Developer documentation | Axl-2.5.1
axlTrimmedParametricSurface Class Reference
#include <axlTrimmedParametricSurface.h>
Inheritance diagram for axlTrimmedParametricSurface:
axlAbstractSurface axlAbstractData
Public Member Functions
 axlTrimmedParametricSurface (QObject *parent=0)
 axlTrimmedParametricSurface (axlCurveOnParamSurface *outer, QList< axlCurveOnParamSurface * > inner)
 ~axlTrimmedParametricSurface ()
void setSurfaceBeTrimmed (axlAbstractSurface *surf)
void setOuterIsBoundary (bool outerIsBoundaryOrNot)
void setOuter (axlCurveOnParamSurface *outer)
void setInner (QList< axlCurveOnParamSurface * > list_inner)
void addInner (axlCurveOnParamSurface *inner)
void addListInner (QList< axlCurveOnParamSurface * > list_inner)
axlCurveOnParamSurfacegetOuter () const
axlAbstractSurfaceParametricgetSurface () const
axlAbstractSurfacegetSurface ()
bool getouterIsBoundaryOrNot ()
QList< axlCurveOnParamSurface * > & getInner () const
axlCurveOnParamSurfacegetInner (int id)
virtual QString description (void) const
virtual QString identifier (void) const
axlTrimmedParametricSurfaceoperator= (const axlTrimmedParametricSurface &other)
- Public Member Functions inherited from axlAbstractSurface
 axlAbstractSurface (void)
virtual ~axlAbstractSurface (void)
virtual int dimension (void) const
virtual axlMeshtoAxlMesh (void)
virtual void * surface (void)
- Public Member Functions inherited from axlAbstractData
 axlAbstractData (axlAbstractData *parent=NULL)
 axlAbstractData (const axlAbstractData &data)
virtual ~axlAbstractData (void)
const QColor & color (void) const
const double & opacity (void) const
const double & size (void) const
const QString & shader (void) const
const bool & editable (void)
const bool & updateView (void)
void setColor (double r, double g, double b)
void addField (axlAbstractField *field)
 Add a field to the field list of the object. More...
bool updateFieldList (QString nameField)
 Check if a field with the same name is already applied on the object. More...
QString changeFieldName (QString fieldName)
axlMeshmesh (void)
 Return the mesh of that object is computed. More...
void setMesh (axlMesh *mesh)
 Set a corresponding mesh for that object. More...
virtual QVariantList convertDataToQVariant (void) const
 Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData. More...
virtual int convertQVariantToData (const QVariantList &data)
 Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0. More...
void setUpdateView (bool updateView)
QList< axlAbstractField * > fields (void)
Additional Inherited Members
- Public Slots inherited from axlAbstractData
void touchGeometry (void)
void touchProperty (void)
void touchStructure (void)
virtual void touchField (void)
void setColor (const QColor &color)
void setOpacity (const double &opacity)
void setSize (const double &size)
void setShader (const QString &shader)
void setEditable (bool edit)
- Signals inherited from axlAbstractData
void modifiedGeometry (void)
void modifiedStructure (void)
void modifiedField (void)
void modifiedProperty (void)
- Properties inherited from axlAbstractData
QColor color
double opacity
double size
QString shader
Detailed Description
Definition at line 31 of file axlTrimmedParametricSurface.h.
Constructor & Destructor Documentation
axlTrimmedParametricSurface::axlTrimmedParametricSurface ( QObject *  parent = 0)
Definition at line 12 of file axlTrimmedParametricSurface.cpp.
axlTrimmedParametricSurface::axlTrimmedParametricSurface ( axlCurveOnParamSurface outer,
Definition at line 22 of file axlTrimmedParametricSurface.cpp.
axlTrimmedParametricSurface::~axlTrimmedParametricSurface ( )
Definition at line 28 of file axlTrimmedParametricSurface.cpp.
Member Function Documentation
void axlTrimmedParametricSurface::addInner ( axlCurveOnParamSurface inner)
Definition at line 68 of file axlTrimmedParametricSurface.cpp.
void axlTrimmedParametricSurface::addListInner ( QList< axlCurveOnParamSurface * >  list_inner)
Definition at line 73 of file axlTrimmedParametricSurface.cpp.
QString axlTrimmedParametricSurface::description ( void  ) const
virtual
Definition at line 34 of file axlTrimmedParametricSurface.cpp.
QList< axlCurveOnParamSurface * > & axlTrimmedParametricSurface::getInner ( ) const
Definition at line 98 of file axlTrimmedParametricSurface.cpp.
axlCurveOnParamSurface * axlTrimmedParametricSurface::getInner ( int  id)
Definition at line 107 of file axlTrimmedParametricSurface.cpp.
axlCurveOnParamSurface & axlTrimmedParametricSurface::getOuter ( ) const
Definition at line 78 of file axlTrimmedParametricSurface.cpp.
axlCurveOnParamSurface * axlTrimmedParametricSurface::getOuter ( )
Definition at line 83 of file axlTrimmedParametricSurface.cpp.
bool axlTrimmedParametricSurface::getouterIsBoundaryOrNot ( )
Definition at line 103 of file axlTrimmedParametricSurface.cpp.
axlAbstractSurfaceParametric & axlTrimmedParametricSurface::getSurface ( ) const
Definition at line 88 of file axlTrimmedParametricSurface.cpp.
axlAbstractSurface * axlTrimmedParametricSurface::getSurface ( )
Definition at line 93 of file axlTrimmedParametricSurface.cpp.
QString axlTrimmedParametricSurface::identifier ( void  ) const
virtual
Definition at line 40 of file axlTrimmedParametricSurface.cpp.
axlTrimmedParametricSurface & axlTrimmedParametricSurface::operator= ( const axlTrimmedParametricSurface other)
Definition at line 112 of file axlTrimmedParametricSurface.cpp.
void axlTrimmedParametricSurface::setInner ( QList< axlCurveOnParamSurface * >  list_inner)
Definition at line 59 of file axlTrimmedParametricSurface.cpp.
void axlTrimmedParametricSurface::setOuter ( axlCurveOnParamSurface outer)
Definition at line 49 of file axlTrimmedParametricSurface.cpp.
void axlTrimmedParametricSurface::setOuterIsBoundary ( bool  outerIsBoundaryOrNot)
Definition at line 54 of file axlTrimmedParametricSurface.cpp.
void axlTrimmedParametricSurface::setSurfaceBeTrimmed ( axlAbstractSurface surf)
Definition at line 44 of file axlTrimmedParametricSurface.cpp.
The documentation for this class was generated from the following files:
