#include <axlAbstractVolumeBSpline.h>
Signals | |
| void | updated (void) |
| void | samplingChanged (void) |
| void | indexSelected (int) |
Signals inherited from axlAbstractData | |
| void | modifiedGeometry (void) |
| void | modifiedStructure (void) |
| void | modifiedField (void) |
| void | modifiedProperty (void) |
Public Member Functions | |
| axlAbstractVolumeBSpline (void) | |
| virtual | ~axlAbstractVolumeBSpline (void) |
| virtual axlAbstractVolumeBSpline * | copy (void) const |
| virtual int | countControlPoints (void) const |
| virtual int | countControlPoints_u (void) const |
| virtual int | countControlPoints_v (void) const |
| virtual int | countControlPoints_w (void) const |
| virtual int | knotVectorSize_u (void) const |
| virtual int | knotVectorSize_v (void) const |
| virtual int | knotVectorSize_w (void) const |
| virtual int | order_u (void) const |
| virtual int | order_v (void) const |
| virtual int | order_w (void) const |
| virtual double | getCoord (int n, int m, int k, int v) const |
| virtual axlPoint | getCoef (int n, int m, int k) const |
| virtual axlPoint | getCoef (int n) const |
| virtual double | getWeight (int n, int m, int k) const |
| virtual bool | setCoef (int n, int m, int k, int v, double c) |
| virtual bool | setCoef (int n, int m, int k, double *controlPoint) |
| virtual bool | setCoef (int n, double *controlPoint) |
| virtual double | getKnot_u (int n) const |
| virtual double | getKnot_v (int n) const |
| virtual double | getKnot_w (int n) const |
| virtual void | setVolume (int pointsCount_u, int pointsCount_v, int pointsCount_w, int order_u, int order_v, int order_w, int dimension, double *knots_u, double *knots_v, double *knots_w, double *points, bool rational) |
| virtual void | insertKnot_u (double k) |
| virtual void | removeKnot_u (double k) |
| virtual void | insertKnot_v (double k) |
| virtual void | removeKnot_v (double k) |
| virtual void | insertKnot_w (double k) |
| virtual void | removeKnot_w (double k) |
| virtual bool | rational (void) const |
| virtual QVector< axlPoint * > | sampling () |
| virtual void | gridEvaluator (int num_u, int num_v, int num_w, std::vector< double > &points, std::vector< double > ¶m_u, std::vector< double > ¶m_v, std::vector< double > ¶m_w) |
| virtual QString | printCoeffs (bool print) const |
| virtual QString | printKnotsVector (bool print) const |
| virtual QString | description (void) const |
| virtual void | updateRcoeff () |
| double | scalarValue (double u, double v, double w) |
| void | setScalarValue (double u, double v, double w, double value) |
| virtual bool | connectionsAreDefined (void) |
| Return true if control points connections were defined by developers. False if there are default connections visualization. More... | |
| virtual QList< int > | getControlPointConnection (int i) |
| The list returned contains all indices of coefficients that are still to be connected to the ith coefficient. More... | |
| virtual void | defineControlPointConnection (int i, int j) |
| Define connection between the ith and the jth coefficient. More... | |
| virtual void | resetControlPointConnections (void) |
| Removes all control point connections. More... | |
| QVariantList | convertDataToQVariant (void) const |
| Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData. More... | |
| int | convertQVariantToData (const QVariantList &data) |
| Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0. More... | |
| virtual void | selectIndex (int i) |
Public Member Functions inherited from axlAbstractVolumeParametric | |
| axlAbstractVolumeParametric (void) | |
| virtual | ~axlAbstractVolumeParametric (void) |
| virtual axlPoint | eval (double u, double v, double w) |
| virtual void | eval (axlPoint *point, double u, double v, double w) |
| virtual void | eval (double &, double &, double &, double u, double v, double w) |
| virtual void | normal (axlPoint *normal, double u, double v, double w) |
| virtual axlMesh | eval (double u, double v, double w, int derivs, bool u_from_right=true, bool v_from_right=true, bool w_from_right=true, double resolution=1.0e-12) |
| virtual dtkDeprecated::dtkVector3D< double > | eval2 (double u, double v, double w) |
| virtual dtkDeprecated::dtkVector3D< double > | normal (double u, double v, double w) |
| virtual void | normal (dtkDeprecated::dtkVector3D< double > *normal, double u, double v, double w) |
| virtual int | numSamples_u (void) |
| virtual int | numSamples_v (void) |
| virtual int | numSamples_w (void) |
| virtual double | startParam_u (void) |
| virtual double | endParam_u (void) |
| virtual double | startParam_v (void) |
| virtual double | endParam_v (void) |
| virtual double | startParam_w (void) |
| virtual double | endParam_w (void) |
| virtual int | stripes (void) |
| virtual void | setStripes (int stripes) |
| virtual void | setNumSamples_u (int numSamples) |
| virtual void | setNumSamples_v (int numSamples) |
| virtual void | setNumSamples_w (int numSamples) |
| const int & | samples_u (void) const |
| const int & | samples_v (void) const |
| const int & | samples_w (void) const |
Public Member Functions inherited from axlAbstractVolume | |
| axlAbstractVolume (void) | |
| virtual | ~axlAbstractVolume (void) |
| virtual int | dimension (void) const |
| virtual axlMesh * | toAxlMesh (void) |
| virtual void * | volume (void) |
Public Member Functions inherited from axlAbstractData | |
| axlAbstractData (axlAbstractData *parent=NULL) | |
| axlAbstractData (const axlAbstractData &data) | |
| virtual | ~axlAbstractData (void) |
| const QColor & | color (void) const |
| const double & | opacity (void) const |
| const double & | size (void) const |
| const QString & | shader (void) const |
| const bool & | editable (void) |
| const bool & | updateView (void) |
| void | setColor (double r, double g, double b) |
| void | addField (axlAbstractField *field) |
| Add a field to the field list of the object. More... | |
| bool | updateFieldList (QString nameField) |
| Check if a field with the same name is already applied on the object. More... | |
| QString | changeFieldName (QString fieldName) |
| axlMesh * | mesh (void) |
| Return the mesh of that object is computed. More... | |
| void | setMesh (axlMesh *mesh) |
| Set a corresponding mesh for that object. More... | |
| void | setUpdateView (bool updateView) |
| QList< axlAbstractField * > | fields (void) |
Additional Inherited Members | |
Public Slots inherited from axlAbstractVolumeParametric | |
| void | setSamples_u (const int &color) |
| void | setSamples_v (const int &color) |
| void | setSamples_w (const int &color) |
Public Slots inherited from axlAbstractData | |
| void | touchGeometry (void) |
| void | touchProperty (void) |
| void | touchStructure (void) |
| virtual void | touchField (void) |
| void | setColor (const QColor &color) |
| void | setOpacity (const double &opacity) |
| void | setSize (const double &size) |
| void | setShader (const QString &shader) |
| void | setEditable (bool edit) |
Properties inherited from axlAbstractVolumeParametric | |
| int | samples_u |
| int | samples_v |
| int | samples_w |
Properties inherited from axlAbstractData | |
| QColor | color |
| double | opacity |
| double | size |
| QString | shader |
Definition at line 30 of file axlAbstractVolumeBSpline.h.
| axlAbstractVolumeBSpline::axlAbstractVolumeBSpline | ( | void | ) |
Definition at line 34 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 39 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 273 of file axlAbstractVolumeBSpline.cpp.
virtual |
Reimplemented from axlAbstractData.
Definition at line 323 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 361 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 45 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 51 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 57 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 63 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 69 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 300 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 247 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 131 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 137 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 291 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 125 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 168 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 174 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 180 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 144 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 194 of file axlAbstractVolumeBSpline.cpp.
signal |
virtual |
Definition at line 205 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 215 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 225 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 76 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 82 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 88 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 95 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 101 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 107 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 235 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 241 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 114 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 210 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 220 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 230 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 281 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 187 of file axlAbstractVolumeBSpline.cpp.
signal |
| double axlAbstractVolumeBSpline::scalarValue | ( | double | u, |
| double | v, | ||
| double | w | ||
Definition at line 253 of file axlAbstractVolumeBSpline.cpp.
inlinevirtual |
Definition at line 109 of file axlAbstractVolumeBSpline.h.
virtual |
Definition at line 150 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 156 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 162 of file axlAbstractVolumeBSpline.cpp.
| void axlAbstractVolumeBSpline::setScalarValue | ( | double | u, |
| double | v, | ||
| double | w, | ||
| double | value | ||
Definition at line 261 of file axlAbstractVolumeBSpline.cpp.
virtual |
Definition at line 199 of file axlAbstractVolumeBSpline.cpp.
signal |
virtual |
Definition at line 120 of file axlAbstractVolumeBSpline.cpp.
