Developer documentation | Axl-2.5.1
axlFieldParametricCurve.h
Go to the documentation of this file.
1 /* axlFieldParametricCurve.h ---
2  *
3  * Author: Anais Ducoffe
4  * Copyright (C) 2013 - Anais Ducoffe, Inria.
5  */
6
7 /* Commentary:
8  *
9  */
10
11 /* Change log:
12  *
13  */
14 #include "axlCoreExport.h"
15 #ifndef AXLFIELDPARAMETRICCURVE_H
16 #define AXLFIELDPARAMETRICCURVE_H
17
19
20 class axlFieldParametricCurvePrivate;
21 class axlAbstractData;
22
24 {
25  Q_OBJECT
26
27 public:
29  virtual ~axlFieldParametricCurve(void);
30
31 // void setType(Type type);
32 // void setKind(Kind kind);
33 // void setSupport(Support support);
34
35  void setFunction(axlAbstractData *data);
37  void setCurve(axlAbstractData *data);
38
39  double start_u(void);
40
41  double end_u(void);
42
43  double numbersample_u(void);
44
45  int size(void);
46
47 // Type type(void);
48 // Kind kind(void);
49 // Support support(void);
50
51  virtual double scalar(double u, double v = 0., double w = 0.);
52  virtual double *vector(double u, double v = 0., double w = 0.);
53  virtual double *tensor(double u, double v = 0., double w = 0.);
54
55  virtual QString description(void) const;
56  virtual QString identifier(void) const;
57 // virtual QString name(void);
58 // virtual void setName(QString name);
59
60
61 public slots:
62  virtual void update(void);
63
64
65 private:
66  axlFieldParametricCurvePrivate *d;
67 };
68
69 AXLCORE_EXPORT dtkAbstractData *createaxlFieldParametricCurve(void);
70
71
72 #endif // AXLFIELDPARAMETRICCURVE_H
virtual double scalar(double u, double v=0, double w=0)
Returns the value of the parametric field at the parameters values in input.
virtual void setFunction(axlAbstractData *data)
Returns the description of the field.
virtual double * tensor(double u, double v=0, double w=0)
Returns the value of the spatial field at the coordinates point entered.
virtual void setCurve(axlAbstractData *Curve)
Sets the support Curve of the field.
virtual axlAbstractData * getFunction(void)
Class axlFieldParametricCurve defines an API for field which owns a BSpline curve.
AXLCORE_EXPORT dtkAbstractData * createaxlFieldParametricCurve(void)
Class axlAbstractFieldParametricCurve defines an API for parametric field.
virtual int size(void)
Returns number of parameters on which the field is evaluated.
virtual double end_u(void)
Returns the last v-value parameter.
virtual double start_u(void)
Returns the first u-value parameter.
#define AXLCORE_EXPORT
Class axlAbstractData defines an API for all type of axel data.
virtual double numbersample_u(void)
Returns the number of u-parameters.
virtual double * vector(double u, double v=0, double w=0)
Returns the value of the parametric field evaluated at the parameters in input.
