Go to the source code of this file.
Classes | |
| class | axlFieldParametricSurfaceTangentVector |
| Class axlFieldParametricSurfaceTangentVector defines an API for field which owns a BSpline Surface as a function and a parametric surface on which the field is applied. More... | |
Functions | |
| AXLCORE_EXPORT dtkAbstractData * | createaxlFieldParametricSurfaceTangentVector (void) |
| AXLCORE_EXPORT dtkAbstractData* createaxlFieldParametricSurfaceTangentVector | ( | void | ) |
Definition at line 271 of file axlFieldParametricSurfaceTangentVector.cpp.
