#include <axlFieldSpatialCoordinatesCreator.h>
| void | setInput (dtkAbstractData *data, int channel) |
| void | setParameter (double value, int channel) |
| int | update (void) |
| virtual void | setInput (dtkAbstractData *data, int channel=0) |
| virtual int | update (void) |
          | axlFieldSpatialCoordinatesCreator::axlFieldSpatialCoordinatesCreator | ( | void |  | ) |  |
          | axlFieldSpatialCoordinatesCreator::~axlFieldSpatialCoordinatesCreator | ( | void |  | ) |  |  | virtual |
          | QString axlFieldSpatialCoordinatesCreator::description | ( | void |  | ) | const |  | virtual |
          | QString axlFieldSpatialCoordinatesCreator::form | ( | void |  | ) | const |  | inlinevirtual |
Description of the form for the dialog with the process.
The string use to describe the form is formatted as follows:
"INPUT[:CHANNEL] TYPE LABEL"
"PARAMETER[:CHANNEL] TYPE LABEL"
"OUTPUT [:CHANNEL] LABEL"
 where:
- CHANNEL is a number identifying the rank of an input, see dtkAbstractProcess. Write this value only if the process method setInput uses a channel in its parameters !
- TYPE is either int, double or data.
- LABEL is the input's name.
Here is an example of such a declaration:
      return QString(
           " INPUT:0 data StartPoint \n"
           " INPUT:1 data EndPoint \n"
           " PARAMETER:0 double Radius \n"
           " OUTPUT Cylinder ");
Reimplemented from axlAbstractProcess.
Definition at line 54 of file axlFieldSpatialCoordinatesCreator.h.
          | QString axlFieldSpatialCoordinatesCreator::identifier | ( | void |  | ) | const |  | virtual |
          | static bool axlFieldSpatialCoordinatesCreator::registered | ( | void |  | ) |  |  | static |
          | void axlFieldSpatialCoordinatesCreator::setInput | ( | dtkAbstractData * | data, |
          |  |  | int | channel |
          |  | ) |  |  |  | slot |
          | void axlFieldSpatialCoordinatesCreator::setParameter | ( | double | value, |
          |  |  | int | channel |
          |  | ) |  |  |  | slot |
          | int axlFieldSpatialCoordinatesCreator::update | ( | void |  | ) |  |  | slot |
The documentation for this class was generated from the following files:
