Class axlSphere defines 3D spheres. More...
#include <axlSphere.h>
 | Public Slots | |
| void | onXChanged (double x) |
| void | onYChanged (double y) |
| void | onZChanged (double z) |
| void | onRadiusChanged (double radius) |
|  Public Slots inherited from axlAbstractData | |
| void | touchGeometry (void) |
| void | touchProperty (void) |
| void | touchStructure (void) |
| virtual void | touchField (void) |
| void | setColor (const QColor &color) |
| void | setOpacity (const double &opacity) |
| void | setSize (const double &size) |
| void | setShader (const QString &shader) |
| void | setEditable (bool edit) |
| Public Member Functions | |
| axlSphere (QObject *parent=0) | |
| Constructs a axel sphere of zero coordinates and 1.0 radius with parent parent of QObject type.  More... | |
| axlSphere (double x, double y, double z=0, double radius=1.0, QObject *parent=0) | |
| Constructs a axel sphere of coordinates (x, y, z) and radius (radius) with parent parent of QObject type.  More... | |
| axlSphere (const axlSphere &other) | |
| Constructs a copy of other.  More... | |
| ~axlSphere (void) | |
| Destroys the axel sphere.  More... | |
| virtual QString | description (void) const |
| virtual QString | identifier (void) const |
| double | x (void) const |
| Returns x-coordinate of this sphere.  More... | |
| double | y (void) const |
| Returns y-coordinate of this sphere.  More... | |
| double | z (void) const |
| Returns z-coordinate of this sphere.  More... | |
| double * | coordinates (void) const |
| Returns coordinates of this sphere.  More... | |
| double | radius (void) const |
| void | setRadius (double radius) |
| void | touchRadius (double radius) |
| void | touchCenter (axlPoint center) |
| axlPoint | centerPoint (void) |
| void | setValues (double x, double y, double z, double radius) |
| Change coordinates of this sphere.  More... | |
| void | setCenter (double x, double y, double z) |
| void | normalize () |
| axlSphere & | operator= (const axlSphere &other) |
| Assigns other to this sphere and returns a reference to this sphere.  More... | |
| axlSphere & | operator+= (const axlSphere &other) |
| Adds the coordinates and radius of the other sphere to this sphere and returns a reference to this sphere.  More... | |
| axlSphere & | operator-= (const axlSphere &other) |
| Substracts the coordinates and radius of the other sphere to this sphere and returns a reference to this sphere.  More... | |
| axlSphere & | operator*= (double scalar) |
| Multiplies the coordinates and radius of this sphere by a scalar value and returns a reference to this sphere.  More... | |
| axlSphere & | operator/= (double scalar) |
| Divides the coordinates and radius of this sphere by a scalar value and returns a reference to this sphere.  More... | |
| axlSphere | operator+ (const axlSphere &other) const |
| Returns a sphere that results from the addition of this sphere and the other sphere.  More... | |
| axlSphere | operator- (const axlSphere &other) const |
| Returns a sphere that results from the substraction of this sphere and the other sphere.  More... | |
| axlSphere | operator* (double scalar) const |
| Returns a sphere that results from the multiplication of the scalar with this sphere.  More... | |
| axlSphere | operator/ (double scalar) const |
| Returns a sphere that results from the division of the scalar with this sphere.  More... | |
| QVariantList | convertDataToQVariant (void) const |
| Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData.  More... | |
| int | convertQVariantToData (const QVariantList &data) |
| Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0.  More... | |
|  Public Member Functions inherited from axlAbstractData | |
| axlAbstractData (axlAbstractData *parent=NULL) | |
| axlAbstractData (const axlAbstractData &data) | |
| virtual | ~axlAbstractData (void) |
| const QColor & | color (void) const |
| const double & | opacity (void) const |
| const double & | size (void) const |
| const QString & | shader (void) const |
| const bool & | editable (void) |
| const bool & | updateView (void) |
| void | setColor (double r, double g, double b) |
| void | addField (axlAbstractField *field) |
| Add a field to the field list of the object.  More... | |
| bool | updateFieldList (QString nameField) |
| Check if a field with the same name is already applied on the object.  More... | |
| QString | changeFieldName (QString fieldName) |
| axlMesh * | mesh (void) |
| Return the mesh of that object is computed.  More... | |
| void | setMesh (axlMesh *mesh) |
| Set a corresponding mesh for that object.  More... | |
| void | setUpdateView (bool updateView) |
| QList< axlAbstractField * > | fields (void) |
| Static Public Member Functions | |
| static double | distance (const axlSphere &lhs, const axlSphere &rhs) |
| Returns the distance between lhs sphere and rhs sphere.  More... | |
| static double | distance (axlSphere *lhs, axlSphere *rhs) |
| Properties | |
| double | radius |
| axlPoint | center |
|  Properties inherited from axlAbstractData | |
| QColor | color |
| double | opacity |
| double | size |
| QString | shader |
| Friends | |
| QDebug | operator<< (QDebug dbg, axlSphere sphere) |
| QDebug | operator<< (QDebug dbg, axlSphere &sphere) |
| QDebug | operator<< (QDebug dbg, axlSphere *sphere) |
| Additional Inherited Members | |
|  Signals inherited from axlAbstractData | |
| void | modifiedGeometry (void) |
| void | modifiedStructure (void) |
| void | modifiedField (void) |
| void | modifiedProperty (void) |
This class enables to represent and manipulate 3D spheres.
Example:
Definition at line 33 of file axlSphere.h.
| axlSphere::axlSphere | ( | QObject * | parent = 0 | ) |
The parent of an object may be viewed as the object's owner. The destructor of a parent object destroys all child objects. Setting parent to 0 constructs a axel sphere with no parent.
Definition at line 46 of file axlSphere.cpp.
| axlSphere::axlSphere | ( | double | x, |
| double | y, | ||
| double | z = 0, | ||
| double | radius = 1.0, | ||
| QObject * | parent = 0 | ||
Definition at line 61 of file axlSphere.cpp.
| axlSphere::axlSphere | ( | const axlSphere & | other | ) |
Definition at line 75 of file axlSphere.cpp.
| axlSphere::~axlSphere | ( | void | ) |
Definition at line 90 of file axlSphere.cpp.
| axlPoint axlSphere::centerPoint | ( | void | ) |
Definition at line 283 of file axlSphere.cpp.
 | virtual |
Reimplemented from axlAbstractData.
Definition at line 421 of file axlSphere.cpp.
 | virtual |
Definition at line 439 of file axlSphere.cpp.
| double * axlSphere::coordinates | ( | void | ) | const |
Definition at line 325 of file axlSphere.cpp.
 | virtual |
Definition at line 382 of file axlSphere.cpp.
The distance is always positive.
Definition at line 334 of file axlSphere.cpp.
Definition at line 347 of file axlSphere.cpp.
 | virtual |
Definition at line 389 of file axlSphere.cpp.
| void axlSphere::normalize | ( | void | ) |
Definition at line 310 of file axlSphere.cpp.
 | slot |
Definition at line 415 of file axlSphere.cpp.
 | slot |
Definition at line 400 of file axlSphere.cpp.
 | slot |
Definition at line 405 of file axlSphere.cpp.
 | slot |
Definition at line 410 of file axlSphere.cpp.
| axlSphere axlSphere::operator* | ( | double | scalar | ) | const |
Definition at line 202 of file axlSphere.cpp.
| axlSphere & axlSphere::operator*= | ( | double | scalar | ) |
Definition at line 143 of file axlSphere.cpp.
Definition at line 176 of file axlSphere.cpp.
Definition at line 115 of file axlSphere.cpp.
Definition at line 189 of file axlSphere.cpp.
Definition at line 129 of file axlSphere.cpp.
| axlSphere axlSphere::operator/ | ( | double | scalar | ) | const |
If the scalar value is zero, it returns a default sphere.
Definition at line 215 of file axlSphere.cpp.
| axlSphere & axlSphere::operator/= | ( | double | scalar | ) |
If the scalar value is zero, the sphere remains unchanged.
Definition at line 157 of file axlSphere.cpp.
Definition at line 101 of file axlSphere.cpp.
| double axlSphere::radius | ( | void | ) | const |
Definition at line 257 of file axlSphere.cpp.
| void axlSphere::setCenter | ( | double | x, |
| double | y, | ||
| double | z | ||
Definition at line 302 of file axlSphere.cpp.
| void axlSphere::setRadius | ( | double | radius | ) |
Definition at line 262 of file axlSphere.cpp.
| void axlSphere::setValues | ( | double | x, |
| double | y, | ||
| double | z, | ||
| double | radius | ||
Definition at line 293 of file axlSphere.cpp.
| void axlSphere::touchCenter | ( | axlPoint | center | ) |
Definition at line 274 of file axlSphere.cpp.
| void axlSphere::touchRadius | ( | double | radius | ) |
Definition at line 268 of file axlSphere.cpp.
| double axlSphere::x | ( | void | ) | const |
Definition at line 234 of file axlSphere.cpp.
| double axlSphere::y | ( | void | ) | const |
Definition at line 243 of file axlSphere.cpp.
| double axlSphere::z | ( | void | ) | const |
Definition at line 252 of file axlSphere.cpp.
 | friend |
Definition at line 361 of file axlSphere.cpp.
 | friend |
Definition at line 368 of file axlSphere.cpp.
 | friend |
Definition at line 375 of file axlSphere.cpp.
 | readwrite |
Definition at line 36 of file axlSphere.h.
 | readwrite |
