Developer documentation | Axl-2.5.1
axlIntersection Class Reference
#include <axlIntersection.h>
Inheritance diagram for axlIntersection:
axlAbstractProcess
Signals
void dataInserted (axlAbstractData *data)
Public Member Functions
 axlIntersection (QObject *parent=0)
 ~axlIntersection (void)
axlAbstractData * getInput (int channel) const
virtual int update (void)
QString description (void) const
QString identifier (void) const
dtkAbstractData * output (void)
void setInput (dtkAbstractData *newData, int channel)
int channelCount (void)
QString form (void) const
 Description of the form for the dialog with the process. More...
- Public Member Functions inherited from axlAbstractProcess
 axlAbstractProcess (void)
virtual ~axlAbstractProcess (void)
virtual void copyProcess (axlAbstractProcess *process)
virtual bool hasParameters (void)
virtual void setDescription (QString description)
virtual void setIdentifier (QString identifier)
Detailed Description
Definition at line 30 of file axlIntersection.h.
Constructor & Destructor Documentation
axlIntersection::axlIntersection ( QObject *  parent = 0)
Definition at line 36 of file axlIntersection.cpp.
axlIntersection::~axlIntersection ( void  )
Definition at line 43 of file axlIntersection.cpp.
Member Function Documentation
int axlIntersection::channelCount ( void  )
Definition at line 80 of file axlIntersection.cpp.
void axlIntersection::dataInserted ( axlAbstractData *  data)
signal
QString axlIntersection::description ( void  ) const
virtual
Reimplemented from axlAbstractProcess.
Definition at line 140 of file axlIntersection.cpp.
QString axlIntersection::form ( void  ) const
inlinevirtual
The string use to describe the form is formatted as follows:
"INPUT[:CHANNEL] TYPE LABEL"
"PARAMETER[:CHANNEL] TYPE LABEL"
"OUTPUT [:CHANNEL] LABEL"
where:
  • CHANNEL is a number identifying the rank of an input, see dtkAbstractProcess. Write this value only if the process method setInput uses a channel in its parameters !
  • TYPE is either int, double or data.
  • LABEL is the input's name.
Here is an example of such a declaration:
QString form(void) const
return QString(
" INPUT:0 data StartPoint \n"
" INPUT:1 data EndPoint \n"
" PARAMETER:0 double Radius \n"
" OUTPUT Cylinder ");
Definition at line 57 of file axlIntersection.h.
axlAbstractData * axlIntersection::getInput ( int  channel) const
Definition at line 49 of file axlIntersection.cpp.
QString axlIntersection::identifier ( void  ) const
virtual
Definition at line 145 of file axlIntersection.cpp.
dtkAbstractData * axlIntersection::output ( void  )
Definition at line 64 of file axlIntersection.cpp.
void axlIntersection::setInput ( dtkAbstractData *  newData,
int  channel
Definition at line 70 of file axlIntersection.cpp.
int axlIntersection::update ( void  )
virtual
Definition at line 86 of file axlIntersection.cpp.
The documentation for this class was generated from the following files:
