14 #include "axlCoreExport.h"
   15 #ifndef AXLFIELDPARAMETRICNORMALVECTOR_H
   16 #define AXLFIELDPARAMETRICNORMALVECTOR_H
   20 class axlFieldParametricNormalVectorPrivate;
   45     double *
vector(
double u,
double v,
double w=0.);
   57     axlFieldParametricNormalVectorPrivate *d;
   63 #endif // AXLFIELDPARAMETRICNORMALVECTOR_H
virtual double start_u(void)
Returns the first u-value parameter.
virtual int size(void)
Returns number of parameters on which the field is evaluated.
AXLCORE_EXPORT dtkAbstractData * createaxlFieldParametricNormalVector(void)
virtual void update(void)
virtual double start_v(void)
Returns the first v-value parameter.
virtual double numbersample_v(void)
Returns the number of v-parameters.
virtual double numbersample_u(void)
Returns the number of u-parameters.
virtual double end_u(void)
Returns the last v-value parameter.
virtual double * vector(double u, double v, double w=0)
Returns the value of the parametric field evaluated at the parameters in input.
virtual double end_v(void)
Class axlFieldParametricNormalVector defines an API for field which owns a BSpline Surface as a funct...
virtual QString identifier(void) const
Returns the description of the field.
virtual QString description(void) const
Class axlAbstractFieldParametricSurface defines an API for parametric field.
virtual void setSurface(axlAbstractData *surface)
Sets the support surface of the field.
Class axlAbstractData defines an API for all type of axel data.
