Developer documentation | Axl-2.5.1
axlFieldParametricSurfaceTangentVector.h
Go to the documentation of this file.
1 /* axlFieldParametricSurfaceTangentVector.h ---
2  *
3  * Author: Anais Ducoffe
4  * Copyright (C) 2013 - Anais Ducoffe, Inria.
5  */
6
7 /* Commentary:
8  *
9  */
10
11 /* Change log:
12  *
13  */
14 #include "axlCoreExport.h"
15 #ifndef AXLFIELDPARAMETRICSURFACETANGENTVECTOR_H
16 #define AXLFIELDPARAMETRICSURFACETANGENTVECTOR_H
17
19
20 class axlFieldParametricSurfaceTangentVectorPrivate;
21 class axlAbstractData;
22
24 {
25  Q_OBJECT
26
27 public:
30
31  void setSurface(axlAbstractData *data);
32  void setParameter(double parameter, int channel);
33
34  double parameter(int channel);
35
36  double start_u(void);
37  double start_v(void);
38
39  double end_u(void);
40  double end_v(void);
41
42  double numbersample_u(void);
43  double numbersample_v(void);
44
45  int size(void);
46
47
48  double* vector(double u, double v, double w=0.);
49
50  QString description(void) const;
51  QString identifier(void) const;
52
53 public slots:
54  virtual void update(void);
55
56 private:
57  axlFieldParametricSurfaceTangentVectorPrivate *d;
58 };
59
61
62
63 #endif // AXLFIELDPARAMETRICSURFACETANGENTVECTOR_H
virtual double start_u(void)
Returns the first u-value parameter.
virtual int size(void)
Returns number of parameters on which the field is evaluated.
virtual double start_v(void)
Returns the first v-value parameter.
virtual double numbersample_v(void)
Returns the number of v-parameters.
virtual double numbersample_u(void)
Returns the number of u-parameters.
virtual double end_u(void)
Returns the last v-value parameter.
virtual double * vector(double u, double v, double w=0)
Returns the value of the parametric field evaluated at the parameters in input.
AXLCORE_EXPORT dtkAbstractData * createaxlFieldParametricSurfaceTangentVector(void)
Class axlFieldParametricSurfaceTangentVector defines an API for field which owns a BSpline Surface as...
virtual double end_v(void)
#define AXLCORE_EXPORT
virtual QString identifier(void) const
Returns the description of the field.
virtual QString description(void) const
Class axlAbstractFieldParametricSurface defines an API for parametric field.
virtual void setSurface(axlAbstractData *surface)
Sets the support surface of the field.
Class axlAbstractData defines an API for all type of axel data.
