22 #include <dtkCoreSupport/dtkGlobal.h>
   24 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
   25 #include <dtkCoreSupport/dtkAbstractProcessFactory.h>
   30 class axlFieldParametricSurfaceTangentVectorPrivate
   86         qDebug() <<
"Getting vector value on non vector field.";
   96     double x = d->a*deriv1u->
x() + d->b*deriv1v->
x();
   97     double y = d->a*deriv1u->
y() + d->b*deriv1v->
y();
   98     double z = d->a*deriv1u->
z() + d->b*deriv1v->
z();
  114     return "axlFieldParametricSurfaceTangentVector";
  126     qstr.append(
"axlFieldParametricSurfaceTangentVector : \n");
  127     qstr.append(
"Type : Double ");
  128     qstr.append(
";Kind : Vector ");
  129     qstr.append(
";Support : Point");
  142     if(dynamic_cast<axlAbstractSurfaceBSpline*>(data))
  154     else if(channel == 1)
  157         qDebug() <<
"only two possible channel values : 0 and 1";
  167     else if(channel == 1)
  170         qDebug() <<
"channel has only two values : 0 and 1.";
  183     return d->input->startParam_u();
  193     return d->input->startParam_v();
  203     return d->input->endParam_u();
  213     return d->input->endParam_v();
  224     return d->input->numSamples_u();
  232     return d->input->numSamples_v();
  242     return d->input->numSamples_u()*d->input->numSamples_v();
double end_u(void)
Returns the last parameter value of the field.
Class axlPoint defines 3D points.
dtkAbstractData * createaxlFieldParametricSurfaceTangentVector(void)
double * vector(double u, double v, double w=0.)
Returns the value of the spatial field at the coordinates point entered.
double * coordinates(void) const
Returns coordinates of this point.
double numbersample_v(void)
Returns the number of parameters.
double parameter(int channel)
Returns the direction parameter for the tangentVector, for the channel-th.
QString identifier(void) const
Returns the identifier of the field "axlFieldParametricSurfaceTangentVector".
virtual void update(void)
QString description(void) const
Returns the description of the field.
axlMesh * mesh(void)
Return the mesh of that object is computed.
double start_u(void)
Returns the first parameter value of the field.
axlFieldParametricSurfaceTangentVector()
double start_v(void)
void vertex(const int &ind, double vertex[3])
set vertex values of vertices with index ind.
virtual ~axlFieldParametricSurfaceTangentVector(void)
Destroys a Bspline field.
int size(void)
Returns the number of values evaluated for this BSpline field on each samples of the input BSpline...
Class axlFieldParametricSurfaceTangentVector defines an API for field which owns a BSpline Surface as...
void setSurface(axlAbstractData *data)
Sets the BSpline on which the BSpline field is applied.
void setParameter(double parameter, int channel)
Sets the direction parameter for the tangentVector.
virtual void setType(Type type)
Sets the type of the field which can be either int, float or double.
double end_v(void)
virtual void setSupport(Support support)
double numbersample_u(void)
Class axlAbstractFieldParametricSurface defines an API for parametric field.
virtual void setKind(Kind kind)
Sets the kind of the field which can be either scalar, vector or tensor.
void setCoordinates(double x, double y, double z)
Change coordinates of this point.
Class axlAbstractData defines an API for all type of axel data.
Class axlMesh defines a piecewise-linear 3D object.
