Developer documentation | Axl-2.5.1
axlDataDynamicReader Class Reference
#include <axlDataDynamicReader.h>
Inheritance diagram for axlDataDynamicReader:
axlAbstractDataReader
Public Member Functions
 axlDataDynamicReader (void)
 ~axlDataDynamicReader (void)
axlAbstractDatareadInputs (axlDataDynamic *data, const QDomNode &node, const QList< axlAbstractData * > &list)
 Construct an axlAbstractData from a node and a list of data. More...
QString identifier (void) const
QString description (void) const
QStringList handled (void) const
axlAbstractDatadataByReader (axlAbstractDataReader *axl_reader, const QDomNode &node)
bool accept (const QDomNode &node)
bool reject (const QDomNode &node)
axlAbstractDataread (const QDomNode &node)
- Public Member Functions inherited from axlAbstractDataReader
 axlAbstractDataReader (void)
virtual ~axlAbstractDataReader (void)
void setNameOf (axlAbstractData *data, const QDomElement &e)
void setColorOf (axlAbstractData *data, const QDomElement &e)
void setSizeOf (axlAbstractData *data, const QDomElement &e)
void setShaderOf (axlAbstractData *data, const QDomElement &e)
Static Public Member Functions
static bool registered (void)
Detailed Description
Definition at line 26 of file axlDataDynamicReader.h.
Constructor & Destructor Documentation
axlDataDynamicReader::axlDataDynamicReader ( void  )
Definition at line 37 of file axlDataDynamicReader.cpp.
axlDataDynamicReader::~axlDataDynamicReader ( void  )
Definition at line 42 of file axlDataDynamicReader.cpp.
Member Function Documentation
bool axlDataDynamicReader::accept ( const QDomNode &  node)
virtual
Implements axlAbstractDataReader.
Definition at line 67 of file axlDataDynamicReader.cpp.
axlAbstractData * axlDataDynamicReader::dataByReader ( axlAbstractDataReader axl_reader,
Definition at line 422 of file axlDataDynamicReader.cpp.
QString axlDataDynamicReader::description ( void  ) const
Definition at line 52 of file axlDataDynamicReader.cpp.
QStringList axlDataDynamicReader::handled ( void  ) const
Definition at line 57 of file axlDataDynamicReader.cpp.
QString axlDataDynamicReader::identifier ( void  ) const
Definition at line 47 of file axlDataDynamicReader.cpp.
axlAbstractData * axlDataDynamicReader::read ( const QDomNode &  node)
virtual
Definition at line 82 of file axlDataDynamicReader.cpp.
axlAbstractData * axlDataDynamicReader::readInputs ( axlDataDynamic data,
const QDomNode &  node,
const QList< axlAbstractData * > &  list
Parameters
data: axlDataDynamic object to be constructed.
node: node of the xml tree.
list: list of data already constructed.
Returns
the axlAbstractData constructed from the node and the object list.
The node should be of the form
<process type="process_name" status="process_status">
<input .../> ...
<parameter .../> ...
<output .../> ...
</process>
where
  • process_name is the identifier of the process to be called.
  • process_status is either
    • dynamic for a dynamic data,
    • static for a static data.
  • <input ... />... corresponds to the list (possibly empty) of inputs of the process.
  • <parameter ... />... corresponds to the list (possibly empty) of parameters of the process.
  • <output ... />... corresponds to the list (possibly empty) of outputs of the process.
The process will read its input, will setup its parameters and will compute outputs that will be stored in the objects described in the output list.
The input, parameter, output items have the following tags:
  • type="type_of_object" which can be
    • data for an axlAbstractData object specified by the tag name="...",
    • double for a double value specified by the tag value="...",
    • int for a int value specified by the tag value="...".
  • name="name_of_an_object" to specify the name of the data to be used or to be computed.
  • channel="an_integer" to specify which input or parameter channel is used.
Here is an example of an input assigned to be the axlPoint data named axlPoint1 on channel 2:
<input type="data" name="axlPoint1" channel="2" />
The output items can have color and shader attributes to describe their rendering. Here is an example of an output which will be named "surface0" and will appear in red:
<output name="surface0" color="255 0 0" />
Definition at line 206 of file axlDataDynamicReader.cpp.
bool axlDataDynamicReader::registered ( void  )
static
Definition at line 62 of file axlDataDynamicReader.cpp.
bool axlDataDynamicReader::reject ( const QDomNode &  node)
virtual
Definition at line 77 of file axlDataDynamicReader.cpp.
The documentation for this class was generated from the following files:
