Developer documentation | Axl-2.5.1
axlFieldParametricSurface.h
Go to the documentation of this file.
1 /* axlFieldParametricSurface.h ---
2  *
3  * Author: Anais Ducoffe
4  * Copyright (C) 2013 - Anais Ducoffe, Inria.
5  */
6
7 /* Commentary:
8  *
9  */
10
11 /* Change log:
12  *
13  */
14 #include "axlCoreExport.h"
15 #ifndef AXLFIELDPARAMETRICSURFACE_H
16 #define AXLFIELDPARAMETRICSURFACE_H
17
19
20 class axlFieldParametricSurfacePrivate;
21 class axlAbstractData;
22
24 {
25  Q_OBJECT
26
27 public:
29  virtual ~axlFieldParametricSurface(void);
30
31  // void setType(Type type);
32  // void setKind(Kind kind);
33  // void setSupport(Support support);
34
35  void setFunction(axlAbstractData *data);
37  void setSurface(axlAbstractData *data);
38
39  double start_u(void);
40  double start_v(void);
41
42  double end_u(void);
43  double end_v(void);
44
45  double numbersample_u(void);
46  double numbersample_v(void);
47
48  int size(void);
49
50  // Type type(void);
51  // Kind kind(void);
52  // Support support(void);
53
54  virtual double scalar(double u, double v, double w = 0);
55  virtual double *vector(double u, double v, double w = 0);
56  virtual double *tensor(double u, double v, double w = 0);
57
58  virtual QString description(void) const;
59  virtual QString identifier(void) const;
60  // virtual QString name(void);
61  // virtual void setName(QString name);
62
63
64 public slots:
65  virtual void update(void);
66
67
68 private:
69  axlFieldParametricSurfacePrivate *d;
70 };
71
72 AXLCORE_EXPORT dtkAbstractData *createaxlFieldParametricSurface(void);
73
74
75 #endif // AXLFIELDPARAMETRICSURFACE_H
AXLCORE_EXPORT dtkAbstractData * createaxlFieldParametricSurface(void)
Class axlFieldParametricSurface defines an API for field which owns a BSpline Surface as a function a...
virtual axlAbstractData * getFunction(void)
Returns the description of the field.
virtual double start_u(void)
Returns the first u-value parameter.
virtual int size(void)
Returns number of parameters on which the field is evaluated.
virtual double scalar(double u, double v, double w=0)
Returns the value of the parametric field at the parameters values in input.
virtual double start_v(void)
Returns the first v-value parameter.
virtual double numbersample_v(void)
Returns the number of v-parameters.
virtual void setFunction(axlAbstractData *data)
virtual double numbersample_u(void)
Returns the number of u-parameters.
virtual double * tensor(double u, double v, double w=0)
Returns the value of the spatial field at the coordinates point entered.
virtual double end_u(void)
Returns the last v-value parameter.
virtual double * vector(double u, double v, double w=0)
Returns the value of the parametric field evaluated at the parameters in input.
virtual double end_v(void)
#define AXLCORE_EXPORT
Class axlAbstractFieldParametricSurface defines an API for parametric field.
virtual void setSurface(axlAbstractData *surface)
Sets the support surface of the field.
Class axlAbstractData defines an API for all type of axel data.
