Developer documentation | Axl-2.5.1
axlSphereCreator Class Reference
#include <axlSphereCreator.h>
Inheritance diagram for axlSphereCreator:
axlAbstractCreatorProcess axlAbstractProcess
Public Member Functions
 axlSphereCreator (QObject *parent=0)
virtual ~axlSphereCreator (void)
virtual axlAbstractDatagetInput (int channel) const
void copyProcess (axlAbstractProcess *process)
bool hasParameters (void)
virtual int update (void)
virtual QString description (void) const
virtual QString identifier (void) const
virtual void setInput (dtkAbstractData *newData, int channel)
virtual void setParameter (double data)
virtual dtkAbstractData * output (void)
- Public Member Functions inherited from axlAbstractCreatorProcess
 axlAbstractCreatorProcess (QObject *parent=0)
virtual ~axlAbstractCreatorProcess (void)
virtual dtkAbstractData * output (int channel)
virtual int channelCount (void)
- Public Member Functions inherited from axlAbstractProcess
 axlAbstractProcess (void)
virtual ~axlAbstractProcess (void)
virtual void setDescription (QString description)
virtual void setIdentifier (QString identifier)
virtual QString form (void) const
 Description of the form for the dialog with the process. More...
Detailed Description
Definition at line 29 of file axlSphereCreator.h.
Constructor & Destructor Documentation
axlSphereCreator::axlSphereCreator ( QObject *  parent = 0)
Definition at line 37 of file axlSphereCreator.cpp.
axlSphereCreator::~axlSphereCreator ( void  )
virtual
Definition at line 44 of file axlSphereCreator.cpp.
Member Function Documentation
void axlSphereCreator::copyProcess ( axlAbstractProcess process)
virtual
Reimplemented from axlAbstractProcess.
Definition at line 54 of file axlSphereCreator.cpp.
QString axlSphereCreator::description ( void  ) const
virtual
Reimplemented from axlAbstractCreatorProcess.
Definition at line 107 of file axlSphereCreator.cpp.
axlAbstractData * axlSphereCreator::getInput ( int  channel) const
virtual
Definition at line 50 of file axlSphereCreator.cpp.
bool axlSphereCreator::hasParameters ( void  )
virtual
returns true if the process needs parameters. By default, equals false.
Definition at line 60 of file axlSphereCreator.cpp.
QString axlSphereCreator::identifier ( void  ) const
virtual
Definition at line 112 of file axlSphereCreator.cpp.
dtkAbstractData * axlSphereCreator::output ( void  )
virtual
Definition at line 65 of file axlSphereCreator.cpp.
void axlSphereCreator::setInput ( dtkAbstractData *  newData,
int  channel
virtual
Definition at line 70 of file axlSphereCreator.cpp.
void axlSphereCreator::setParameter ( double  data)
virtual
Definition at line 80 of file axlSphereCreator.cpp.
int axlSphereCreator::update ( void  )
virtual
Definition at line 85 of file axlSphereCreator.cpp.
The documentation for this class was generated from the following files:
