Developer documentation | Axl-2.5.1
axlFieldParametricCurve.cpp
Go to the documentation of this file.
1 /* axlFieldParametricCurve.cpp ---
2  *
3  * Author: Anais Ducoffe
4  * Copyright (C) 2013 - Anais Ducoffe, Inria.
5  */
6
7 /* Commentary:
8  *
9  */
10
11 /* Change log:
12  *
13  */
14 #include <sstream>
15
17 #include "axlAbstractProcess.h"
18
19 #include <dtkCoreSupport/dtkGlobal.h>
20
21 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
22 #include <dtkCoreSupport/dtkAbstractProcessFactory.h>
23
26
27 class axlFieldParametricCurvePrivate
28 {
29 public:
33
36 };
37
38 // /////////////////////////////////////////////////////////////////
39 // axlFieldParametricCurve implementation
40 // /////////////////////////////////////////////////////////////////
41
43
47 {
48  d->input = NULL;
49  d->function = NULL;
50  this->setObjectName(this->identifier());
51 }
52
53
54
56
60 {
61  delete d;
62
63  d = NULL;
64 }
65
66
67
70 // *
71 // */
72 //void axlFieldParametricCurve::setType(axlFieldParametricCurve::Type type)
73 //{
74
75 // d->type = type;
76 //}
77
80 // *
81 // */
82 //void axlFieldParametricCurve::setKind(axlFieldParametricCurve::Kind kind)
83 //{
84
85 // d->kind = kind;
86 //}
87
90 // *
91 // */
92 //void axlFieldParametricCurve::setSupport(axlFieldParametricCurve::Support support)
93 //{
94 // d->support = support;
95 //}
96
97
98 //axlFieldParametricCurve::Type axlFieldParametricCurve::type(void)
99 //{
100 // return d->type;
101 //}
102
103 //axlFieldParametricCurve::Kind axlFieldParametricCurve::kind(void)
104 //{
105 // return d->kind;
106 //}
107
108 //axlFieldParametricCurve::Support axlFieldParametricCurve::support(void)
109 //{
110 // return d->support;
111 //}
112
114
117 double axlFieldParametricCurve::scalar(double u, double v, double w)
118 {
119  if(!(this->kind() == Scalar)) {
120  qDebug() << "Getting scalar value on non scalar field.";
121  return 0;
122  }
123  return d->function->eval(u).x();
124
125
126
127 }
128
130
133 double *axlFieldParametricCurve::vector(double u, double v, double w)
134 {
135  if(!(this->kind() == Vector)) {
136  qDebug() << "Getting vector value on non vector field.";
137  return NULL;
138  }
139  return d->function->eval(u).coordinates();
140
141 }
142
144
147 double *axlFieldParametricCurve::tensor(double u, double v, double w)
148 {
149  if(!(this->kind() == Tensor)) {
150  qDebug() << "Getting tensor value on non tensor field.";
151  return NULL;
152  }
153  return NULL;
154 }
155
158 // *
159 // */
160 //QString axlFieldParametricCurve::name(void)
161 //{
162 // return this->name() ;
163 //}
164
167 // *
168 // */
169 //void axlFieldParametricCurve::setName(QString name)
170 //{
171 // this->setObjectName(name);
172
173 //}
174
176
181 {
182  QString qstr;
183
184  qstr.append("axlFieldParametricCurve : \n");
185
186  switch(d->type){
188  qstr.append("Type : integer");
189  break;
191  qstr.append("Type : Float");
192  break;
194  qstr.append("Type : Double");
195  break;
196  default:
197  qDebug() << "Unsupported field type";
198  }
199
200
201  switch(d->kind) {
203  qstr.append(";Kind : Scalar");
204  break;
206  qstr.append(";Kind : Vector");
207  break;
209  qstr.append(";Kind : Tensor");
210  break;
211  default:
212  qDebug() << ";Unsupported field kind";
213  }
214
215  switch(d->support) {
217  qstr.append(";Support : Point");
218  break;
220  qstr.append(";Support : Cell");
221  break;
223  qstr.append(";Support : Custom");
224  break;
225  default:
226  qDebug() << ";No support";
227  }
228
229  return qstr;
230
231 }
232
233
235
240 {
241  return "axlFieldParametricCurve";
242 }
243
245
249  if(dynamic_cast<axlAbstractCurveParametric*>(data))
250  d->function = dynamic_cast<axlAbstractCurveParametric*>(data);
251 }
252
254
258  return d->function;
259
260 }
261
263
267  if(dynamic_cast<axlAbstractCurveParametric *>(data))
268  d->input = dynamic_cast<axlAbstractCurveParametric *>(data);
269 }
270
271
273
277  return d->input->startParam();
278 }
279
280
281
283
287  return d->input->endParam();
288 }
289
290
291
293
297  return d->input->numSamples();
298 }
299
300
302
306  return d->input->numSamples();
307 }
308
309
310
313
317 {
318  emit updated();
319 }
320
321 // /////////////////////////////////////////////////////////////////
322 // axlFieldBSpline documentation
323 // /////////////////////////////////////////////////////////////////
324
331 // /////////////////////////////////////////////////////////////////
332 // Type instanciation
333 // /////////////////////////////////////////////////////////////////
334
335 dtkAbstractData *createaxlFieldParametricCurve(void)
336 {
337  return new axlFieldParametricCurve();
338 }
339
340
virtual double * vector(double u, double v=0., double w=0.)
Returns the value of the spatial field at the coordinates point entered.
double start_u(void)
Returns the first parameter value of the field.
virtual ~axlFieldParametricCurve(void)
Destroys a Bspline field.
dtkAbstractData * createaxlFieldParametricCurve(void)
virtual QString identifier(void) const
Returns the identifier of the field "axlFieldParametricCurve".
virtual double scalar(double u, double v=0., double w=0.)
Class axlFieldParametricCurve defines an API for field which owns a BSpline curve.
Class axlAbstractFieldParametricCurve defines an API for parametric field.
virtual QString description(void) const
Returns the description of the field.
virtual Kind kind(void)
Generic interface for parametric curve.
double numbersample_u(void)
Returns the number of parameters.
void setFunction(axlAbstractData *data)
Sets the Bspline function which determines the values of the BSpline field.
void setCurve(axlAbstractData *data)
Sets the curve on which the parametric field is applied.
double end_u(void)
Returns the last parameter value of the field.
axlAbstractData * getFunction(void)
Returns the Bspline function which determines the values of the BSpline field.
Class axlAbstractData defines an API for all type of axel data.
int size(void)
Returns the number of values evaluated for this parametric field on each samples of the input curve...
virtual double * tensor(double u, double v=0., double w=0.)
