41 #include <dtkCoreSupport/dtkAbstractProcess.h>
   42 #include <dtkCoreSupport/dtkGlobal.h>
   46 class axlInspectorToolPrivate
   58     this->setAttribute(Qt::WA_MacShowFocusRect,
false);
   59     this->setFrameShape(QFrame::NoFrame);
   60     this->setWidgetResizable(
true);
   61     this->setSizePolicy(QSizePolicy::Expanding, QSizePolicy::Minimum);
   72     QObject * obj = QObject::sender();
   75         tool->setVisible(
false);
   77         disconnect(tool, SIGNAL(dataSetFieldsChanged(QList<axlAbstractData*>, QString)), d->view, SLOT(onUpdateActorField(QList<axlAbstractData *>, QString)));
   78         disconnect(tool, SIGNAL(dataSetFieldsChanged(QList<axlAbstractData*>, QString)),
this, SIGNAL(
fieldsCreatedOnData(QList<axlAbstractData *>, QString)));
   84         disconnect(tool, SIGNAL(
update()),
this, SIGNAL(
update()));
   97     if (tool && !dynamic_cast<axlInspectorToolCreator *>(tool)) {
  107         connect(tool, SIGNAL(dataSetFieldsChanged(QList<axlAbstractData*>, QString)), d->view, SLOT(onUpdateActorField(QList<axlAbstractData *>, QString)));
  108         connect(tool, SIGNAL(dataSetFieldsChanged(QList<axlAbstractData*>, QString)),
this, SIGNAL(
  116         connect(tool, SIGNAL(
update()),
this, SIGNAL(
update()));
  120                 if(!(interface_name ==
"FieldGenerator")) {
  121             tool->setAttribute(Qt::WA_DeleteOnClose);
  125         if(interface_name ==
"FieldGenerator") {
  126             connect(tool, SIGNAL(dataSetFieldsChanged(QList<axlAbstractData*>, QString)), d->view, SLOT(onUpdateActorField(QList<axlAbstractData *>, QString)));
  127             connect(tool, SIGNAL(dataSetFieldsChanged(QList<axlAbstractData*>, QString)),
this, SIGNAL(
  131         this->setWidget(tool);
  134     }
else if(interface_name ==
"axlAbstractCreator") {
  136         if(implementation ==
"axlLineCreator") {
  143                 qDebug()<<
"No controller founded for InspectorTool";
  146             this->setWidget(tool);
  147             tool->setAttribute(Qt::WA_DeleteOnClose);
  150         else if(implementation ==
"axlConeCreator") {
  157                 qDebug()<<
  162             this->setWidget(tool);
  163             tool->setAttribute(Qt::WA_DeleteOnClose);
  166         else if(implementation ==
"axlCylinderCreator") {
  173                 qDebug()<<
  178             this->setWidget(tool);
  179             tool->setAttribute(Qt::WA_DeleteOnClose);
  182         else if(implementation ==
"axlTorusCreator") {
  189                 qDebug()<<
  194             this->setWidget(tool);
  195             tool->setAttribute(Qt::WA_DeleteOnClose);
  199         else if(implementation ==
"axlCircleArcCreator") {
  206                 qDebug()<<
  209             this->setWidget(tool);
  210             tool->setAttribute(Qt::WA_DeleteOnClose);
  213         else if(implementation ==
"axlEllipsoidCreator") {
  220                 qDebug()<<
  223             this->setWidget(tool);
  224             tool->setAttribute(Qt::WA_DeleteOnClose);
  228         else if(implementation ==
"axlPlaneCreator") {
  235                 qDebug()<<
  238             this->setWidget(tool);
  239             tool->setAttribute(Qt::WA_DeleteOnClose);
  243         if(implementation ==
"axlPointCreator") {
  250                 qDebug()<<
  253             this->setWidget(tool);
  254             tool->setAttribute(Qt::WA_DeleteOnClose);
  270         if(implementation ==
"axlSphereCreator") {
  277                 qDebug()<<
  282             this->setWidget(tool);
  283             tool->setAttribute(Qt::WA_DeleteOnClose);
  286         if(implementation ==
"axlDataDynamicCreator") {
  293                 qDebug()<<
  296             this->setWidget(tool);
  297             tool->setAttribute(Qt::WA_DeleteOnClose);
  303     else if(interface_name ==
"FieldGenerator") {
  310             qDebug()<<
  312         connect(tool, SIGNAL(dataSetFieldsChanged(QList<axlAbstractData*>, QString)), d->view, SLOT(onUpdateActorField(QList<axlAbstractData *>, QString)));
  313         connect(tool, SIGNAL(dataSetFieldsChanged(QList<axlAbstractData*>, QString)),
this, SIGNAL(
  315         this->setWidget(tool);
  329         connect(tool, SIGNAL(dataSetFieldsChanged(QList<axlAbstractData*>, QString)), d->view, SLOT(onUpdateActorField(QList<axlAbstractData *>, QString)));
  330         connect(tool, SIGNAL(dataSetFieldsChanged(QList<axlAbstractData*>, QString)),
this, SIGNAL(
  333         this->setWidget(tool);
  337     if (this->widget() && this->widget()->layout()) {
  338         this->widget()->layout()->setAlignment(Qt::AlignTop);
  344     d->controller = controller;
Class axlAbstractData defines an API for all type of axel data.
