. More... | |
double | numbersample_v (void) |
double | numbersample_w (void) |
int | size (void) |
Returns the number of values evaluated for this BSpline field on each samples of the input BSpline. More... | |
double * | vector (double u, double v, double w) |
Returns the value of the spatial field at the coordinates point entered. More... | |
QString | description (void) const |
Returns the description of the field. More... | |
QString | identifier (void) const |
Returns the identifier of the field "axlFieldParametricVolumeTangentVector". More... | |
axlAbstractFieldParametricVolume () | |
virtual | ~axlAbstractFieldParametricVolume (void) |
Destroys a parametric field. More... | |
virtual double | scalar (double u, double v, double w) |
Returns the value of the parametric field at the parameters values in input. More... | |
virtual double * | tensor (double u, double v, double w) |
virtual void | setFunction (axlAbstractData *data) |
virtual axlAbstractData * | getFunction (void) |
axlAbstractFieldParametric () | |
virtual | ~axlAbstractFieldParametric (void) |
axlAbstractField () | |
axlAbstractField (QString name, Type type, Kind kind, Support support) | |
virtual | ~axlAbstractField (void) |
Destroys the field. More... | |
virtual void | setType (Type type) |
Sets the type of the field which can be either int, float or double. More... | |
virtual void | setKind (Kind kind) |
Sets the kind of the field which can be either scalar, vector or tensor. More... | |
virtual void | setSupport (Support support) |
virtual Type | type (void) |
virtual Kind | kind (void) |
virtual Support | support (void) |
virtual void | setMin (double mini) |
Sets the minimum value of the field. More... | |
virtual double | minValue (void) |
Returns the minimum value of the field. More... | |
virtual void | setMax (double maxi) |
Sets the maximum value of the field.. More... | |
virtual double | maxValue (void) |
Returns the maximum value of the field. More... | |
axlAbstractData (axlAbstractData *parent=NULL) | |
axlAbstractData (const axlAbstractData &data) | |
virtual | ~axlAbstractData (void) |
const QColor & | color (void) const |
const double & | opacity (void) const |
const double & | size (void) const |
const QString & | shader (void) const |
const bool & | editable (void) |
const bool & | updateView (void) |
void | setColor (double r, double g, double b) |
void | addField (axlAbstractField *field) |
Add a field to the field list of the object. More... | |
bool | updateFieldList (QString nameField) |
Check if a field with the same name is already applied on the object. More... | |
QString | changeFieldName (QString fieldName) |
axlMesh * | mesh (void) |
Return the mesh of that object is computed. More... | |
void | setMesh (axlMesh *mesh) |
Set a corresponding mesh for that object. More... | |
virtual QVariantList | convertDataToQVariant (void) const |
Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData. More... | |
virtual int | convertQVariantToData (const QVariantList &data) |
Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0. More... | |
void | setUpdateView (bool updateView) |
QList< axlAbstractField * > | fields (void) |
Additional Inherited Members | |
enum | Type { Int = 0x001, Float = 0x002, Double = 0x004 } |
enum | Kind { Scalar = 0x001, Vector = 0x002, Tensor = 0x004 } |
enum | Support { Point = 0x001, Cell = 0x002, Custom = 0x004 } |
void | updated (void) |
void | modifiedGeometry (void) |
void | modifiedStructure (void) |
void | modifiedField (void) |
void | modifiedProperty (void) |
QColor | color |
double | opacity |
double | size |
QString | shader |
Definition at line 23 of file axlFieldParametricVolumeTangentVector.h.
axlFieldParametricVolumeTangentVector::axlFieldParametricVolumeTangentVector | ( | ) |
Definition at line 52 of file axlFieldParametricVolumeTangentVector.cpp.
virtual |
Definition at line 72 of file axlFieldParametricVolumeTangentVector.cpp.
virtual |
Reimplemented from axlAbstractFieldParametricVolume.
Definition at line 130 of file axlFieldParametricVolumeTangentVector.cpp.
virtual |
Definition at line 221 of file axlFieldParametricVolumeTangentVector.cpp.
virtual |
Definition at line 231 of file axlFieldParametricVolumeTangentVector.cpp.
virtual |
Definition at line 242 of file axlFieldParametricVolumeTangentVector.cpp.
virtual |
Definition at line 120 of file axlFieldParametricVolumeTangentVector.cpp.
virtual |
Definition at line 253 of file axlFieldParametricVolumeTangentVector.cpp.
virtual |
Definition at line 262 of file axlFieldParametricVolumeTangentVector.cpp.
virtual |
Definition at line 271 of file axlFieldParametricVolumeTangentVector.cpp.
double axlFieldParametricVolumeTangentVector::parameter | ( | int | channel | ) |
Definition at line 174 of file axlFieldParametricVolumeTangentVector.cpp.
void axlFieldParametricVolumeTangentVector::setParameter | ( | double | parameter, |
int | channel | ||
Definition at line 159 of file axlFieldParametricVolumeTangentVector.cpp.
virtual |
Definition at line 149 of file axlFieldParametricVolumeTangentVector.cpp.
virtual |
Definition at line 280 of file axlFieldParametricVolumeTangentVector.cpp.
virtual |
Definition at line 192 of file axlFieldParametricVolumeTangentVector.cpp.
virtual |
Definition at line 203 of file axlFieldParametricVolumeTangentVector.cpp.
virtual |
Definition at line 211 of file axlFieldParametricVolumeTangentVector.cpp.
virtualslot |
Mark the internal data structure as changed to notify underlying pipeline execution.
Definition at line 291 of file axlFieldParametricVolumeTangentVector.cpp.
virtual |
Definition at line 84 of file axlFieldParametricVolumeTangentVector.cpp.
