| | axlPlaneParametric (axlAbstractSurfaceParametric *parent=0) |
| | axlPlaneParametric (axlPlane *plane, axlPoint *i) |
| | axlPlaneParametric (const axlPlane &plane, const axlPoint &i) |
| | axlPlaneParametric (const axlPlaneParametric &other) |
| virtual | ~axlPlaneParametric (void) |
| virtual QString | description (void) const |
| virtual QString | identifier (void) const |
| void | setPlane (const axlPlane &plane) |
| void | setI (axlPoint *i) |
| void | setJ (axlPoint *j) |
| axlPlaneParametric & | operator= (const axlPlaneParametric &other) |
| void | modifyI (double *i) |
| void | modifyJ (double *j) |
| axlPlane * | getPlane (void) const |
| axlPoint * | getI (void) const |
| axlPoint * | getJ (void) const |
| virtual axlPoint | eval (double u, double v) |
| virtual void | eval (axlPoint *point, double u, double v) |
| virtual void | eval (double &x, double &y, double &z, double u, double v) |
| virtual void | normal (axlPoint *normal, double, double) |
| virtual void | parameterOf (const axlPoint &point, double &u, double &v) |
| | axlAbstractSurfaceParametric (void) |
| virtual | ~axlAbstractSurfaceParametric (void) |
| virtual axlMesh | eval (double u, double v, int derivs, bool u_from_right=true, bool v_from_right=true, double resolution=1.0e-12) |
| virtual dtkDeprecated::dtkVector3D< double > | eval2 (double u, double v) |
| virtual dtkDeprecated::dtkVector3D< double > | normal (double u, double v) |
| virtual void | normal (dtkDeprecated::dtkVector3D< double > *normal, double u, double v) |
| virtual double | area (double tol) |
| virtual int | numSamples_u (void) |
| virtual int | numSamples_v (void) |
| virtual double | startParam_u (void) |
| virtual double | endParam_u (void) |
| virtual double | startParam_v (void) |
| virtual double | endParam_v (void) |
| virtual double | startParam_u (int numCell) |
| virtual double | endParam_u (int numCell) |
| virtual double | startParam_v (int numCell) |
| virtual double | endParam_v (int numCell) |
| virtual void | eval (axlPoint *point, double u, double v, int numCell) |
| virtual void | normal (axlPoint *normal, double u, double v, int numCell) |
| virtual bool | hasCells (void) |
| virtual int | countCells (void) |
| virtual int | numSamples_u (int numCell) |
| virtual int | numSamples_v (int numCell) |
| virtual int | stripes (void) |
| virtual void | setStripes (int stripes) |
| virtual void | setNumSamples_u (int numSamples) |
| virtual void | setNumSamples_v (int numSamples) |
| const int & | samples_u (void) const |
| const int & | samples_v (void) const |
| | axlAbstractSurface (void) |
| virtual | ~axlAbstractSurface (void) |
| virtual int | dimension (void) const |
| virtual axlMesh * | toAxlMesh (void) |
| virtual void * | surface (void) |
| | axlAbstractData (axlAbstractData *parent=NULL) |
| | axlAbstractData (const axlAbstractData &data) |
| virtual | ~axlAbstractData (void) |
| const QColor & | color (void) const |
| const double & | opacity (void) const |
| const double & | size (void) const |
| const QString & | shader (void) const |
| const bool & | editable (void) |
| const bool & | updateView (void) |
| void | setColor (double r, double g, double b) |
| void | addField (axlAbstractField *field) |
| | Add a field to the field list of the object. More...
| bool | updateFieldList (QString nameField) |
| | Check if a field with the same name is already applied on the object. More...
| QString | changeFieldName (QString fieldName) |
| axlMesh * | mesh (void) |
| | Return the mesh of that object is computed. More...
| void | setMesh (axlMesh *mesh) |
| | Set a corresponding mesh for that object. More...
| virtual QVariantList | convertDataToQVariant (void) const |
| | Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData. More...
| virtual int | convertQVariantToData (const QVariantList &data) |
| | Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0. More...
| void | setUpdateView (bool updateView) |
| QList< axlAbstractField * > | fields (void) |
Definition at line 29 of file axlPlaneParametric.h.
