22 #include <dtkCoreSupport/dtkGlobal.h>
   24 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
   25 #include <dtkCoreSupport/dtkAbstractProcessFactory.h>
   29 class axlFieldParametricVolumeTangentVectorPrivate
  101     double x = d->a*deriv1u->
x() + d->b*deriv1v->
x() + d->c*deriv1w->
x();
  102     double y = d->a*deriv1u->
y() + d->b*deriv1v->
y()+ d->c*deriv1w->
y();
  103     double z = d->a*deriv1u->
z() + d->b*deriv1v->
z()+ d->c*deriv1w->
z();
  104     double *tangentTab =
new double[3];
  122     return "axlFieldParametricVolumeTangentVector";
  134     qstr.append(
"axlFieldParametricVolumeTangentVector : \n");
  135     qstr.append(
"Type : Double ");
  136     qstr.append(
";Kind : Vector ");
  137     qstr.append(
";Support : Point");
  150     if(dynamic_cast<axlAbstractVolumeParametric*>(data))
  162     else if(channel == 1)
  167         qDebug() <<
"only three possible channel values : 0 to 2";
  177     else if(channel == 1)
  182         qDebug() <<
  194     return d->input->startParam_u();
  204     return d->input->startParam_v();
  212     return d->input->startParam_w();
  223     return d->input->endParam_u();
  233     return d->input->endParam_v();
  244     return d->input->endParam_w();
  255     return d->input->numSamples_u();
  263     return d->input->numSamples_v();
  272     return d->input->numSamples_w();
  281     return d->input->numSamples_u()*d->input->numSamples_v()*d->input->numSamples_w();
Class axlPoint defines 3D points.
double end_v(void)
Returns the last parameter value of the field.
double start_w(void)
Returns the first parameter value of the field.
double end_w(void)
double start_v(void)
double numbersample_v(void)
Returns the number of parameters.
virtual void update(void)
double end_u(void)
double start_u(void)
void setParameter(double parameter, int channel)
Sets the direction parameter for the tangentVector.
double numbersample_w(void)
QString identifier(void) const
Returns the identifier of the field "axlFieldParametricVolumeTangentVector".
QString description(void) const
Returns the description of the field.
int size(void)
Returns the number of values evaluated for this BSpline field on each samples of the input BSpline...
axlMesh * mesh(void)
Return the mesh of that object is computed.
double * vector(double u, double v, double w)
Returns the value of the spatial field at the coordinates point entered.
dtkAbstractData * createaxlFieldParametricVolumeTangentVector(void)
axlFieldParametricVolumeTangentVector()
double numbersample_u(void)
void setVolume(axlAbstractData *data)
Sets the BSpline on which the BSpline field is applied.
void vertex(const int &ind, double vertex[3])
set vertex values of vertices with index ind.
virtual ~axlFieldParametricVolumeTangentVector(void)
Destroys a Bspline field.
virtual void setType(Type type)
Sets the type of the field which can be either int, float or double.
Class axlAbstractFieldParametricVolume defines an API for parametric field.
virtual void setSupport(Support support)
virtual void setKind(Kind kind)
Sets the kind of the field which can be either scalar, vector or tensor.
double parameter(int channel)
Returns the direction parameter for the tangentVector, the channel-th one.
Class axlAbstractData defines an API for all type of axel data.
Class axlFieldParametricVolumeTangentVector defines an API for field which owns a BSpline Surface as ...
Class axlMesh defines a piecewise-linear 3D object.
