Developer documentation | Axl-2.5.1
axlInspectorTool Class Reference
#include <axlInspectorTool.h>
Inheritance diagram for axlInspectorTool:
Public Slots
void onProcessSelected (QString implementation, QString interface_name)
void onCloseProcessDialog (void)
Signals
void update (void)
void dataInserted (axlAbstractData *data)
void dataSetToRemove (QList< dtkAbstractData * > dataSet)
void dataChanged (dtkAbstractData *data)
void dataChangedByControlPoints (dtkAbstractData *data)
void fieldsCreatedOnData (QList< axlAbstractData * > dataList, QString fieldName)
void modifiedProperty (dtkAbstractData *, int)
Public Member Functions
 axlInspectorTool (QWidget *parent=0)
 ~axlInspectorTool (void)
void setController (axlInspectorObjectController *controller)
void setView (axlAbstractView *view)
Detailed Description
Definition at line 36 of file axlInspectorTool.h.
Constructor & Destructor Documentation
axlInspectorTool::axlInspectorTool ( QWidget *  parent = 0)
Definition at line 53 of file axlInspectorTool.cpp.
axlInspectorTool::~axlInspectorTool ( void  )
Definition at line 64 of file axlInspectorTool.cpp.
Member Function Documentation
void axlInspectorTool::dataChanged ( dtkAbstractData *  data)
signal
void axlInspectorTool::dataChangedByControlPoints ( dtkAbstractData *  data)
signal
void axlInspectorTool::dataInserted ( axlAbstractData data)
signal
void axlInspectorTool::dataSetToRemove ( QList< dtkAbstractData * >  dataSet)
signal
void axlInspectorTool::fieldsCreatedOnData ( QList< axlAbstractData * >  dataList,
QString  fieldName
signal
void axlInspectorTool::modifiedProperty ( dtkAbstractData *  ,
int
signal
void axlInspectorTool::onCloseProcessDialog ( void  )
slot
Definition at line 71 of file axlInspectorTool.cpp.
void axlInspectorTool::onProcessSelected ( QString  implementation,
slot
Definition at line 92 of file axlInspectorTool.cpp.
void axlInspectorTool::setController ( axlInspectorObjectController controller)
Definition at line 342 of file axlInspectorTool.cpp.
void axlInspectorTool::setView ( axlAbstractView view)
Definition at line 347 of file axlInspectorTool.cpp.
void axlInspectorTool::update ( void  )
signal
The documentation for this class was generated from the following files:
