20 #ifndef AXLABSTRACTVOLUMEBSPLINE_H
   21 #define AXLABSTRACTVOLUMEBSPLINE_H
   24 #include "axlCoreExport.h"
   26 #include <dtkMathSupport/dtkVector3D.h>
   28 class axlAbstractVolumeBSplinePrivate;
   38     using   axlAbstractVolumeParametric::copy;
   41     virtual int countControlPoints(
void)
const;
   42     virtual int countControlPoints_u(
void)
const;
   43     virtual int countControlPoints_v(
void)
const;
   44     virtual int countControlPoints_w(
void)
const;
   46     virtual int knotVectorSize_u(
void)
const;
   47     virtual int knotVectorSize_v(
void)
const;
   48     virtual int knotVectorSize_w(
void)
const;
   50     virtual int order_u(
void)
const;
   51     virtual int order_v(
void)
const;
   52     virtual int order_w(
void)
const;
   54     virtual double   getCoord(
int n,
int m,
int k,
int v)
const;
   55     virtual axlPoint getCoef(
int n,
int m,
int k)
const;
   56     virtual axlPoint getCoef(
int n)
const;
   59     virtual double getWeight(
int n,
int m,
int k)
const;
   61     virtual bool setCoef(
int n,
int m,
int k,
int v,
double c);
   62     virtual bool setCoef(
int n,
int m,
int k,
double *controlPoint);
   63     virtual bool setCoef(
int n,
   65     virtual double getKnot_u(
int n)
const;
   66     virtual double getKnot_v(
int n)
const;
   67     virtual double getKnot_w(
int n)
const;
   69     virtual void setVolume(
int pointsCount_u,
int pointsCount_v,
int pointsCount_w,
int order_u,
int order_v,
int order_w,
int dimension,
double *knots_u,
double *knots_v,
double *knots_w,
double *points,
bool rational);
   71     virtual void insertKnot_u(
double k);
   72     virtual void removeKnot_u(
double k);
   74     virtual void insertKnot_v(
double k);
   75     virtual void removeKnot_v(
double k);
   77     virtual void insertKnot_w(
double k);
   78     virtual void removeKnot_w(
double k);
   80     virtual bool rational(
void)
const;
   82     virtual QVector<axlPoint *> sampling();
   84     virtual void gridEvaluator(
int num_u,
int num_v,
int num_w, std::vector<double>& points, std::vector<double>& param_u, std::vector<double>& param_v,std::vector<double>& param_w);
   86     virtual QString printCoeffs(
bool print)
const;
   87     virtual QString printKnotsVector(
bool print)
const;
   89     virtual QString description(
void)
const;
   91     virtual void updateRcoeff();
   94     double scalarValue(
double u,
double v,
double w);
   95     void setScalarValue(
double u,
double v,
double w,
double value);
   99     virtual bool connectionsAreDefined(
void);
  100     virtual QList<int> getControlPointConnection(
int i);
  101     virtual void defineControlPointConnection(
int i,
int j);
  103     virtual void resetControlPointConnections(
void);
  113     void samplingChanged(
void);
  114     void indexSelected(
int);
  117     axlAbstractVolumeBSplinePrivate *d;
Class axlPoint defines 3D points.
virtual int convertQVariantToData(const QVariantList &data)
Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was suc...
virtual QVariantList convertDataToQVariant(void) const
Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData...
virtual void selectIndex(int i)
