| | axlAbstractSurfaceNurbs (void) |
| virtual | ~axlAbstractSurfaceNurbs (void) |
| | axlAbstractSurfaceBSpline (void) |
| virtual | ~axlAbstractSurfaceBSpline (void) |
| virtual axlAbstractSurfaceBSpline * | copy (void) const |
| virtual int | countControlPoints (void) const |
| virtual int | countControlPoints_u (void) const |
| virtual int | countControlPoints_v (void) const |
| virtual int | knotVectorSize_u (void) const |
| virtual int | knotVectorSize_v (void) const |
| virtual int | order_u (void) const |
| virtual int | order_v (void) const |
| virtual double | getCoord (int n, int m, int v) const |
| virtual axlPoint | getCoef (int n, int m) const |
| virtual axlPoint | getCoef (int n) const |
| virtual double | getWeight (int n, int m) const |
| virtual bool | setCoef (int n, int m, int v, double c) |
| virtual bool | setCoef (int n, int m, double *controlPoint) |
| virtual bool | setCoef (int n, double *controlPoint) |
| virtual double | getKnot_u (int n) const |
| virtual double | getKnot_v (int n) const |
| virtual void | setSurface (int pointsCount_u, int pointsCount_v, int order_u, int order_v, int dimension, double *knots_u, double *knots_v, double *points, bool rational) |
| | axlAbstractSurfaceBSpline::setSurface More...
| virtual void | updateRcoeff () |
| virtual void | insertKnot_u (double k) |
| virtual void | removeKnot_u (double k) |
| virtual void | insertKnot_v (double k) |
| virtual void | removeKnot_v (double k) |
| virtual bool | rational (void) const |
| virtual QVector< axlPoint * > | sampling () |
| virtual void | gridEvaluator (int num_u, int num_v, std::vector< double > &points, std::vector< double > ¶m_u, std::vector< double > ¶m_v) |
| virtual QString | printCoeffs (bool print) const |
| virtual QString | printKnotsVector (bool print) const |
| virtual QString | description (void) const |
| QVariantList | convertDataToQVariant (void) const |
| | Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData. More...
| int | convertQVariantToData (const QVariantList &data) |
| | Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0. More...
| double | scalarValue (double u, double v) |
| void | setScalarValue (double u, double v, double value) |
| virtual bool | connectionsAreDefined (void) |
| | Return true if control points connections were defined by developers. False if there are default connections visualization. More...
| virtual QList< int > | getControlPointConnection (int i) |
| | The list returned contains all indices of coefficients that are still to be connected to the ith coefficient. More...
| virtual void | defineControlPointConnection (int i, int j) |
| | Define connection between the ith and the jth coefficient. More...
| virtual void | resetControlPointConnections (void) |
| | Removes all control point connections. More...
| virtual void | selectIndex (int i) |
| | axlAbstractSurfaceParametric (void) |
| virtual | ~axlAbstractSurfaceParametric (void) |
| virtual axlPoint | eval (double u, double v) |
| virtual void | eval (axlPoint *point, double u, double v) |
| virtual void | eval (double &, double &, double &, double u, double v) |
| virtual void | normal (axlPoint *normal, double u, double v) |
| virtual axlMesh | eval (double u, double v, int derivs, bool u_from_right=true, bool v_from_right=true, double resolution=1.0e-12) |
| virtual dtkDeprecated::dtkVector3D< double > | eval2 (double u, double v) |
| virtual void | parameterOf (const axlPoint &point, double &um, double &vm) |
| virtual dtkDeprecated::dtkVector3D< double > | normal (double u, double v) |
| virtual void | normal (dtkDeprecated::dtkVector3D< double > *normal, double u, double v) |
| virtual double | area (double tol) |
| virtual int | numSamples_u (void) |
| virtual int | numSamples_v (void) |
| virtual double | startParam_u (void) |
| virtual double | endParam_u (void) |
| virtual double | startParam_v (void) |
| virtual double | endParam_v (void) |
| virtual double | startParam_u (int numCell) |
| virtual double | endParam_u (int numCell) |
| virtual double | startParam_v (int numCell) |
| virtual double | endParam_v (int numCell) |
| virtual void | eval (axlPoint *point, double u, double v, int numCell) |
| virtual void | normal (axlPoint *normal, double u, double v, int numCell) |
| virtual bool | hasCells (void) |
| virtual int | countCells (void) |
| virtual int | numSamples_u (int numCell) |
| virtual int | numSamples_v (int numCell) |
| virtual int | stripes (void) |
| virtual void | setStripes (int stripes) |
| virtual void | setNumSamples_u (int numSamples) |
| virtual void | setNumSamples_v (int numSamples) |
| const int & | samples_u (void) const |
| const int & | samples_v (void) const |
| | axlAbstractSurface (void) |
| virtual | ~axlAbstractSurface (void) |
| virtual int | dimension (void) const |
| virtual axlMesh * | toAxlMesh (void) |
| virtual void * | surface (void) |
| | axlAbstractData (axlAbstractData *parent=NULL) |
| | axlAbstractData (const axlAbstractData &data) |
| virtual | ~axlAbstractData (void) |
| const QColor & | color (void) const |
| const double & | opacity (void) const |
| const double & | size (void) const |
| const QString & | shader (void) const |
| const bool & | editable (void) |
| const bool & | updateView (void) |
| void | setColor (double r, double g, double b) |
| void | addField (axlAbstractField *field) |
| | Add a field to the field list of the object. More...
| bool | updateFieldList (QString nameField) |
| | Check if a field with the same name is already applied on the object. More...
| QString | changeFieldName (QString fieldName) |
| axlMesh * | mesh (void) |
| | Return the mesh of that object is computed. More...
| void | setMesh (axlMesh *mesh) |
| | Set a corresponding mesh for that object. More...
| void | setUpdateView (bool updateView) |
| QList< axlAbstractField * > | fields (void) |
Definition at line 28 of file axlAbstractSurfaceNurbs.h.
