Developer documentation | Axl-2.5.1
axlFieldParametricSurface.cpp
Go to the documentation of this file.
1 /* axlFieldParametricSurface.cpp ---
2  *
3  * Author: Anais Ducoffe
4  * Copyright (C) 2013 - Anais Ducoffe, Inria.
5  */
6
7 /* Commentary:
8  *
9  */
10
11 /* Change log:
12  *
13  */
14 #include <sstream>
15
17 #include "axlAbstractProcess.h"
18
19 #include <dtkCoreSupport/dtkGlobal.h>
20
21 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
22 #include <dtkCoreSupport/dtkAbstractProcessFactory.h>
23
26
27 class axlFieldParametricSurfacePrivate
28 {
29 public:
33
36 };
37
38 // /////////////////////////////////////////////////////////////////
39 // axlFieldParametricSurface implementation
40 // /////////////////////////////////////////////////////////////////
41
43
47 {
48  d->input = NULL;
49  d->function = NULL;
50  this->setObjectName(this->identifier());
51 }
52
53
54
56
60 {
61  delete d;
62
63  d = NULL;
64 }
65
66
67
70 // *
71 // */
72 //void axlFieldParametricSurface::setType(axlFieldParametricSurface::Type type)
73 //{
74
75 // d->type = type;
76 //}
77
80 // *
81 // */
82 //void axlFieldParametricSurface::setKind(axlFieldParametricSurface::Kind kind)
83 //{
84
85 // d->kind = kind;
86 //}
87
90 // *
91 // */
92 //void axlFieldParametricSurface::setSupport(axlFieldParametricSurface::Support support)
93 //{
94 // d->support = support;
95 //}
96
97
98 //axlFieldParametricSurface::Type axlFieldParametricSurface::type(void)
99 //{
100 // return d->type;
101 //}
102
103 //axlFieldParametricSurface::Kind axlFieldParametricSurface::kind(void)
104 //{
105 // return d->kind;
106 //}
107
108 //axlFieldParametricSurface::Support axlFieldParametricSurface::support(void)
109 //{
110 // return d->support;
111 //}
112
114
117 double axlFieldParametricSurface::scalar(double u, double v, double w)
118 {
119  if(!(this->kind() == Scalar)) {
120  qDebug() << "Getting scalar value on non scalar field.";
121  return 0;
122  }
123  if(d->function){
124  return d->function->eval(u,v).x();
125  } else
126  return 0;
127 }
128
130
133 double *axlFieldParametricSurface::vector(double u, double v, double w)
134 {
135  if(!(this->kind() == Vector)) {
136  qDebug() << "Getting vector value on non vector field.";
137  return NULL;
138  }
139  return d->function->eval(u,v).coordinates();
140
141 }
142
144
147 double *axlFieldParametricSurface::tensor(double u, double v, double w)
148 {
149  if(!(this->kind() == Tensor)) {
150  qDebug() << "Getting tensor value on non tensor field.";
151  return NULL;
152  }
153  // TO DO
154  return NULL;
155 }
156
159 // *
160 // */
161 //QString axlFieldParametricSurface::name(void)
162 //{
163 // return this->objectName() ;
164 //}
165
168 // *
169 // */
170 //void axlFieldParametricSurface::setName(QString name)
171 //{
172 // this->setObjectName(name);
173
174 //}
175
176
178
182 {
183  return "axlFieldParametricSurface";
184 }
185
187
191 {
192  QString qstr;
193
194  qstr.append("axlFieldParametricSurface : \n");
195
196  switch(d->type){
198  qstr.append("Type : integer");
199  break;
201  qstr.append("Type : Float");
202  break;
204  qstr.append("Type : Double");
205  break;
206  default:
207  qDebug() << "Unsupported field type";
208  }
209
210
211  switch(d->kind) {
213  qstr.append(";Kind : Scalar");
214  break;
216  qstr.append(";Kind : Vector");
217  break;
219  qstr.append(";Kind : Tensor");
220  break;
221  default:
222  qDebug() << ";Unsupported field kind";
223  }
224
225  switch(d->support) {
227  qstr.append(";Support : Point");
228  break;
230  qstr.append(";Support : Cell");
231  break;
233  qstr.append(";Support : Custom");
234  break;
235  default:
236  qDebug() << ";No support";
237  }
238
239  return qstr;
240
241 }
242
244
248  qDebug() << Q_FUNC_INFO << 1;
249  if(dynamic_cast<axlAbstractSurfaceParametric*>(data)){
250  qDebug() << Q_FUNC_INFO << 2;
251  d->function = dynamic_cast<axlAbstractSurfaceParametric*>(data);
252  }
253 }
254
255
257
261  return d->function;
262 }
263
265
269  if(dynamic_cast<axlAbstractSurfaceBSpline*>(data))
270  d->input = dynamic_cast<axlAbstractSurfaceBSpline*>(data);
271 }
272
273
275
279
280  return d->input->startParam_u();
281
282 }
283
284
286
290  return d->input->startParam_v();
291 }
292
293
295
299
300  return d->input->endParam_u();
301 }
302
303
305
309
310  return d->input->endParam_v();
311 }
312
313
314
316
320
321  return d->input->numSamples_u();
322 }
323
325
329  return d->input->numSamples_v();
330 }
331
332
333
335
339  return d->input->numSamples_u()*d->input->numSamples_v();
340 }
341
342
343
346
350 {
351  emit updated();
352 }
353
354 // /////////////////////////////////////////////////////////////////
355 // axlFieldParametricSurface documentation
356 // /////////////////////////////////////////////////////////////////
357
364 // /////////////////////////////////////////////////////////////////
365 // Type instanciation
366 // /////////////////////////////////////////////////////////////////
367
368 dtkAbstractData *createaxlFieldParametricSurface(void)
369 {
370  return new axlFieldParametricSurface;
371 }
372
373
double numbersample_u(void)
Returns the number of parameters.
double end_v(void)
Returns the last parameter value of the field.
Class axlFieldParametricSurface defines an API for field which owns a BSpline Surface as a function a...
int size(void)
Returns the number of values evaluated for this BSpline field on each samples of the input BSpline...
axlAbstractData * getFunction(void)
Returns the Bspline function which determines the values of the parametric field. ...
void setSurface(axlAbstractData *data)
Sets the BSpline on which the BSpline field is applied.
double start_u(void)
Returns the first parameter value of the field.
virtual double * tensor(double u, double v, double w=0)
Returns the value of the spatial field at the coordinates point entered.
virtual QString identifier(void) const
Returns the identifier of the field "axlFieldParametricSurface".
virtual ~axlFieldParametricSurface(void)
Destroys a Bspline field.
virtual Kind kind(void)
void setFunction(axlAbstractData *data)
Sets the Bspline function which determines the values of the parametric field.
double end_u(void)
virtual double scalar(double u, double v, double w=0)
double start_v(void)
dtkAbstractData * createaxlFieldParametricSurface(void)
virtual double * vector(double u, double v, double w=0)
double numbersample_v(void)
virtual QString description(void) const
Returns the description of the field.
Class axlAbstractFieldParametricSurface defines an API for parametric field.
Class axlAbstractData defines an API for all type of axel data.
