9 #include <dtkCoreSupport/dtkAbstractData.h>
   10 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
   26     return "axlTabulatedCylinderReader";
   30     return "axlTabulatedCylinderReader";
   34     return QStringList() <<
"axlTabulatedCylinder";
   42     QDomElement element = node.toElement();
   44     if (element.tagName() !=
"tabulated_cylinder")
   51     return !this->
accept(node);
   56     QDomElement element = node.toElement();
   61     QString name = element.attribute(
"name");
   62     if (!name.isEmpty()) {
   63         tabCyl->setObjectName(name);
   67     QString color = element.attribute(
"color");
   68     if (!color.isEmpty()) {
   69         QStringList colorList = color.split(
   70         if (colorList.size() > 2)
   71             tabCyl->
setColor(QColor(colorList.at(0).toInt(), colorList.at(1).toInt(), colorList.at(2).toInt()));
   72         if (colorList.size() == 4)
   77     QString shader = element.attribute(
"shader");
   79     if (!shader.isEmpty()) {
   81         dirShader =
":axlShader/shader/" + shader;
   82         if (!QFile::exists(dirShader)) {
   83             QSettings settings(
"inria",
"dtk");
   85             settings.beginGroup(
"shader");
   86             dirShader = settings.value(
"path", defaultPath).toString();
   87             dirShader.append(
"/" + shader);
   93     QString size = element.attribute(
"size");
   95         tabCyl->
setSize(size.toFloat());
   99     QDomNode genElement = element.elementsByTagName(
"generatrix").at(0);
  101     QDomElement ptElement = genElement.toElement();
  102     QString ptReaderTag =
"axlPointReader";
  108     QDomElement dirElement = element.elementsByTagName(
"directrix").at(0).toElement();
  109     QString curveReaderTag = dirElement.attribute(
"type")+
"Reader";
Class axlPoint defines 3D points.
axlAbstractData * read(const QDomNode &node)
QString description(void) const
bool reject(const QDomNode &node)
void setShader(const QString &shader)
dtkAbstractDataReader * createaxlTabulatedCylinderReader(void)
bool accept(const QDomNode &node)
virtual axlAbstractData * read(const QDomNode &node)=0
void set_generatrix(const axlPoint &vector)
static bool registered(void)
virtual ~axlTabulatedCylinderReader(void)
QStringList handled(void) const
void setOpacity(const double &opacity)
QString identifier(void) const
void setSize(const double &size)
void setColor(double r, double g, double b)
Class axlAbstractData defines an API for all type of axel data.
void set_directrix(axlAbstractCurve *curve)
