#include <axlTabulatedCylinder.h>
Public Member Functions | |
| axlTabulatedCylinder (QObject *parent=0) | |
| ~axlTabulatedCylinder () | |
| axlAbstractCurve | get_directrix () const |
| axlAbstractCurve * | get_pt_directrix () const |
| axlPoint & | get_ref_generatrix () const |
| axlPoint * | get_pt_generatrix () |
| void | set_generatrix (const axlPoint &vector) |
| void | set_generatrix (axlPoint *vector) |
| void | set_directrix (axlAbstractCurve *curve) |
| void | set_directrix (const axlAbstractCurve &curve) |
| virtual QString | description (void) const |
| virtual QString | identifier (void) const |
| axlTabulatedCylinder & | operator= (const axlTabulatedCylinder &other) |
Public Member Functions inherited from axlAbstractSurface | |
| axlAbstractSurface (void) | |
| virtual | ~axlAbstractSurface (void) |
| virtual int | dimension (void) const |
| virtual axlMesh * | toAxlMesh (void) |
| virtual void * | surface (void) |
Public Member Functions inherited from axlAbstractData | |
| axlAbstractData (axlAbstractData *parent=NULL) | |
| axlAbstractData (const axlAbstractData &data) | |
| virtual | ~axlAbstractData (void) |
| const QColor & | color (void) const |
| const double & | opacity (void) const |
| const double & | size (void) const |
| const QString & | shader (void) const |
| const bool & | editable (void) |
| const bool & | updateView (void) |
| void | setColor (double r, double g, double b) |
| void | addField (axlAbstractField *field) |
| Add a field to the field list of the object. More... | |
| bool | updateFieldList (QString nameField) |
| Check if a field with the same name is already applied on the object. More... | |
| QString | changeFieldName (QString fieldName) |
| axlMesh * | mesh (void) |
| Return the mesh of that object is computed. More... | |
| void | setMesh (axlMesh *mesh) |
| Set a corresponding mesh for that object. More... | |
| virtual QVariantList | convertDataToQVariant (void) const |
| Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData. More... | |
| virtual int | convertQVariantToData (const QVariantList &data) |
| Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0. More... | |
| void | setUpdateView (bool updateView) |
| QList< axlAbstractField * > | fields (void) |
Additional Inherited Members | |
Public Slots inherited from axlAbstractData | |
| void | touchGeometry (void) |
| void | touchProperty (void) |
| void | touchStructure (void) |
| virtual void | touchField (void) |
| void | setColor (const QColor &color) |
| void | setOpacity (const double &opacity) |
| void | setSize (const double &size) |
| void | setShader (const QString &shader) |
| void | setEditable (bool edit) |
Signals inherited from axlAbstractData | |
| void | modifiedGeometry (void) |
| void | modifiedStructure (void) |
| void | modifiedField (void) |
| void | modifiedProperty (void) |
Properties inherited from axlAbstractData | |
| QColor | color |
| double | opacity |
| double | size |
| QString | shader |
Definition at line 23 of file axlTabulatedCylinder.h.
| axlTabulatedCylinder::axlTabulatedCylinder | ( | QObject * | parent = 0 | ) |
Definition at line 13 of file axlTabulatedCylinder.cpp.
| axlTabulatedCylinder::~axlTabulatedCylinder | ( | ) |
Definition at line 18 of file axlTabulatedCylinder.cpp.
virtual |
Definition at line 64 of file axlTabulatedCylinder.cpp.
| axlAbstractCurve axlTabulatedCylinder::get_directrix | ( | ) | const |
Definition at line 24 of file axlTabulatedCylinder.cpp.
| axlAbstractCurve * axlTabulatedCylinder::get_pt_directrix | ( | ) | const |
Definition at line 29 of file axlTabulatedCylinder.cpp.
| axlPoint * axlTabulatedCylinder::get_pt_generatrix | ( | ) |
Definition at line 39 of file axlTabulatedCylinder.cpp.
| axlPoint & axlTabulatedCylinder::get_ref_generatrix | ( | ) | const |
Definition at line 34 of file axlTabulatedCylinder.cpp.
virtual |
Definition at line 70 of file axlTabulatedCylinder.cpp.
| axlTabulatedCylinder & axlTabulatedCylinder::operator= | ( | const axlTabulatedCylinder & | other | ) |
Definition at line 75 of file axlTabulatedCylinder.cpp.
| void axlTabulatedCylinder::set_directrix | ( | axlAbstractCurve * | curve | ) |
Definition at line 54 of file axlTabulatedCylinder.cpp.
| void axlTabulatedCylinder::set_directrix | ( | const axlAbstractCurve & | curve | ) |
Definition at line 59 of file axlTabulatedCylinder.cpp.
| void axlTabulatedCylinder::set_generatrix | ( | const axlPoint & | vector | ) |
Definition at line 44 of file axlTabulatedCylinder.cpp.
| void axlTabulatedCylinder::set_generatrix | ( | axlPoint * | vector | ) |
Definition at line 49 of file axlTabulatedCylinder.cpp.
