21 #include <dtkCoreSupport/dtkAbstractData.h>
   22 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
   40     return "axlShapeWriter";
   44     return "axlShapeWriter";
   48     return QStringList() <<
"axlShape";
   52     return dtkAbstractDataFactory::instance()->registerDataWriterType(
"axlShapeWriter", QStringList(),
createaxlShapeWriter);
   64     return !this->
accept(data);
   71     QDomElement shapeElement = doc->createElement(
"shape");
   72     shapeElement.setAttribute(
"name", shape->name());
   75     shapeElement.setAttribute(
"size", QString::number(shape->
size()));
   78     QColor qcolor = shape->
color();
   80     QTextStream(&color) << QString::number(qcolor.red()) <<
   81                         << QString::number(qcolor.green()) <<
   82                         << QString::number(qcolor.blue()) <<
   83                         << QString::number(shape->
opacity());
   84     shapeElement.setAttribute(
"color", color);
   87     QString shader = shape->
shader();
   88     QFileInfo shaderFileInfo(shader);
   89     shapeElement.setAttribute(
"shader", shaderFileInfo.fileName());
   93     shapeElement.setAttribute(
"nb_edges", shape->
getEdgeCount());
   94     shapeElement.setAttribute(
"nb_faces", shape->
getFaceCount());
   97     QVector<axlPoint*> allVertices = shape->
getVertices();
   98     QDomElement verticesElement = doc->createElement(
"vertices");
   99     for (
int k = 0; k < allVertices.size(); k++) {
  100         axlPoint* currVertex = allVertices.at(k);
  101         QString coordsString = QString::number(currVertex->
x()) +
  102                              + QString::number(currVertex->
y()) +
  103                              + QString::number(currVertex->
z()) +
"\n\t";
  104         QDomText coordsDomText = doc->createTextNode(coordsString);
  105         verticesElement.appendChild(coordsDomText);
  107     shapeElement.appendChild(verticesElement);
  110     QVector<axlShape::Edge*> allEdges = shape->
getEdges();
  111     QDomElement edgesElement = doc->createElement(
"edges");
  112     for (
int k = 0; k < allEdges.size(); k++) {
  113         QDomElement edgeElement = doc->createElement(
"edge");
  114         edgeElement.setAttribute(
"id", k);
  120         QString curveWriterTag = curve->identifier()+
"Writer";
  122         QDomElement curveElement = curveWriter->
write(doc, curve);
  125         edgeElement.appendChild(curveElement);
  126         edgeElement.setAttribute(
"type", curve->identifier());
  133         edgesElement.appendChild(edgeElement);
  135     shapeElement.appendChild(edgesElement);
  138     QVector<axlShape::Face*> allFaces = shape->
getFaces();
  139     QDomElement facesElement = doc->createElement(
"faces");
  140     for (
int k = 0; k < allFaces.size(); k++) {
  141         QDomElement faceElement = doc->createElement(
"face");
  142         faceElement.setAttribute(
"id", k);
  145         QVector<axlShape::Loop*> currLoops = currFace->
loops;
  147         QDomElement faceSurfaceElement = doc->createElement(
"face_surface");
  149         QString surfaceWriterTag = surface->identifier()+
"Writer";
  152             QDomElement surfaceElement = surfaceWriter->
write(doc, surface);
  154             faceElement.appendChild(surfaceElement);
  156             dtkWarn() << surfaceWriterTag <<
"not supported yet.";
  159         faceElement.setAttribute(
"type", surface->identifier());
  162         for (
int i = 0; i < currLoops.size(); i++) {
  163             QDomElement loopElement = doc->createElement(
"loop");
  164             loopElement.setAttribute(
"id", i);
  167             QVector<int> currEdges = currLoop->
edges;
  168             QVector<bool> currOrientations = currLoop->
orientations;
  170             for (
int j = 0; j < currEdges.size(); j++) {
  171                 QDomElement edgeElement = doc->createElement(
"edge");
  172                 edgeElement.setAttribute(
"id", currEdges.at(j));
  174                 bool currOrientation = currOrientations.at(j);
  175                 edgeElement.setAttribute(
"orientation", currOrientation);
  177                 loopElement.appendChild(edgeElement);
  179             faceElement.appendChild(loopElement);
  181         facesElement.appendChild(faceElement);
  183     shapeElement.appendChild(facesElement);
  188 QDomElement axlShapeWriter::elementByWriter(
axlAbstractDataWriter *axl_writer, QDomDocument *doc, dtkAbstractData *data) {
  194     if(!axl_writer->
accept(data))
  197     element = axl_writer->
write(doc, data);
Class axlPoint defines 3D points.
axlAbstractCurveParametric * curve
Pointer to the parametric curve supporting the edge, of type axlAbstractCurveParametric.
int indexStartVertex
Index of the starting point of the edge in the array of vertices of the axlShape. ...
QVector< int > edges
Vector of indices of the edges of the loop in the array of edges of the axlShape. ...
virtual bool accept(dtkAbstractData *data)=0
QVector< Face * > getFaces(void) const
QVector< Edge * > getEdges(void) const
int getFaceCount(void) const
QString identifier(void) const
int getEdgeCount(void) const
QString description(void) const
int getVertexCount(void) const
Generic interface for parametric curve.
int indexEndVertex
Index of the ending point of the edge in the array of vertices of the axlShape.
QDomElement write(QDomDocument *doc, dtkAbstractData *data)
QVector< bool > orientations
Vector of booleans of the same size as edges: true means the direct orientation, false is the reverse...
axlAbstractSurfaceParametric * surface
Pointer to the supporting surface of type axlAbstractSurfaceParametric.
static bool registered(void)
bool reject(dtkAbstractData *data)
QVector< Loop * > loops
Vector of all the loops defining the face.
virtual QDomElement write(QDomDocument *doc, dtkAbstractData *data)=0
QVector< axlPoint * > getVertices(void) const
dtkAbstractDataWriter * createaxlShapeWriter(void)
virtual ~axlShapeWriter(void)
QStringList handled(void) const
