Developer documentation | Axl-2.5.1
axlFieldParametricNormalVector Class Reference
Class axlFieldParametricNormalVector defines an API for field which owns a BSpline Surface as a function and a parametric surface on which the field is applied. More...
#include <axlFieldParametricNormalVector.h>
Inheritance diagram for axlFieldParametricNormalVector:
axlAbstractFieldParametricSurface axlAbstractFieldParametric axlAbstractField axlAbstractData
Public Slots
virtual void update (void)
- Public Slots inherited from axlAbstractFieldParametricSurface
- Public Slots inherited from axlAbstractData
void touchGeometry (void)
void touchProperty (void)
void touchStructure (void)
virtual void touchField (void)
void setColor (const QColor &color)
void setOpacity (const double &opacity)
void setSize (const double &size)
void setShader (const QString &shader)
void setEditable (bool edit)
Public Member Functions
 axlFieldParametricNormalVector ()
virtual ~axlFieldParametricNormalVector (void)
 Destroys a Bspline field. More...
void setSurface (axlAbstractData *data)
 Sets the BSpline on which the BSpline field is applied. More...
double start_u (void)
 Returns the first parameter value of the field. More...
double start_v (void)
double end_u (void)
 Returns the last parameter value of the field. More...
double end_v (void)
double numbersample_u (void)
 Returns the number of parameters. More...
double numbersample_v (void)
int size (void)
 Returns the number of values evaluated for this BSpline field on each samples of the input BSpline. More...
double * vector (double u, double v, double w=0.)
 Returns the value of the spatial field at the coordinates point entered. More...
QString description (void) const
 Returns the description of the field. More...
QString identifier (void) const
 Returns the identifier of the field "axlFieldParametricNormalVector". More...
- Public Member Functions inherited from axlAbstractFieldParametricSurface
 axlAbstractFieldParametricSurface ()
virtual ~axlAbstractFieldParametricSurface (void)
 Destroys a parametric field. More...
virtual double scalar (double u, double v, double w=0)
 Returns the value of the parametric field at the parameters values in input. More...
virtual double * tensor (double u, double v, double w=0)
virtual void setFunction (axlAbstractData *data)
virtual axlAbstractData * getFunction (void)
 axlAbstractFieldParametric ()
virtual ~axlAbstractFieldParametric (void)
 axlAbstractField ()
 axlAbstractField (QString name, Type type, Kind kind, Support support)
virtual ~axlAbstractField (void)
 Destroys the field. More...
virtual void setType (Type type)
 Sets the type of the field which can be either int, float or double. More...
virtual void setKind (Kind kind)
 Sets the kind of the field which can be either scalar, vector or tensor. More...
virtual void setSupport (Support support)
virtual Type type (void)
virtual Kind kind (void)
virtual Support support (void)
virtual void setMin (double mini)
 Sets the minimum value of the field. More...
virtual double minValue (void)
 Returns the minimum value of the field. More...
virtual void setMax (double maxi)
 Sets the maximum value of the field.. More...
virtual double maxValue (void)
 Returns the maximum value of the field. More...
- Public Member Functions inherited from axlAbstractData
 axlAbstractData (axlAbstractData *parent=NULL)
 axlAbstractData (const axlAbstractData &data)
virtual ~axlAbstractData (void)
const QColor & color (void) const
const double & opacity (void) const
const double & size (void) const
const QString & shader (void) const
const bool & editable (void)
const bool & updateView (void)
void setColor (double r, double g, double b)
void addField (axlAbstractField *field)
 Add a field to the field list of the object. More...
bool updateFieldList (QString nameField)
 Check if a field with the same name is already applied on the object. More...
QString changeFieldName (QString fieldName)
axlMesh * mesh (void)
 Return the mesh of that object is computed. More...
void setMesh (axlMesh *mesh)
 Set a corresponding mesh for that object. More...
virtual QVariantList convertDataToQVariant (void) const
 Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData. More...
virtual int convertQVariantToData (const QVariantList &data)
 Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0. More...
void setUpdateView (bool updateView)
QList< axlAbstractField * > fields (void)
Additional Inherited Members
- Public Types inherited from axlAbstractField
enum  Type { Int = 0x001, Float = 0x002, Double = 0x004 }
enum  Kind { Scalar = 0x001, Vector = 0x002, Tensor = 0x004 }
enum  Support { Point = 0x001, Cell = 0x002, Custom = 0x004 }
- Signals inherited from axlAbstractFieldParametricSurface
void updated (void)
void updated (void)
void updated (void)
- Signals inherited from axlAbstractData
void modifiedGeometry (void)
void modifiedStructure (void)
void modifiedField (void)
void modifiedProperty (void)
- Properties inherited from axlAbstractData
QColor color
double opacity
double size
QString shader
Detailed Description
Definition at line 23 of file axlFieldParametricNormalVector.h.
Constructor & Destructor Documentation
axlFieldParametricNormalVector::axlFieldParametricNormalVector ( )
Definition at line 48 of file axlFieldParametricNormalVector.cpp.
axlFieldParametricNormalVector::~axlFieldParametricNormalVector ( void  )
virtual
Definition at line 63 of file axlFieldParametricNormalVector.cpp.
Member Function Documentation
QString axlFieldParametricNormalVector::description ( void  ) const
virtual
Reimplemented from axlAbstractFieldParametricSurface.
Definition at line 110 of file axlFieldParametricNormalVector.cpp.
double axlFieldParametricNormalVector::end_u ( void  )
virtual
Definition at line 159 of file axlFieldParametricNormalVector.cpp.
double axlFieldParametricNormalVector::end_v ( void  )
virtual
Definition at line 169 of file axlFieldParametricNormalVector.cpp.
QString axlFieldParametricNormalVector::identifier ( void  ) const
virtual
Definition at line 100 of file axlFieldParametricNormalVector.cpp.
double axlFieldParametricNormalVector::numbersample_u ( void  )
virtual
Definition at line 180 of file axlFieldParametricNormalVector.cpp.
double axlFieldParametricNormalVector::numbersample_v ( void  )
virtual
Definition at line 189 of file axlFieldParametricNormalVector.cpp.
void axlFieldParametricNormalVector::setSurface ( axlAbstractData *  data)
virtual
Definition at line 129 of file axlFieldParametricNormalVector.cpp.
int axlFieldParametricNormalVector::size ( void  )
virtual
Definition at line 199 of file axlFieldParametricNormalVector.cpp.
double axlFieldParametricNormalVector::start_u ( void  )
virtual
Definition at line 139 of file axlFieldParametricNormalVector.cpp.
double axlFieldParametricNormalVector::start_v ( void  )
virtual
Definition at line 150 of file axlFieldParametricNormalVector.cpp.
void axlFieldParametricNormalVector::update ( void  )
virtualslot
Mark the internal data structure as changed to notify underlying pipeline execution.
Definition at line 210 of file axlFieldParametricNormalVector.cpp.
double * axlFieldParametricNormalVector::vector ( double  u,
double  v,
double  w = 0.
virtual
Definition at line 75 of file axlFieldParametricNormalVector.cpp.
The documentation for this class was generated from the following files:
